I can't get the time with internal RTCC with PIC18F66J94
yabo104
PostPosted: Tue Jun 02, 2015 5:38 pm     Reply with quote
Hello, I'm using internal RTC in my pic18F66J94 but when i use rtc_read(&read_clock); i get the same data which i already configured the clock. I have a 32.768 KHz crystal in the SOSC pins RC0 and RC1, with 15pf ceramic capacitors. The Vbat pin has a 3v CR2032 Battery installed, but the internal RTC doesn't start.
Anybody can help me?
http://www.ccsinfo.com/forum/viewtopic.php?t=46528
CCS compiler is 5.009
This is the configuration fuses in main.h:
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NOCKSNOFSM               //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES VREGSLEEP_SW             //Ultra low-power regulator is enabled
#FUSES DSWDTOSC_SOSC
#use delay(internal = 8000000)
And this is the code:
void main (){
   setup_lcd(LCD_DISABLED);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_4);         //131 ms overflow
    setup_rtc(RTC_ENABLE , 0);
    wizardTempTime.tm_year = 15;
    wizardTempTime.tm_mon = 6;
    wizardTempTime.tm_mday = 2;
    wizardTempTime.tm_wday = 2;
    wizardTempTime.tm_hour = 17;
    wizardTempTime.tm_min = 58;
    wizardTempTime.tm_sec = 2;
    rtc_write(&wizardTempTime);
   while(true){
       rtc_read(&read_clock);        //reads clock value from RTCC
            fprintf(UART1, "\r%02u/%02u/20%02u %02u:%02u:%02u \n\r",read_clock.tm_mon,read_clock.tm_mday,read_clock.tm_year,read_clock.tm_hour,read_clock.tm_min,read_clock.tm_sec);
