Two different devices on one UART interface
stoyanoff
PostPosted: Fri May 01, 2015 7:46 am     Reply with quote
Greetings! Is there a way to connect 2 different devices on single UART interface of a microcontroller? For example 1 RS485 transiever and something else with enable pin?
Thanks!
PostPosted: Fri May 01, 2015 8:12 am     Reply with quote
Yes. What you describe can be made to work. Obviously both devices need to float their data output line (the line feeding the PIC's RX), when they are disabled, and the line really should have a pull-up, to cover the instant when neither device is driving it.
You can even drive multiple TTL async links, using something like a 4-1 mux/demux, and routing the two lines through these.
However it is dependant on all the devices involved being 'question/reply' type configurations, so they only send data when _asked_.
asmboy
PostPosted: Fri May 01, 2015 8:37 am     Reply with quote
Another way to do this is to send the PIC TX out to multiple TTL level devices through a 220 ohm build out resistor to each.
typically you can feed 4 virtual ports this way, quite handily.
the returned TX lines FROM the 4 interfaces( -> PIC RX pin) are best combined using a 4 input positive logic AND gate ( 3/4 of a 74HC08 interconnected) with a 10k ohm pull up resistor to +5 v ( or 3.3v) on each input to allow for potential 3 state operation.
Mr. T's caveat applies: You have to be sure they don't all TALK back at the same time -
PostPosted: Fri May 01, 2015 3:19 pm     Reply with quote
Yes, it can be done, as pointed out however.....by the time you R&D the '2-into-1 UART' subsystem you could have bought a LOT of PICs that have 2 UARTs in them !! I can buy a lot of PICs with R&D costing $100/hr.
It's one of those 'penny wise-pound foolish' things. You will waste a LOT of time trying to 'bodge' it,maybe blow 2-3 PCB designs, rewire/redo 2-3 times, frankly it's just not worth the time and effort.
I tend to 'overkill' the PIC position, usually an 18F46K22. Tons of memory, I/O, and of course TWO hardware UARTS. Remember clients always 'need' an extra LED or 'just a little bit' more code.....
Jay
