about kbd
dear11235813
about kbd
PostPosted: Tue Oct 07, 2008 10:44 pm     Reply with quote
from this code
//// KBDD.C ////
//// Generic keypad scan driver ////
//// kbd_init() Must be called before any other function. ////
//// c = kbd_getc(c) Will return a key value if pressed or /0 if not ////
//// This function should be called frequently so as ////
//// not to miss a key press. ////
//// (C) Copyright 1996,2003 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
//// Derivative programs created using this software in object code ////
//// form are not restricted in any way. ////
////////////////// The following defines the keypad layout on port D
// Un-comment the following define to use port B
// #define use_portb_kbd TRUE
// Make sure the port used has pull-up resistors (or the LCD) on
// the column pins
#if defined(__PCH__)
//#if defined use_portb_kbd
#byte kbd = 0xF81 // This puts the entire structure
#else
#byte kbd = 0xF83// This puts the entire structure
#else
//#byte kbd = 6 // on to port B (at address 6)
//#else
#byte kbd = 8 // on to port D (at address 8)
// #define set_tris_kbd(x) set_tris_b(x)
//#else
#define set_tris_kbd(x) set_tris_d(x)
//#endif
#include <18f4550.h>
#fuses NOLVP,HS,.....
//Keypad connection: (for example column 0 is B2)
// Bx:
/*#ifdef blue_keypad ///////////////////////////////////// For the blue keypad
#define COL0 (1 << 2)
#define COL1 (1 << 3)
#define COL2 (1 << 6)
#define ROW0 (1 << 4)
#define ROW1 (1 << 7)
#define ROW2 (1 << 1)
#define ROW3 (1 << 5)
//#else ////////////////////////////////////////////////// For the black keypad
#define COL0 (1 << 5)
#define COL1 (1 << 6)
#define COL2 (1 << 7)
#define COL3 (1 << 8)
#define ROW0 (1 << 1)
#define ROW1 (1 << 2)
#define ROW2 (1 << 3)
#define ROW3 (1 << 4)
#define ALL_ROWS (ROW0|ROW1|ROW2|ROW3)
#define ALL_PINS (ALL_ROWS|COL0|COL1|COL2|COL3)
// Keypad layout:
int const KEYS[4][4] =
{{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}};
#define KBD_DEBOUNCE_FACTOR 33
void kbd_init()
//set_tris_b(0xF0);
//output_b(0xF0);
port_b_pullups(true);
short int ROW_HIGH()
if(input (ROW0) || input (ROW1) || input (ROW2) || input (ROW3))
return (1);
return (0);
char kbd_getc()
static byte kbd_call_count;
static short int kbd_down;
static char last_key;
static byte col;
byte kchar;
byte row;
kchar='\0';
if(++kbd_call_count>KBD_DEBOUNCE_FACTOR)
switch (col)
case 0:
output_high(col0);
output_low(col1);
output_low(col2);
output_low(col3);
case 1:
output_low(col0);
output_high(col1);
output_low(col2);
output_low(col3);
case 2:
output_low(col0);
output_low(col1);
output_high(col2);
output_low(col3);
case 3:
output_low(col0);
output_low(col1);
output_low(col2);
output_high(col3);
if(kbd_down)
if(!ROW_HIGH())
kbd_down=false;
kchar=last_key;
last_key='\0';
if(ROW_HIGH())
if(input (row0))
row=0;
else if(input (row1))
row=1;
else if(input (row2))
row=2;
else if(input (row3))
row=3;
last_key =KEYS[row][col];
kbd_down = true;
++col;
if(col==4)
col=0;
kbd_call_count=0;
return(kchar);
void main(){
unsigned char k;
k=kbd_getc();
if(k!=0)
if(k=='*')
output_high(PIN_B0);
output_low(PIN_B0);
if i want to keep value from this code for equation such as
55 (kg) = X for (X * X)/8
but this code can keep just last one
may be i do something wrong ?
thanks for you help..
11235813
PostPosted: Tue Oct 07, 2008 11:33 pm     Reply with quote
It looks like you got that code from this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=28022&start=14
Then you modified it a little, and tacked the CCS copyright message
onto the front of it. This makes it look like its a driver file that comes
with the CCS compiler, but that's not true.
PostPosted: Wed Oct 08, 2008 5:40 pm     Reply with quote
1. Put the incoming characters from the keypad into an array.
Make sure you don't write beyond the end of the array.
2. When the user presses the '#' key, this marks the end of the data.
Write a 0x00 to the end of the data in the array, when you get this key.
This will make the ASCII numbers into a string.
3. Now use the atoi() or atol() function to convert the numeric string
in the array into an integer. Those functions are in this file. You need
to #include it in your program:
c:\program files\picc\drivers\stdlib.h
