bootloader and reset_cpu( ) [Solved]
Linuxbuilders
PostPosted: Fri Jun 12, 2015 11:29 pm     Reply with quote
Hey,
Quite interesting thing:
1. I have bootloader
2. I have extended its size and let it read rom at location 0x00
3. If I find there 0 it means that network did request to boot in bootloader
4. I execute reset_cpu()
Problem which I have just found is that reset CPU jumps to location 0 offset by bootloader which is program memory not a bootloader.
How do I force total re-power (like hard reset) so the unit does restart in bootloader?
Thnx
Help "d" others and then you shell receive some help from "d" others.
Linuxbuilders
PostPosted: Sat Jun 13, 2015 12:48 am     Reply with quote
I am not quite sure why when I execute goto_address(0x00040);
somehow it ignores the instruction to read my ROM and jumps directly into the program itself.
But when I do hard reset then it works correctly.
Below is a map of memory:
               Filename:  main.lst
               ROM used:   864 bytes (1%)
                           Largest free fragment is 64172
               RAM used:   73 (2%) at main() level
                           131 (3%) worst case
               Stack used: 5 locations (4 in main + 1 for interrupts)
               Stack size: 31
Bootloader.c code removed.
Reason: CCS forum rule #10
10. Don't post the CCS example code or drivers.
http://www.ccsinfo.com/forum/viewtopic.php?t=26245
- Forum Moderator
Linuxbuilders
PostPosted: Sat Jun 13, 2015 1:19 am     Reply with quote
Solved, never mind - had a bug in main software, boot loader is ok.
I leave the code if anybody would be looking for something like that.
Linuxbuilders
PostPosted: Sun Jun 14, 2015 1:33 am     Reply with quote
- Forum Moderator
Please clear "internet" of your code too, GOOGLE it by file name, you may be surprised what you can find there.
However I am sorry, I could trim it a bit down. I agree here.
