Tiny Bootloader modifed firmware
rovtec
PostPosted: Mon Oct 05, 2015 9:57 am     Reply with quote
Does anyone in the forum have experience of using the Tiny Bootloader when the firmware has been modified out to maximum of 264 bytes and allocation in the ini file is set to 132 words ? Mine was stable for over 6 months but has stopped working after many months. I can't see a problem except it won't write flash and times out every time it doesn't write byte 1 as far as I can see. Any help much appreciated. Tiny Bootloader ver 1.98
dara
dara hayes
PostPosted: Mon Oct 05, 2015 12:38 pm     Reply with quote
This is not CCS related. Why don't you switch to the SourceForge version
of the Tiny Bootloader. It's currently supported. It has a forum. Try it.
It's based on the original Tiny Bootloader.
http://sourceforge.net/projects/tinypicbootload/
They will be able to answer your questions better than we will.
