I am trying to implement cycle by cycle current limiting on an interleaved boost circuit. This makes use of PWM channel 1 and channel 2.
I am using the internal comparators #2 and #3 to measure the inductor current and when it exceeds the limit the comparator is mapped to the PWM fault pin and turns off the PWM output (cycle by cycle). I can get this to work on one or the other channel at a time but not both channels simultaneously.
Does anyone have any experience in this?
Maybe the part can not do this?
Thanks,
Dave
Posted: Fri May 01, 2015 12:35 pm
Help if you gave us the right part number....
Also compiler version number.
Show some example setup code. You definitely can set separate fault limiting on most DsPIC PWM's.
