AnthonyRFC
DS1307 doesn't keep day of the month |
Posted: Sun Jun 21, 2015 6:54 am |
Hi all:
I'm having a rare problem with the DS1307 RTC chip, doesn't keep the day of the month when I retire the 5V.
I checked the basic: battery, pull-up resistor, tried with different libraries and nothing, the problem persist. So I think that problem could be in the code. Basically, when you start the microcontroller, the DS1307 init, then enters an infinite loop to display data (7 segments) and see if the user wants to change the time (TIMESET flag). To read the DS1307, I do it in the function mostrar() to avoid flashes on the display while the micro performs the reading.
CODE
Code: | #include <16F873.h>
#fuses XT,NOWDT,NOPROTECT
#BYTE TRISD=0x88
#BYTE PORTD=0x08
#include <math.h>
#include <ds1307todopic.c>
#use i2c(Master,slow,sda=PIN_C4,scl=PIN_C3)
byte day=31;
byte dow=7;
byte year=15;
byte mth=12;
byte hr=23;
byte prehr=0,min=59,copia=0, TIMESET=0;
byte contaseg=0, estado=1,mipre=0,uni=0,dec=0,buni=0,bdec=0,grup1=0,grup2=0,lectoconta=0, daycarrier=0;
byte sec=0;
int1 turnseg=0,setling=0,leeds=0;
byte const num[10]={238,6,220,158,54,186,250,14,254,62};
#define DATA PIN_A1
#define CLOCK PIN_A0
#define RAYA PIN_C1
#define SEGUNDERO PIN_C0
#define HAB1 PIN_C2
#define HAB2 PIN_C5
#define HAB3 PIN_C6
#define HAB4 PIN_C7
#define TS PIN_B0
#define MINSET PIN_B2
#define HORASET PIN_B1
#define DIASET PIN_B3
#define SETMES PIN_B4
#define ANOSET PIN_B5
#define AM PIN_B6
#define PM PIN_B7
//#define DEBUG3 PIN_C3
//#define DEBUG4 PIN_C4
void escribir(int8 aux){ ////////FUNCION ESCRIBIR PARA LOS REGISTROS DE DESPLAZAMIENTO
int i;
for(i=0;i<8;i++)
if(bit_test(aux, i)==0)
output_low (DATA);
output_low (CLOCK);
output_high(CLOCK);
if(bit_test(aux,i)==1)
output_high(DATA);
output_low (CLOCK);
output_high(CLOCK);
} ///////////////////////////////FIN DE FUNCION ESCRIBIR
void bin_bcd(){ /////////////////SEPARA LOS DATOS PARA IMPRIMIR
if (hr==0){
prehr=12;
output_low (PM); //PM OFF
output_high (AM); //AM ON
else if (hr==12){
prehr=hr;
output_low (AM); // AM OFF
output_high (PM); //PM ON
else if (hr>12){
prehr=hr-12;
else{
prehr=hr;
if (TIMESET==1){
grup2=20;
grup1=year;
if ((TIMESET==2)||(estado==2)){
grup2=day;
grup1=mth;
//grup1=daycarrier;
if ((TIMESET==3)||(estado==1)){
grup2=prehr;
grup1=min;
copia=grup1;
dec= copia/10;
copia= copia%10;
uni=copia;
copia=grup2;
bdec= copia/10;
copia= copia%10;
buni=copia;
void mostrar(){
bin_bcd();
output_low(HAB4);
escribir(num[uni]);
output_high(HAB1);
if (leeds==0){
delay_ms(2);
if (leeds==1){
ds1307_get_date(day,mth,year,dow);
output_low(HAB1);
output_low(HAB2);
output_low(HAB3);
output_low(HAB4);
escribir(num[dec]);
delay_us(10);
output_high(HAB2);
if (leeds==1){
ds1307_get_time(hr,min,sec);
leeds=0;
if (leeds==0){
delay_ms(2);
output_low(HAB1);
output_low(HAB2);
output_low(HAB3);
output_low(HAB4);
escribir(num[buni]);
delay_us(10);
output_high(HAB3);
delay_ms(2);
if((bdec>0))
output_low(HAB1);
output_low(HAB2);
output_low(HAB3);
output_low(HAB4);
escribir(num[bdec]);
delay_us(10);
output_high(HAB4);
delay_ms(2);
output_low(HAB1);
output_low(HAB2);
output_low(HAB3);
output_low(HAB4);
delay_ms(2);
#INT_TIMER1
void temp1_isr() {
disable_interrupts(INT_TIMER1);
if (mipre==2){
turnseg=!turnseg;
mipre=0;
if (contaseg==20){
contaseg=0;
estado++;
if (estado>2){
estado=1;
if (lectoconta==0){
lectoconta=20;
leeds=1;
contaseg++;
mipre++;
lectoconta--;
set_timer1(3036);
void main(){ //INICIO DEL PROGRAMA
set_tris_C(0b00000000);
PORTD=0b00000000;
disable_interrupts(global);
output_low (SEGUNDERO);
output_low (RAYA);
ds1307_init(DS1307_ALL_DISABLED); //INICIALIZACIÓN DEL DS1307
setup_timer_1(T1_INTERNAL|T1_DIV_BY_4);
set_timer1(3036);
ds1307_get_date(day,mth,year,dow);//LECTURA INICIAL
ds1307_get_time(hr,min,sec); //LECTURA INICIAL
while (1){
mostrar();
if (input(TS)==0){
while (input(TS)==0){
mostrar();
TIMESET++;
if (TIMESET>3){
TIMESET=0;
if (TIMESET>0){ ///INICIO DEL DE LA CONFIGURACIÓN DEL TIEMPO
setling=1;
estado=0;
leeds=0;
if (TIMESET==1){
output_low(SEGUNDERO);
output_low(RAYA);
if (TIMESET==2){
output_high (RAYA);
if (TIMESET==3){
output_high (SEGUNDERO);
output_low (RAYA);
if ((input(HORASET)==0)&&(TIMESET==3)){//INICIO CONFIGURACION DE LA HORA
while(input(HORASET)==0){
mostrar();}
if (hr>=23){
hr=0;
else{
hr++;
}//////////////////FINAL CONFIGURACIÓN DE LA HORA
if((input(MINSET)==0)&&(TIMESET==3)){ //INICIO CONFIGURACIÓN DE LOS MINUTOS
while(input(MINSET)==0){
mostrar();}
if (min>=59){
min=0;
else{
min++;
} //////////////////FINAL CONFIGURACIÓN DE LOS MINUTOS
if ((input(DIASET)==0)&&(TIMESET==2)){//////INICIO CONFIGURACION DEL DÍA
while(input(DIASET)==0){
mostrar();
if (mth==1||mth==3||mth==5||mth==7||mth==8||mth==10||mth==12){
if(day>=31){
day=1;
else{
day++;
else if (mth==4||mth==6||mth==9||mth==11){
if(day>=30){
day=1;
else{
day++;
else if (mth==2){
if(year==16||year==20||year==24||year==28||year==32||year==36||year==40||year==44){
if (day==29){
day=1;
else{
day++;
else if (day==28){
day=1;
else{
day++;
}//////////////////////////FINAL DE CONFIGURACIÓN DEL DÍA
if ((input(SETMES)==0)&&(TIMESET==2)){////INICIO DE CONFIGURACIÓN DEL MES
while(input(SETMES)==0){
mostrar();
if (mth>=12){
mth=1;
else{
mth++;
} //////////////////FIN DE CONFIGURACIÓN DEL MES
if ((input(ANOSET)==0)&&(TIMESET==1)){///INICIO CONFIGURACION DEL AÑO
while(input(ANOSET)==0){
mostrar();
if (year>=99){
year=1;
else{
year++;
}//////////////////////FINAL DE CONFUGURACIÓN DEL AÑO
}////////////////////////////FINAL DEL CICLO IF DE LA CONFIGURACIÓN DEL TIEMPO
if ((TIMESET==0)&&(setling==1)){
setling=0;
sec=0;
daycarrier=day;
delay_ms(200);
ds1307_set_date_time(day,mth,year,dow,hr,min,sec);
delay_ms(200);
estado=1;
set_timer1(3036);
if (TIMESET==0){
if ((estado==1)&&(turnseg==1)){
output_high(SEGUNDERO);
else {
if (estado==2){
output_high (RAYA);
else{
output_low (RAYA);
}//FINAL DEL PROGRAMA |
LIBRARY
Code: | ///////////////////////////////////////////////////////////////////////////////////////
/// DS1307.C ///
/// Driver for Real Time Clock ///
/// modified by Redpic 08/2006 ///
/// http://picmania.garcia-cuervo.com ///
/// void ds1307_init(val) ///
/// - Enable oscillator without clearing the seconds register ///
/// used when PIC loses power and DS1307 run from 3V BAT ///
/// - Config Control Register with next parameters: ///
/// DS1307_ALL_DISABLED All disabled ///
/// DS1307_OUT_ON_DISABLED_HIHG Out to Hight on Disable Out ///
/// DS1307_OUT_ENABLED Out Enabled ///
/// DS1307_OUT_1_HZ Freq. Out to 1 Hz ///
/// DS1307_OUT_4_KHZ Freq. Out to 4.096 Khz ///
/// DS1307_OUT_8_KHZ Freq. Out to 8.192 Khz ///
/// DS1307_OUT_32_KHZ Freq. Out to 32.768 Khz ///
/// Example init: ///
/// ds1307_init(DS1307_ALL_DISABLED); ///
/// ds1307_init(DS1307_OUT_ENABLED | DS1307_OUT_1_HZ); ///
/// void ds1307_set_date_time(day,mth,year,dow,hour,min,sec) - Set the date/time ///
/// void ds1307_get_date(day,mth,year,dow) - Get the date ///
/// void ds1307_get_time(hr,min,sec) - Get the time ///
/// char ds1307_read_nvram_byte(char addr) - Read byte in address ///
/// void ds1307_write_nvram_byte(char addr, char value) - Write byte in address ///
/// void ds1307_get_day_of_week(char* ptr) - Get string Day Of Week///
/// If defined USE_INTERRUPTS all functions disable Global Interrupts on starts and ///
/// enable Global on ends else usar can do it hiself ///
#ifndef RTC_SDA
#define RTC_SDA PIN_C4
#define RTC_SCL PIN_C3
#endif
#use i2c(master, sda=RTC_SDA, scl=RTC_SCL)
#define DS1307_ALL_DISABLED 0b00000000 // All disabled
#define DS1307_OUT_ON_DISABLED_HIHG 0b10000000 // Out to Hight on Disable Out
#define DS1307_OUT_ENABLED 0b00010000 // Out Enabled
#define DS1307_OUT_1_HZ 0b00000000 // Freq. Out to 1 Hz
#define DS1307_OUT_4_KHZ 0b00000001 // Freq. Out to 4.096 Khz
#define DS1307_OUT_8_KHZ 0b00000010 // Freq. Out to 8.192 Khz
#define DS1307_OUT_32_KHZ 0b00000011 // Freq. Out to 32.768 Khz
#define Start_user_address_nvram 0x08
#define End_user_address_nvram 0x3f
char days_of_week[7][11]={"Lunes\0","Martes\0","Miércoles\0","Jueves\0","Viernes\0","Sábado\0","Domingo\0"};
byte ds1307_bin2bcd(byte binary_value);
byte ds1307_bcd2bin(byte bcd_value);
void ds1307_init(int val){
byte seconds = 0;
#ifndef USE_INTERRUPTS
#endif
i2c_start();
i2c_write(0xD0);
i2c_write(0x00);
i2c_start();
i2c_write(0xD1);
seconds = ds1307_bcd2bin(i2c_read(0));
i2c_stop();
seconds &= 0x7F;
delay_us(3);
i2c_start();
i2c_write(0xD0);
i2c_write(0x00);
i2c_write(ds1307_bin2bcd(seconds));
i2c_start();
i2c_write(0xD0);
i2c_write(0x07);
i2c_write(val);
i2c_stop();
enable_interrupts(global);
#endif
void ds1307_set_date_time(byte day, byte mth, byte year, byte dow, byte hr, byte min, byte sec){
#endif
sec &= 0x7F;
hr &= 0x3F;
i2c_start();
i2c_write(0xD0);
i2c_write(0x00);
i2c_write(ds1307_bin2bcd(sec));
i2c_write(ds1307_bin2bcd(min));
i2c_write(ds1307_bin2bcd(hr));
i2c_write(ds1307_bin2bcd(dow));
i2c_write(ds1307_bin2bcd(day));
i2c_write(ds1307_bin2bcd(mth));
i2c_write(ds1307_bin2bcd(year));
i2c_stop();
#endif
void ds1307_get_date(byte &day, byte &mth, byte &year, byte &dow){
#endif
i2c_start();
i2c_write(0xD0);
i2c_write(0x03);
i2c_start();
i2c_write(0xD1);
dow = ds1307_bcd2bin(i2c_read() & 0x7f);
day = ds1307_bcd2bin(i2c_read() & 0x3f);
mth = ds1307_bcd2bin(i2c_read() & 0x1f);
year = ds1307_bcd2bin(i2c_read(0));
i2c_stop();
#endif
void ds1307_get_time(byte &hr, byte &min, byte &sec){
#endif
i2c_start();
i2c_write(0xD0);
i2c_write(0x00);
i2c_start();
i2c_write(0xD1);
sec = ds1307_bcd2bin(i2c_read() & 0x7f);
min = ds1307_bcd2bin(i2c_read() & 0x7f);
hr = ds1307_bcd2bin(i2c_read(0) & 0x3f);
i2c_stop();
#endif
char ds1307_read_nvram_byte(char addr){
char retval;
#endif
i2c_start();
i2c_write(0xD0);
i2c_write(addr);
i2c_start();
i2c_write(0xD1);
retval = i2c_read(0);
i2c_stop();
return(retval);
#endif
void ds1307_write_nvram_byte(char addr, char value){
#endif
i2c_start();
i2c_write(0xD0);
i2c_write(addr);
i2c_write(value);
i2c_stop();
#endif
void ds1307_get_day_of_week(char* ptr){
byte lday;
byte lmonth;
byte lyr;
byte ldow;
ds1307_get_date(lday,lmonth,lyr,ldow);
sprintf(ptr,"%s",days_of_week[ldow]);
byte ds1307_bin2bcd(byte binary_value){
byte temp;
byte retval;
temp = binary_value;
retval = 0;
while(1){
if(temp >= 10){
temp -= 10;
retval += 0x10;
}else{
retval += temp;
return(retval);
byte ds1307_bcd2bin(byte bcd_value){
byte temp;
temp = bcd_value;
temp >>= 1;
temp &= 0x78;
return(temp + (temp >> 2) + (bcd_value & 0x0f));
Best regards from Venezuela. _________________ From Cumaná, Venezuela. |
Posted: Sun Jun 21, 2015 8:14 am |
First, get rid of the interrupt disable/enable inside the timer interrupt. This is pointless (interrupts are already disabled in the interrupt handler). Just a waste of space.
Then you have two I2C setups. Should only be one. The driver already contains an I2C setup....
Then a worrying one. The driver uses 'reference' parameters to allow it to change the value in an external variable. You have global variables, with the same name as the reference parameters, which are then being passed as the variables for the reference parameters. This is dangerous coding, and I would not be at all surprised if this did cause problems.... The driver expects to be handed _local_ variable names, not global variables, and certainly not with the same name.
Then if you want us to understand your code, it needs to be laid out much better, and have some documentation. As it stands, it is a mess. Tell us where in the code you are actually getting to, and what is missing at this point, as the minimum starting point. |
AnthonyRFC
Posted: Tue Jun 23, 2015 8:49 pm |
Hi
First, thanks for the quick response. One of my reasons for get in this forum is to learn to make more orderly and efficient codes.
About your request, I put a synthesis of software:
- escribir (): I used it to write the 74LS164
-bin_bcd() : take the bin value to bcd
-mostrar() : multiplex the 7 segments displays and read the DS1307
-TIMER 1 : Is called every 250mS, I used to control the colon and the reading rate of the DS1307.
The rest of the program is to set the time through the buttons.
In the other hand, your recomendation is something like this?
-mth,day,hr,min (local variables into the DS1307 driver library)
-mes,dia, hora, minutos (global variables into the main program
**In the read process
mes=mth;
day=dia;
hora=hr;
minutos=min;
**In the write process (like setting the time)
mth=mes;
day=dia;
hr=hora;
min=minutos;
By the way, how I upload the Proteus simulation to the forum?
Best regards. _________________ From Cumaná, Venezuela. |
Posted: Wed Jun 24, 2015 1:10 am |
You don't.
If this is a problem in Proteus, they we don't want to hear about it. Read the sticky post at the top of the forum. The Proteus simulator is the cause of more wasted time than any other piece of software involved with the PIC. It'll tell you 'good' software can't work, and also tell you that designs can work, that have not got a hope of functioning on a real chip. Don't waste your time with it.... |
AnthonyRFC
Posted: Wed Jun 24, 2015 5:27 am |
Ohhhh No, no,no! It's a real problem, real chip, real hardware, i was asking to upload the schematic of the circuit due to you requested more information.
So, what do you think about my proposal ?
Thanks in advance _________________ From Cumaná, Venezuela. |
Posted: Wed Jun 24, 2015 5:50 am |
At initialisation you set dow=7
Then at start of main this is overwritten by a call to ds1307_get_date(day,mth,year,dow). Now dow contains a random value that was in the DS1307
You never change dow.
When the user changes the time, you write the random DOW value back to the chip.
How do you know the chip doesn't remember the day of the month?
Nowhere in your code do you use the value. |
AnthonyRFC
Posted: Wed Jun 24, 2015 6:21 am |
I used the "day" variable inside of the bin_bcd() and mostrar() sub functions.
So, do you think that the random value in the dow variable is the origin of the problem?
Ttelmah make me a warning advice when using the local variables of the driver in the main program.
void bin_bcd(){ //
if (TIMESET==1){
grup2=20;
grup1=year;
grup2=day;
grup1=mth;
grup2=prehr;
grup1=min;
copia=grup1;
dec= copia/10;
copia= copia%10;
uni=copia;
copia=grup2;
bdec= copia/10;
copia= copia%10;
buni=copia;
void mostrar(){
bin_bcd();
output_low(HAB4);
escribir(num[uni]);
output_high(HAB1);
if (leeds==0){
delay_ms(2);
if (leeds==1){
} _________________ From Cumaná, Venezuela. |
Posted: Wed Jun 24, 2015 2:42 pm |
My mistake. First time I read your question as having problems with the Day Of Week instead of Day of month.
I tried following your code but it took too much of my time. Your code is difficult to follow.
Here are a few hints:
- Use English comments
- When you have parts consisting of more than 20 lines of code, then break them into multiple functions. Repeat until each function is maximum 20 lines.
- At the top of each function add little comment (in English) about what the function is doing. For example, for the timer interrupt it is great help when you write how often the interrupt is called each second.
- Try to use as little global variables as possible. Try to move them into the local function that uses them. This makes your code easier to read and saves memory.
- Convention is to only write constants and defines in all capital letters. Your variables like TIMESET and TS do not follow this rule.
- Instead of hard coded values like 'TIMESET==3' try to use defines or enums for better readability: Code: | enum timeSet_t {
SET_NONE = 0,
SET_YEAR,
SET_DAY,
SET_MIN
enum timeSet_t timeSet;
if (timeSet == SET_YEAR) {
AnthonyRFC
Posted: Sat Jun 27, 2015 7:41 am |
Hi:
First of all, thanks for your time and help!
I couldn't understand the structure of the "enums". In the other hand, for a quick test, I erased the part of the program to set the time in the DS1307 and ran the code. The problem continues, so I keep confused about it.
Summarizing:
1.- I put global variables for the main program and local variables for the DS1307 chip.
2.- Corrected writing of random values of DOW variable
3-re-re-re-re-re-re-re checked the hardware (battery, pull-ups resistors).
Finally, a short video of the program in the real life.
https://www.youtube.com/watch?v=D6mpoEcyygQ&feature=youtu.be
PS: Program with english comments and without the messy part of setting the time.
#BYTE TRISD=0x88
#BYTE PORTD=0x08
#include <math.h>
//////////////////////////////////////////////////// LOCAL & GLOBAL VARIABLES
byte day=26,hr=22,sec=0,mth=6,year=15,min=0,dow=3;
byte dia=31;
byte diasem=7;
byte anno=15;
byte mes=12;
byte hora=23;
byte prehr=0,minutos=20,copia=0, time_set=0;
byte segundos=0;
///////////////////////////////////////////////// PINOUT OF MICROCONTROLER
#define DATA PIN_A1
#define RAYA PIN_C1
#define HAB1 PIN_C2
#define HAB2 PIN_C5
#define HAB3 PIN_C6
#define HAB4 PIN_C7
#define TS PIN_B0
#define AM PIN_B6
#define PM PIN_B7
void write_74(int8 aux){ //////// THIS FUNCTION IS USED TO WRITE THE 74LS164 (SERIAL-PARALLEL REGISTER)
int i;
for(i=0;i<8;i++)
output_low (DATA);
output_low (CLOCK);
output_high(CLOCK);
output_high(DATA);
output_low (CLOCK);
output_high(CLOCK);
} ///////////////////////////////END OF write_74
void bin_bcd(){ /////////////////binary to BCD
if (hora==0){
prehr=12;
else if (hora==12){
prehr=hora;
else if (hora>12){
prehr=hora-12;
else{
prehr=hora;
if (time_set==1){ ///////////// This part is used to show time of date acording to "estado" variable.
grup2=20;
grup1=anno;
if ((time_set==2)||(estado==2)){
grup2=dow;
grup1=mes;
//grup1=daycarrier;
if ((time_set==3)||(estado==1)){
grup2=prehr;
grup1=minutos;
copia=grup1;
dec= copia/10;
copia= copia%10;
uni=copia;
copia=grup2;
bdec= copia/10;
copia= copia%10;
buni=copia;
void mostrar(){ /// Multiplexing of display
bin_bcd();
write_74(num[uni]); //Write the 74LS164
delay_us (20); //small time to avoid ghost
output_high(HAB1); //turn the 1 display
if (leeds==0){ // "leeds" is a flag to decide if read or not the DS1307 chip
delay_ms(2);
if (leeds==1){ // Read the DS1307
dia=day; //local to global variable
mes=mth;
anno=year;
output_low(HAB1);
write_74(num[dec]);
delay_us(20);
output_high(HAB2);
if (leeds==1){
hora=hr;
minutos=min;
leeds=0;
if (leeds==0){
delay_ms(2);
output_low(HAB2);
write_74(num[buni]);
delay_us(20);
output_high(HAB3);
delay_ms(2);
output_low (HAB3);
if((bdec>0))
write_74(num[bdec]);
delay_us(20);
output_high(HAB4);
delay_ms(2);
output_low (HAB4);
output_low(HAB1);
output_low(HAB2);
output_low(HAB3);
output_low(HAB4);
delay_ms(2);
#INT_TIMER1
void temp1_isr() { /// Is called every 250mS
if (mipre==2){ // This control the flag to turn ON/OFF the colon
turnseg=!turnseg;
mipre=0;
if (contaseg==20){ //This control how fast the display change to show HH:MM DAY-MONTH
contaseg=0;
estado++;
if (estado>2){
estado=1;
if (lectoconta==0){//This control de reading rate of the DS1307 chip
lectoconta=20;
leeds=1;
contaseg++;
mipre++;
lectoconta--;
void main(){ ///// MAIN PROGRAM
PORTD=0b00000000;
output_low (RAYA);
set_timer1(3036);
ds1307_init(DS1307_ALL_DISABLED); //INIT OF DS1307
////ds1307_set_date_time(day,mth,year,dow,hr,min,sec); ///<-- This line was udes to the time and date and later, I removed to no re-write data
while (1){ ///infinite loop
mostrar(); /// Show data in display
}//END OF THE MAIN |
Joined: 01 Jul 2010 Posts: 9205 Location: Greensville,Ontario
Posted: Sat Jun 27, 2015 10:30 am |
I suggest a test using 'dummy data' instead of reading the RTC.
With this known data, does the display correctly show all variables?
I'd try several values especially for the 'day' variable as that's the only one not functioning properly.
your mostrar() function should be split into two functions
1) the actual display function
and
2) the test to see if you should read the RTC.
Actually I'm not sure why you need this test. Simply get the RTC data every time you update the display.
ezflyr
Posted: Sat Jun 27, 2015 10:41 am |
Please post a clear, in focus picture of your hardware. I suspect you have a problem with your circuit!
John |
Posted: Sat Jun 27, 2015 11:14 am |
If he is keeping all the other clock values OK, then I doubt if there is a hardware problem.
However there is a big problem in overall 'messiness', and abusing the way that parameters are actually referenced.
The key is he needs to step back, simplify, and use one part at a time. Temtronic has suggested a good way to start 'back', and doing this would allow things to be 'narrowed down'. |
ezflyr
Posted: Sat Jun 27, 2015 11:32 am |
My suspicion is that the "hardware problem" is that there is no hardware, and this is a Proteus project. On everything else I agree whole-heartedly
John |
AnthonyRFC
Posted: Sat Jun 27, 2015 12:02 pm |
ezflyr wrote: | Hi,
John |
Hi, in the beginning of the post, I mention that's a REAL hardware. In proof of that, I upload a video and now, a picture of the circuit. NO Proteus!!
VIDEO: https://www.youtube.com/watch?v=D6mpoEcyygQ&feature=youtu.be
PICTURE:
Ttelmah wrote: | step back, simplify, and use one part at a time. |
I did it.. Also find out that DAY OF THE WEEK doesn't keep.. always back from DS1307 like 7.
AnthonyRFC
Posted: Sat Jun 27, 2015 12:11 pm |
PS: The battery and buttons are located in a different PCB.
I think, there is possibility of a bug in compiler? I have Version 4.104 _________________ From Cumaná, Venezuela. |
