art
Output D problem |
Posted: Fri Jan 22, 2016 2:58 am |
Hai, I'm having trouble when I type 12345678 result at output D only D4,D5,D6 and D7 become high, D1,D2,D3,D4 will become low. Suppose all Output D will become High. What cause this problem ?
#include <18F4550.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#include <stdlib.h>
#include <input.c>
#include <string.h>
unsigned char x[9] ;
char a[] ="12345678";
unsigned char key;
unsigned char d;
while (TRUE)
if(d=='Z')
while (key!=32) // push SPACE BAR to stop
get_string(x,9);
if (strcmp(x,a)==0)
output_high(PIN_D0);
output_high(PIN_D1);
output_high(PIN_D2);
output_high(PIN_D3);
output_high(PIN_D4);
output_high(PIN_D5);
output_high(PIN_D6);
output_high(PIN_D7);
} key=0;
Mike Walne
Posted: Fri Jan 22, 2016 4:07 am |
How much of your while loop routine ever executes?
How do you know what the pin states are?
Have you tried setting all the portD pins to zero before the while loop?
Have you tested that all the portD pins can move?
Mike |
art
Posted: Fri Jan 22, 2016 4:28 am |
Hi mike,
If i change all output D to output B the problem will not happen. It will only happen at output D. |
Mike Walne
Posted: Fri Jan 22, 2016 6:04 am |
Can you make portD work correctly by a different method?
Mike |
Joined: 01 Jul 2010 Posts: 9225 Location: Greensville,Ontario
Posted: Fri Jan 22, 2016 6:25 am |
First thought was another peripheral is active on those pins but it is Odd that a nibble is not working. Perhaps it's a wiring problem. As the code 'worked on port B', I suspect hardware..maybe no power to those 4 LEDs?
Would need to see schematic and/or photo to help more.
A simple 1Hz LED program for all pins, as Mike says, might be useful.
Jay |
