isd4003 driver and software spi
freedom
PostPosted: Thu Jul 16, 2015 1:00 pm     Reply with quote
hello all
I want to use ccs supplied isd4003.c driver to record and playback.
I want to interface isd4003 chip with 16f877a through software SPI.
I use compiler version 4.124
as example
#include <16F877A.h>
#fuses HS,WDT,NOPROTECT,NOLVP
#use spi(Master, Mode=0, DI=PIN_A1, DO=PIN_A2, CLK=PIN_A4, ENABLE=PIN_A5, BITS=8, MSB_FIRST)
though this driver have already
#ifndef ISD4003_SELECT
#define ISD4003_RAC     PIN_C1
#define ISD4003_SELECT  PIN_C2
#define ISD4003_CLK     PIN_C3
#define ISD4003_MISO    PIN_C4
#define ISD4003_MOSI    PIN_C5
what will be the real #use spi statement to drive isd4003 ?
//this function is used to record a message on the chip
void record_message(long address)  {
What will be the address ? A1 , A2..... or other ?
How many message can I record ?
suppose I have Isd4002 chip with 120 second duration.
Message 1 - 10 sec duration
Message 2 - 20 sec duration
Message 3 - 5 sec duration
Message 4 - 5 sec duration
Message 5 - 30 sec duration
Message 6 - 10 sec duration
Message 7 - 40 sec duration
total : 7 message and 120 sec duration
already I have seen the example Ex_voice.c but this is slight understandable.
as I want to record voice via microphone and playback if any error occurred, so I need an example on this issue.
PostPosted: Thu Jul 16, 2015 4:13 pm     Reply with quote
Post a list of your hardware connections between the PIC and the isd4003.
Post a table, similar to the one below, except fill it in with the correct pin
numbers for your board, and also put in lines for CLK, SELECT, and RAC.
Pic pin    isd4003 pin
PIN_A1       3
PIN_A2       2
Check the connections with an ohmmeter to verify them before posting.
luckyluke
PostPosted: Thu Jul 16, 2015 6:11 pm     Reply with quote
is it still producing?
driver use software spi so you don't have to use spi
you can connect mcu to isd4003 with any pin you want (a4?)
you have to capture addresses
for example start with address 0
first record
record_message(0);(make button to start)
//10seconds record then finish with
add=stop_message();
(make button to stop or use a delay)
add (long) is the first records last memory address add it 1 for next record
start second record with address add
record_message(add+1);
//20seconds record then finish with
add=stop_message();
.... an so other records
isd4003 is works with 3.3V be careful
PostPosted: Thu Jul 16, 2015 9:17 pm     Reply with quote
While we're waiting for your reply,
1. There is no need for the Watchdog Timer to be enabled in a program
where you are developing a driver. Add it later to the final program
when you're done.
2. Pin A4 on the 16F877A is open-drain when used as an output pin.
It requires an external pull-up resistor, and is a poor choice as the pin
for CLK, since your spi clock should have fast, clean edges. The pullup
will give you a slow rise time on pin A4, compared to using a normal i/o pin.
3. The isd4003 requires that the LSB comes first, not the MSB. This is
shown in the isd4003 data sheet, in Section 8: Timing Diagrams. The
first bit to come in or to leave the master, is the LSB. Also, in the CCS
example file, isd4003.c, they have a line of code that outputs the lsb first:
for(i=0;i<16;i++)
{ // shift LSB first so it latches on rising edge
output_bit(ISD4003_MOSI, shift_right(&value,2,0));
delay_us(50);
output_high(ISD4003_CLK);
delay_us(100);
output_low(ISD4003_CLK);
delay_us(50);
Which brings up another question. You said here,
That is exactly what the CCS isd4003.c driver file does. It uses software
SPI. Look at the code above. It's a software loop that outputs 16 bits
and toggles the SPI clock with pin i/o functions. It's using software SPI.
The CCS driver doesn't need the #use spi() statement. The driver was
written before the #use spi() library was created. It does software SPI
with C code.
freedom
PostPosted: Fri Jul 17, 2015 4:33 am     Reply with quote
now SPI configuration for the ISD4003.c driver
#define ISD4003_RAC PIN_D2
#define ISD4003_SELECT PIN_D3
#define ISD4003_CLK PIN_C4
#define ISD4003_MISO PIN_C5
#define ISD4003_MOSI PIN_C6
In ex_voice example text to voice/speech.
Please give me an example to record via microphone and playback via speaker using the ISD4003.c driver
PostPosted: Fri Jul 17, 2015 3:41 pm     Reply with quote
I don't have a chip to test, but using ex_voice.c as a base, I came up
with this minimal test program:
#fuses HS, NOWDT, BROWNOUT, PUT, NOLVP
#use delay(clock=20M)
#define RED_LED_PIN  PIN_B0
#include <isd4003.c>
int16 message_address = 0;
init_isd();
output_high(RED_LED_PIN);  // Turn on LED to show we are recording
record_message(message_address);   // Record message at specified address
delay_ms(10000);   // Record for 10 seconds
stop_message();
output_low(RED_LED_PIN);  // Recording done so turn off the LED
delay_ms(2000);   // Wait 2 seconds before playback
play_message(message_address);  // Then playback what we just recorded
while(TRUE);
freedom
PostPosted: Sat Jul 18, 2015 4:47 am     Reply with quote
thanks PCM Programmer
does this statement is necessary for this example ?
Ok I am going to test it
