round() in CCS [solved elegantly]
PostPosted: Thu Jan 21, 2016 9:13 am     Reply with quote
Is there an easy equivalent to the c standard :
IN CCS - that does an honest round() function?
where the input argument is a float and the output is
an integer of the 8 or 16 bit flavor ?
PostPosted: Thu Jan 21, 2016 9:57 am     Reply with quote
Actually, 'round' is not a C standard function. However a lot of libraries do offer it.
It's easy to code as:
#define round(x) (x<0.0)?(int16)(x-0.5):(int16)(x+0.5)
an int16, will be truncated to an int8 automatically.
You could use a overloaded function to give int32, int16 & int8 versions if required.
