PIC 18 - ADC Setup
Nikel
PIC 18 - ADC Setup
PostPosted: Tue Jul 28, 2015 10:59 am     Reply with quote
Hi, I'm working on a project on MPLAB 8.92 using a PIC18F46K22 and I'm having an issue with my ADC setup. I had this project working on another computer but when I tried to compile it on mine, it threw an "expecting a close paren" error on this line:
setup_adc_ports(sAN0|sAN1, VSS_FVR);
I'm assuming the function prototype differs from the one in the other computer's CCS since this will compile and work:
setup_adc_ports(sAN0|sAN1 | VSS_FVR);
However I'm not sure this would be correct. The OR operations with those parameters don't overlap, but I don't know if setup_adc_ports() will even take VSS_FVR into consideration and my hardware is now overheating (ADC is being used to control a microstepping motor).
How can I properly setup the ADC module including VSS_FVR?
Aditionally, my CCS won't recognize #fuses CCP2C0, which I changed for CCP2C1 following the microcontroller datasheet... is that correct? Why is CCP2C0 undefined in my CCS but not on the other computer? What should I be updating on my computer to have the same defines/functions/etcs as the other one?
Thank you for any help!
Nic
PostPosted: Tue Jul 28, 2015 1:21 pm     Reply with quote
setup_adc_ports(THIS, WTF? ); per the CCS manual counts
as TWO arguments
and the CCS manual shows one argument with NO commas -
just the one argument with ORing
wishing the compiler worked to your taste won't get it done.
the comma is not expected so of course an error as you see.
what compiler version do you have?
and as to : CCP2C0 IT IS INVALID on TWO counts
1) you can't arbitrarily make up fuses for CCS
AND
2) the part could not provide the function to C0 anyway.
READ the datasheet pinout to see why
only C1 works in the hardware.......
adjust your design to make it so and use the supported #fuse
you are simply wrong twice over
Nikel
PostPosted: Tue Jul 28, 2015 2:03 pm     Reply with quote
Well, that's exactly what I'm trying to clarify! Maybe I explained it poorly... I'm working on a project a coworker wrote. He quit, I got more work. So now I'm setting up my computer and when I compile the project, I get these errors.
Reading datasheets and manuals I haven't found a setup_adc_ports() with 2 arguments, yet a call to such function will compile on my coworker's machine!! And so will a declaration of #fuses with CCP2C0!! I'm not wishing for anything, I'm only stating that I found those problems, they will compile on another machine, they (naturally) won't on mine, and I'm trying to understand the why's of the situation. Probably some weird library he installed? Eventually, I don't care about the why's, but I do need to know how to replace those declarations with a correct call.
So, will a call to setup_adc_ports() with only 1 argument (as it should be!) with an OR including VSS_FVR work as I expect it to? If not, how do I set that up? (As I said, ADC value is used as input for a PID that regulates current on a Motor, and I now notice overheating, so I suspect I have to do something differently.)
Finally, would CCP2C1 be the proper replacement for what I had originally? For what I have read, it is, but just wanted to check and be sure.
Thanks for your answer!
Nic
PostPosted: Tue Jul 28, 2015 2:12 pm     Reply with quote
Post your CCS compiler version. It's a 4-digit number given at the top
of the .LST file after a successful compilation. The .LST file will be in
your project directory. Example of version numbers:
http://www.ccsinfo.com/devices.php?page=versioninfo
Nikel
PostPosted: Tue Jul 28, 2015 2:24 pm     Reply with quote
Sorry, forgot about that.
Mine is "CCS PCH C Compiler, Version 4.109, 38426" (from my last Main.lst build)
Nic
PostPosted: Wed Jul 29, 2015 2:18 am     Reply with quote
Optional dual variable setup of the ADC, appeared with V5 compilers. These have:
_bif void setup_adc_ports(int32 pins);
_bif void setup_adc_ports(int32 pins, int32 reference);
//and in the defines:
// Optional Second argument:
With the second form allowing the reference to be specified as a second variable.
So the code you have is for a V5 compiler.
Then CCP2C0. This is a mis-spelling on some of the recent compilers. It correctly sets CCP2C1....
Nikel
PostPosted: Wed Jul 29, 2015 2:18 pm     Reply with quote
Well... that would explain it! Thank you so much for that!
So what would the 4.x version of
for setting the reference be?
As I said on my first post, I've tried with
but it looks like it's not working, since I'm not getting the expected behaviour (which I do get if I compile and program on the other computer)
Nic
