Eugeneo
| Pic24 can't reach low power spec. |
Posted: Sat Nov 14, 2015 5:46 pm |
Hi all,
Been trying to setup this Pic (24FJ128GC006) to sip as little power as possible. When the mcu enters sleep without RAM retention, I measure 75 uA - which is fine as a baseline. When it is running at 32K LPRC, it consumes 330 uA. Based on the datasheet, it should be closer to +80uA from my baseline.
All the Peripheral Module Disables (PMD) have been set - this helped a little but there is still about 175uA that haven't been accounted for.
I've tried many things with no success. Any help is appreciated.
Here's the code:
#include <24FJ128GC006.h>
#use delay(internal = 32767)
#FUSES NOJTAG //JTAG disabled
#FUSES ICSP1 //ICD uses PGC1/PGD1 pins
#FUSES NOIESO //No Internal External Switch Over mode enabled
#fuses NODSWDT //Deep Sleep Watchdog Timer disabled
#fuses OSCIO //OSC2 is general purpose output
#fuses NORTCBAT //RTC operation is discontinued in VBAT
#fuses NOPR //Pimary oscillator disabled
#fuses LPRC //Internal low power RC Oscillator
#build(STACK = 0x400)
#define LED1 PIN_D10 // upper right output
#define led_on output_low(led1)
#define led_off output_high(led1)
#define TEST_FLASH {led_on; delay_ms(200); led_off; delay_ms(200);}
#define stop do{}while(1)
#define flash do{test_flash;}while(1)
* Main app
void Main(void) {
output_low(PIN_B7); // PGM
output_low(PIN_B6); // CLK
output_low(PIN_B5);
output_low(PIN_B4);
output_low(PIN_B3);
output_low(PIN_B2);
output_low(PIN_B1);
output_low(PIN_B0);
output_low(PIN_B12);
output_low(PIN_B13);
output_low(PIN_B14);
output_low(PIN_B15);
output_low(PIN_G9);
output_low(PIN_G8);
output_low(PIN_G7);
output_low(PIN_G6);
output_low(PIN_G2);
output_low(PIN_G3);
output_low(PIN_E0);
output_low(PIN_E1);
output_low(PIN_E2);
output_low(PIN_E3);
output_low(PIN_E4);
output_low(PIN_E5);
output_low(PIN_E6);
output_low(PIN_E7);
output_low(PIN_F3);
output_low(PIN_F4); // SP2
output_low(PIN_F5); // SP2
output_low(PIN_D0);
output_low(PIN_D1); // SP1
output_low(PIN_D2); // SP1
output_low(PIN_D3);
output_low(PIN_D4);
output_low(PIN_D5);
output_low(PIN_D6);
output_low(PIN_D7);
output_low(PIN_D8);
output_low(PIN_D9);
//output_low(PIN_D10); // LED
output_low(PIN_D11);
output_float(PIN_C13);
output_float(PIN_C14);
#byte PMD1 = getenv("byte:PMD1")
#byte PMD2 = getenv("byte:PMD2")
#byte PMD3 = getenv("byte:PMD3")
#byte PMD4 = getenv("byte:PMD4")
#byte PMD5 = getenv("byte:PMD5")
#byte PMD6 = getenv("byte:PMD6")
#byte PMD7 = getenv("byte:PMD7")
PMD1 = 0xFF;
PMD2 = 0xFF;
PMD3 = 0xFF;
PMD4 = 0xFF;
PMD5 = 0xFF;
PMD6 = 0xFF;
PMD7 = 0xFF;
do
delay_ms(2000);
TEST_FLASH
} while(1);
Posted: Sun Nov 15, 2015 9:50 am |
| You are running off the FRC oscillator, not the LPRC oscillator..... |
Eugeneo
Posted: Sun Nov 15, 2015 5:33 pm |
Thanks Ttelmah,
If I insert this line at the beginning, the current draw is 224 uA
setup_oscillator(OSC_RC, 0);
And this one uses the FRC and draws 500 uA
setup_oscillator(OSC_INTERNAL, 32768);
Still on the high side. Time to strip down the hardware to see where the extra is. |
Eugeneo
Posted: Sun Nov 15, 2015 6:03 pm |
All the hardware is removed. The unit now draws a total of 13 uA in deep sleep mode with the LPRC waking the unit up every second. When the MCU wakes up, it draws 284 uA. Does anybody know how I can test if it is running off the LPRC?
Thanks for the help.
** EDIT: If I bring the source voltage from 3.3v to 2.0v, the unit still runs and draws 72 uA. Interestingly enough, the datasheet shows very little linear change between 3.3v and 2.0v (Param# DC31). Is there any additional on chip regulators that need to be disabled via bit? |
Posted: Mon Nov 16, 2015 2:29 am |
I know on some compiler versions/chips, CCS 'silently' switches oscillators based on the clock speed you select. The LPRC, is specified as 31KHz. On these you get the different oscillators, by selecting:
#use delay(internal = 31000) //LPRC
or
#use delay(internal = 32500) //FRC
So worth trying specifying the frequency for LPRC.
The easiest way to 'know' what is selected, is simply look at the end of the .lst file and how the fuses are set.
Question. How is Vbus3v3 connected? This needs to connect to Vdd. Quote from data sheet:
"Connecting VBUS3V3 to VDD is highly recommended, as floating this input can cause increased IPD currents.".
Could be your problem. |
Eugeneo
Posted: Mon Nov 16, 2015 11:35 am |
I found this link. It allows you to modify the clock source input with the required ASM unlock sequence. It will allow you to manually adjust and verify the clock sources. Note: Please be aware, the multiplier entry doesn't work on this specific Pic.
//http://www.ccsinfo.com/forum/viewtopic.php?t=53502&highlight=pic24+setuposcillator2
As you said, based on the values, the compiler decides to select between LPRC, LPFRC, FRC.
setup_oscillator(OSC_INTERNAL, 31250);
setup_oscillator(OSC_INTERNAL, 31000);
setup_oscillator(OSC_INTERNAL, 500000);
setup_oscillator(OSC_INTERNAL, 8000000, 4);
Thanks for also pointing out the VBUS3V3 recommendation! I'm going to try this. |
