hmm since the ad says 'ardunio' in it as well as ST7735, I found a driver/code on mikroc...... website. It should be that hard to convert into CCS C.
Maybe google 'ST7735 CCS C code driver' or check the 'code library' here ?
You can't be the first one using the device !!
There has to be good datasheet/info about the device or the ST7735.
Just be sure to do 'low level' testing after hardware is properly done.
Also don't assume that 'compatible' means 100% the same!!
