SOLVED: Timer interrupt slow
JackB
PostPosted: Sat Mar 19, 2016 6:49 pm     Reply with quote
I use a PIC18F67K90 at 20MHz.
It seems my 1mSec timer interrupt, is about 2 times too slow.
The LED should flash at 1 Hz rate, but it is 1 second on and 1 second off.
The other two receive interrupts are not triggered much.
What should I check to find out why the timer interrupt is slowing down?
main.c:
#include "project.h"
#define DMX_SIZE        128
#define DMX_BREAK_COUNT 8
uint16 msecs;
uint16 heartbeat_count;
uint8 dmx_in[DMX_SIZE];
uint16 dmx_index;
uint16 dmx_value;
uint16 dmx_break_time;
uint8 dmx_skip_bytes;
uint8 dmx_signal_detected;
uint16 dmx_address;
... (some more variables)
    setup_timer_2(T2_DIV_BY_4, 249, 10);
    enable_interrupts(INT_RDA);     // UART1 gives INT_RDA
    enable_interrupts(INT_RDA2);    // UART2 gives INT_RDA2
#INT_TIMER2
void timer2_isr()
    // Timer interrupt every 1 mSec
    if(--heartbeat_count==0) {
        output_toggle(PIN_C1);      // Heartbeat LED
        heartbeat_count = 500;            // Toggle every 500 mS
    if (dmx_break_time < 1000)
        dmx_break_time++;           // Increase measured break time by 1 mSec
    if (dmx_break_time > 100)
        dmx_signal_detected = 0;    // Flag indicates presence of DMX signal
    msecs++;
#INT_RDA2
void usb_isr2() {
    // Is this receiver interrupt on the STD stream? Does not trigger?
    std_byte = (int8)fgetc(USB_STREAM);             // Read RX register
    if (std_byte == 0x0d)
        input_string_fetching[input_index] = (char) '\0';
        input_string_fetching[input_index] = (char) std_byte;
    input_index++;
    if (input_index > INPUT_STRING_SIZE-1)
        input_index = INPUT_STRING_SIZE-1;
#INT_RDA
void dmx_isr() {
    // Is this receiver interrupt on the DMX stream? Does not trigger?
    int8 dmx_byte = (int8)fgetc(DMX_STREAM);             // Read RX register
    if (dmx_break_time > DMX_BREAK_COUNT) {      // MARK time after Slot > 15mS, reset index
        dmx_index = 0;
        dmx_skip_bytes = 2;
        dmx_signal_detected = 1;
    if (dmx_skip_bytes > 0) {
        dmx_skip_bytes--;
    else {
        dmx_in[dmx_index++] = dmx_byte;
        if (dmx_index == DMX_SIZE)
           dmx_index = DMX_SIZE-1;           // Ensure this cannot overflow.
    dmx_break_time = 0;             // Character received: reset break time
project.h:
#ifndef PROJECT_H
#define   PROJECT_H
#include <18F67K90.h>
#include "types.h"
#define BOARD_CURRENT_DRIVER  1
#define BOARD_VOLTAGE_DRIVER  1-BOARD_CURRENT_DRIVER
#case
#device ADC=12
#fuses MCLR,HSH,NOPLLEN
#use delay(crystal=20mhz)
#use rs232(UART1, BAUD=250000,BITS=9,PARITY=N,STOP=1,ERRORS,stream=DMX_STREAM, LONG_DATA)
#use rs232(uart2, baud=9600, stream=USB_STREAM)
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3)
enum errors { err_range, err_too_far, err_too_many };
#endif   /* PROJECT_H */
jeremiah
PostPosted: Sat Mar 19, 2016 7:30 pm     Reply with quote
The parameters you have have chosen make the pin toggle every second
Fosc = 20MHz
Fcy = 20/4 = 5MHz
Prescaler of 4x: 5/4 = 1.25 MHz
Postscaler of 10x: 1.25/10 = 125kHz = 8us per tick
250 ticks per period => 8us * 250 = 2ms per timer period
500 counts per toggle => 2*500 = 1 second per toggle (1 second on and 1 second off)
JackB
PostPosted: Sun Mar 20, 2016 5:04 am     Reply with quote
Hi Jeremiah,
thank you very much! That fixed the problem!
I'm still learning with ccs c.
It works as expected, and I have added your comments in the code for future reference.
This is how I understood it:
// The parameters to make the pin toggle every 500ms are
// Fosc = 20MHz
// Fcy = 20/4 = 5MHz
// Prescaler of 4x: 5/4 = 1.25 MHz
// Postscaler of 5x: 1.25/5 = 250kHz = 4us per tick
// (249+1) ticks per period => 4us * 250 = 1ms per timer period
// 500 counts per toggle => 1*500 = 500ms per toggle (500ms on and 500ms off)
setup_timer_2(T2_DIV_BY_4, 249, 5);
