SeeCwriter
Problem with v5.056 |
Posted: Tue Mar 22, 2016 3:00 pm |
A program I have that compiled fine with v5.055 gets reams of errors with v5.056. Is there something I need to know?
#include <18F67K22.h>
#ifdef _DEBUG_
#device *=16 ADC=12 ICD=TRUE WRITE_EEPROM=NOINT
//#define USE_ANALOG_TEST
#else
#device *=16 ADC=12 WRITE_EEPROM=NOINT
#nolist
#ZERO_RAM
#include "version.h"
#include <ctype.h>
#include <float.h>
#include <limits.h>
#include <math.h>
#include <stddef.h>
#include <stdlib.h>
#include <string.h>
#include <stdio.h>
#include <stdint.h>
#ifdef USE_BOOTLOADER
#include <bootloader.h>
** These fuses must match the fuses in the bootloader application.
#FUSES PUT
#FUSES HSM
#FUSES WDT_SW // Software Watch Dog Timer.
#FUSES WDT512 // Watch Dog Timer uses 1:512 Postscale for 2-sec timeout.
#FUSES BORV30 // Brown-out Reset at 3.0V.
#use delay(clock=64000000,internal=16000000,restart_wdt)
#use FAST_IO( D )
#use FAST_IO( E )
#use FAST_IO( F )
#use rs232(baud=38400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=COM1,restart_wdt)
#use timer(timer=0,tick=100us,bits=32,NOISR)
The first error is with the #use timer statement: "USE parameter value is out of range. Does not have Timer 0"
Next error: "A numeric expression must appear here"
Referring the function get_ticks().
CurrentTick = get_ticks();
Really? |
SeeCwriter
Posted: Tue Mar 22, 2016 3:23 pm |
FYI...going back to v5.055 works. I'll stay with that for now. v5.056 is not ready for prime time. |
Posted: Tue Mar 22, 2016 10:02 pm |
In vs. 5.056, getenv() says Timer0 doesn't exist. It also gives a strange
result for Timer1. It should be 0 or 1.
Quote: |
Timer0: 00
Timer1: 05
Timer2: 01
Test program:
Code: | #include <18F67K22.h>
#fuses INTRC_IO, NOWDT
#use delay(clock=4M)
printf("Timer0: %x \r", getenv("TIMER0"));
printf("Timer1: %x \r", getenv("TIMER1"));
printf("Timer2: %x \r", getenv("TIMER2"));
while(TRUE);
I then ran the same test program for the 18F4620. It also says Timer0
doesn't exist (in compiler vs. 5.056):
Quote: | Timer0: 00
Timer1: 01
Timer2: 01 |
#include <18F4620.h>
while(TRUE);
Conclusion: Compiler vs. 5.056 is buggy.
I reported this bug to CCS support today, on Wednesday morning.
CCS reports they will fix it in vs. 5.057. |
