#INT_RTCC based pwm will not work
freedom
PostPosted: Tue Nov 17, 2015 7:07 am     Reply with quote
Hello all
www.ccsinfo.com/forum/viewtopic.php?t=20050&postdays=0&postorder=asc&start=0
They didn't show the setup code for the RTCC, so I've taken the liberty
of making a test program. For a PIC with a 4 MHz crystal, this demo
program creates a PWM signal on Pin B1, with a frequency of 100 Hz,
and a 25% duty cycle
I am trying to build pulse generator ( software pwm) as per PCM programmer provided code and working fine.
But, when I want to change the pwm rate using a switch control , its not working.
Any idea please ? I am using ver 4.124 and here is my code
   #include <16F877A.H>
   #device *=16            // Use 16 bit pointers for Full RAM use (for 14 bit parts)
   #device adc=10          //Configures the read_adc return size
   #use delay(clock = 20MHZ)       //Crystal Frequency  clock
   #use fast_io(A) // Port forwarding commands apply to A port
   #use fast_io(B) // Port forwarding commands apply to B port
   #use fast_io(C) // Port forwarding commands apply to C port
   #use fast_io(D) // Port forwarding commands apply to D port
   #use fast_io(E) // Port forwarding commands apply to E port
   #define  Speed_1            PIN_B7
   #define  Speed_2            PIN_B6
   #define  Stepper_pulse_out      PIN_C1
   //#define LOOPCNT 39 // PWM Rate
   int8 width ;
   int8 loopcnt_valu ;
   int8 loopcnt ;
#INT_RTCC
void tick_interrupt(void);
main()
width = 10;
loopcnt_valu = 30; // initial valu
loopcnt = loopcnt_valu ;
   set_tris_A(0b000001);   // configure input output
   set_tris_B(0b11111111);
   set_tris_C(0b10100000);
   set_tris_D(0b00010000);
   set_tris_E(0b000);
setup_timer_0(RTCC_INTERNAL|RTCC_8_BIT|RTCC_DIV_4);
      enable_interrupts (INT_TIMER0);
      enable_interrupts(global);
      set_timer0(6);
   if (input(Speed_1)==0 )
          loopcnt_valu = 20 ;
   if (input(Speed_2)==0 )
          loopcnt_valu = 40 ;
#INT_RTCC
static int8 loop = LOOPCNT;
static int8 pulse;
if(--loop == 0)
   loop = LOOPCNT;
   pulse = width;
if(pulse)
   output_high(Stepper_pulse_out);
   pulse--;
   output_low(Stepper_pulse_out);
[b]
alan
PostPosted: Tue Nov 17, 2015 7:22 am     Reply with quote
LOOPCNT is zero. Or did you want to use loopcnt_valu instead.
Regards
freedom
PostPosted: Tue Nov 17, 2015 8:04 am     Reply with quote
I want to asign the value of LOOPCNT by loopcnt_valu which is generated in while loop if statement
          loopcnt_valu = 20 ;
wangine
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Tue Nov 17, 2015 12:55 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=54585
try it
PostPosted: Tue Nov 17, 2015 8:13 pm     Reply with quote
The main problem is that you are setting a variable called 'loopcnt_valu'
but you don't use it anywhere else. It's not used in the RTCC routine.
The problem is the lines in bold below:
loopcnt_valu = 20 ;
loopcnt_valu = 40 ;
To fix it, remove the '_valu' at the end, as shown below.
          loopcnt = 20 ;
          loopcnt = 40 ;
There are a few other problems in your program such as:
1. Using the XT fuse with a 20 MHz crystal ? It won't work anywhere
except in Proteus. Real hardware needs the HS fuse.
2. CCS is not case sensitive by default. This is a strategy mistake in
my opinion. You should not use LOOPCNT and loopcnt in the same
program. It works in CCS, but it's just not good coding style.
3. The compiler warns you about main() and while(1). You can fix these
warnings as shown in bold below:
freedom
PostPosted: Tue Nov 17, 2015 11:56 pm     Reply with quote
Thank Everyone. Now I understand my fault.
Now it is working
