JAM2014
Passing a string to a subroutine and parsing it.... |
Posted: Fri May 01, 2015 1:09 pm |
Hi All,
I want to send a string to a subroutine like this:
Display_4D_Text("Hello World");
and then parse it character by character to send the data to a serially connected LCD module. So far, I have got it working.....
void Display_4D_Text(Char InString)
int8 iIndex = 0;
// Here we send the character string command....
fputc(0x00,LCD_Display);
fputc(0x06,LCD_Display);
for ( iIndex=0 ; iIndex<strlen(InString) ; iIndex++ )
fputc(InString[iIndex],LCD_Display);
//Here we tell the display 'that's it...'
Thanks,
Jack |
Posted: Fri May 01, 2015 1:55 pm |
Quote: | So far, I have got it working..... |
I didn't see that it was working. Your code required a couple changes
to make it work, as shown in bold below.
Quote: |
#include <18F4520.h>
#device PASS_STRINGS=IN_RAM
#fuses INTRC_IO, BROWNOUT, PUT, NOWDT
#use delay(clock=4M)
#use rs232(baud=9600, UART1, ERRORS, stream=LCD_Display)
#include <string.h>
void Display_4D_Text(Char *InString)
int8 i;
for(i=0; i < strlen(InString); i++)
fputc(InString[i], LCD_Display);
while(TRUE);
I cut out that parts of your code that I didn't need for the test program,
and I simplified your index variable name. |
JAM2014
Posted: Fri May 01, 2015 2:19 pm |
Sorry, that should have read:
Quote: |
So far, I haven't got it working.....
I had tried adding the '*' previously, and figured it should have worked fine like that. What I missed was this:
It's now working like a champ!
Thanks!!
Jack |
