Compiler errors with TCP/IP stack
adilrs
PostPosted: Tue Apr 28, 2015 12:58 pm     Reply with quote
Hello everybody ! I'm new here so I apologize if you make any obvious question for y'all ! However I am suffering more than three weeks with a domesticated design automation !
I have a development board with 18f97j60
http://www.ebay.com/itm/PIC-Ethernet-Development-Board-PIC-WEB-EK-for-PIC18F97J60-/271848230627?pt=LH_DefaultDomain_0&hash=item3f4b6acee3
It comes with examples in MPLAB, however I am more used to the CCS to play engineer.
In MPLAB by examples using TCP -STACK, has web server where the page do the Upload to EEPROM.
I managed to serve the page with Getting the answers with CGI by the Wizard of CCS, however when I enable
#define STACK_USE_MPFS2
#define MPFS_USE_EEPROM
begin errors and can not compile more.
For example:
MPFS MPFSOpenROM(ROM BYTE* file)
   BYTE nameRAM[MAX_FILE_NAME_LEN+1];
   memcpypgm2ram(nameRAM, (ROM void*)file, strlenpgm((ROM char*)file));
   nameRAM[strlenpgm((ROM char*)file)] = '\0';
   return MPFSOpen([b]nameRAM[/b]);
MPFS.c" Line 347(20,27): A numeric expression must appear here
And this is just the beginning of errors.
I walked around this by changing the declaration for
   BYTE * nameRAM;
more ai is an error cascade later!
Would have some simpler mode to enable the use EEPROM
to store my files?
Sorry for the bad English, I speak only Portuguese, translated by google rs
PostPosted: Tue Apr 28, 2015 1:52 pm     Reply with quote
Would love to but I do NOT have a Microsoft ONEDRIVE account. It's bad enough they 'sniff' my PC once a day...so I refuse to get into their 'cloud'...
I have to assume the hardware does exist and this is NOT a Proteus simulation? If so , please post schematic, but not on one drive.....
Also IF you put a vaild user ID in (instead of grabbing off the net) does your program function ?
Jay
PostPosted: Wed Apr 29, 2015 8:45 am     Reply with quote
I think you're trying to compile the Microchip Stack using the CCS
compiler. That won't work. You need to use a Microchip compiler,
such as XC8.
http://www.microchip.com/pagehandler/en_us/devtools/mplabxc/
Also get support from the Microchip forum.
adilrs
PostPosted: Wed Apr 29, 2015 11:48 am     Reply with quote
such as XC8.
Thanks for the tip!
As in the CCS Wizard own it uses the Stack, thought to have a more easy solution to the case!
What I do not want is to have to adapt to another compiler :(
grateful
Gabriel
PostPosted: Thu Apr 30, 2015 1:19 pm     Reply with quote
i have the Non-Chinese version of your board: https://www.olimex.com/Products/PIC/Development/PIC-MAXI-WEB/
I have not been able to get this thing online with the CCS stack.
I did get it to work with the supplied Olimex examples using the Microchip compiler... which i didnt like at all.
I did get it to work with modbus TCP/IP but only because CCS gave me a version of the stack that worked with the examples provided.
other than that... its collecting dust.
I have since purchased an ESP8*** 5 dolar IOT thingy... and will try to get that to work, and if that fails.... no IOT for me.
G.
CCS PCM 5.078 & CCS PCH 5.093
