ex_usb_scope.c compile error
art
PostPosted: Tue Nov 24, 2015 3:56 pm     Reply with quote
Hai,
I'm trying to compile " ex_usb_scope.c" example using PIC18f4550 but it shows error :
#ERROR You must include USB hardware driver (in the usb.c) .
What should i do? Kindly please help me
////                        ex_usb_scope.c                           ////
//// This example shows how to develop a USB bulk device, and is     ////
//// accompanied by an example Windows program (oscope.exe) and      ////
//// an example Windows USB Bulk driver (usbdemo.sys).  This example ////
//// will run on CCS's USB Prototype board.                          ////
//// NOTE: THIS DOES NOT WORK PIC16C7x5 BECAUSE THAT USB PERIPHERAL  ////
////       IS A SLOW SPEED PERIPHERAL, AND SLOW SPEED ONLY SUPPORTS  ////
////       CONTROL AND INTERRUPT TRANSFERS.                          ////
//// When a PIC with this code is connected to the PC, an install    ////
//// driver wizard should pop-up in Windows.  Install the            ////
//// provided usbdemo.sys driver.  You may have to reboot the        ////
//// machine.  Once installed, you can use oscope.exe to see the     ////
//// data from the PIC.                                              ////
//// This file is part of CCS's PIC USB driver code.  See USB.H      ////
//// for more documentation and a list of examples.                  ////
[code deleted]
Code deleted.
Reason: Forum rule #10:
10. Don't post the CCS example code or drivers.
http://www.ccsinfo.com/forum/viewtopic.php?t=26245
-Forum Moderator
ezflyr
PostPosted: Tue Nov 24, 2015 4:15 pm     Reply with quote
There is this section in the code. did you remove it by any chance?
#if __USB_PIC_PERIF__
 #if defined(__PCH__)
  #include <pic18_usb.h>   //Microchip PIC18Fxx5x hardware layer for usb.c
 #elif defined(__PCD__)
  #include <pic24_usb.h>   //Microchip PIC18Fxx5x hardware layer for usb.c
 #endif
#else
 #include <usbn960x.h>   //National 960x hardware layer for usb.c
#endif
Since you are using an 18F PIC, I'd simply reduce it to this:
Does that solve your issue?
John
If it's worth doing, it's worth doing in real hardware!
art
PostPosted: Tue Nov 24, 2015 4:24 pm     Reply with quote
I did not remove it. But it still give Error Crying or Very sad
PostPosted: Tue Nov 24, 2015 4:39 pm     Reply with quote
I edited ex_usb_common.h and changed it to use the 18F4550, and it
compiles OK with CCS compiler version 5.051.
What's your compiler version ?
art
PostPosted: Tue Nov 24, 2015 5:26 pm     Reply with quote
Hi PCM
It works after I edit ex_usb_common.h to use the 18F4550.
Thank you very much...
