Warning 240
rafaluc2001
Warning 240
PostPosted: Sun Mar 20, 2016 9:37 am     Reply with quote
Good afternoon,
I wonder what's going to appear this warning?
I'm using PCWHD 5,056.
>>> Warning 240 "C: \ Program Files \ PICC \ Drivers \ can-18xxx8.c" Line 112 (22.23): Pointer types do not match
can_set_id (RX0FILTER0 0, CAN_USE_EXTENDED_ID); // SET FILTER 0 of 0 mask
Note:
The Cursor in the comma RX0FILTRO
  Another thing, when you compile in PCWHD 4,141 not appear this warning.
Thank you all,
PostPosted: Sun Mar 20, 2016 10:07 am     Reply with quote
You have fiddled with the file.
The supplied file has a comma between
RX0FILTER0 and the following 0.....
rafaluc2001
PostPosted: Sun Mar 20, 2016 10:15 am     Reply with quote
Sorry, error copy of the translator.
the right is.
can_set_id (RX0FILTER0, 0, CAN_USE_EXTENDED_ID); // SET FILTER 0 of 0 mask
PostPosted: Sun Mar 20, 2016 11:06 am     Reply with quote
OK.
That is because a little while ago, CCS added checks on whether things like pointers were of the type declared, rather than allowing automatic casting to just silently happen.
It is only a warning. Doesn't stop things from working.
If you want to avoid it, you can either just turn off the warning, or cast the variable to the required type (if you have the IDE just hover over the function, and it'll display the types it expects to receive).
They have obviously not checked this file, since the change was made.
rafaluc2001
PostPosted: Sun Mar 20, 2016 1:09 pm     Reply with quote
I do not know where to start, could you show a working example?
PostPosted: Sun Mar 20, 2016 1:27 pm     Reply with quote
Why?.
The warning _does not matter_.
However if you must, then change every use of can_set_id like:
can_set_id ((unsigned int *)RX0FILTER0, 0, CAN_USE_EXTENDED_ID); // SET FILTER 0 of 0 mask
Adding the cast shown.
rafaluc2001
PostPosted: Sun Mar 20, 2016 2:27 pm     Reply with quote
It worked, no more warnings
Thank you for your help!
