pic communication using uart (PIC16F628)
kodomo32
PostPosted: Fri Jul 10, 2015 7:35 pm     Reply with quote
Hello
I want to connect 2 device(Computer and Printer) with max232
Computer (Baud rate:2400) =>Micro controller(PIC16F628)=>Printer(Baud rate:9600)
but they have different baud rate, I'm trying to test code but it's not work.
Cloud you help me,please
#include <16F628A.H>
#fuses  HS, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock = 4000000)
#use RS232(STREAM=gps,BAUD=2400, RCV=PIN_B1)
#use RS232(STREAM=dbg,BAUD=9600, XMIT=PIN_B2)
main(void)
char ch;
  ch = fgetc(gps);
  fputc( ch, dbg);
PostPosted: Fri Jul 10, 2015 8:25 pm     Reply with quote
The 16F628A has only one hardware UART and it can only have one
baudrate for both transmit and receive.
You also can't split the hardware UART into two pieces for Tx and Rx.
The compiler will create two software uarts with your two #use
rs232 statements.
Then why are the streams called dbg (debug) and gps ?
PostPosted: Sat Jul 11, 2015 4:54 am     Reply with quote
What you could do, is to configure the hardware UART to use both pins, at 2400bps (since this is the 'receiving' device, and this is therefore much easier to do with the hardware), then also setup a software UART for transmit on the output pin only, then disable the TX side of the UART in the code before using the transmit. A search here will find lots of threads telling you how to disable just one half of the UART.
Awkward, but should work fine.
