software PWM using PIC16F877A
balboa
PostPosted: Mon Mar 30, 2015 7:42 am     Reply with quote
hey there :
I need 4 PWM in my project and I've been wondering how can I do this using my PIC16F877A I've read about software PWM & couldn't actually get it
I need an example to show me how to do it
help pls !!
PostPosted: Mon Mar 30, 2015 7:55 am     Reply with quote
It depends totally on a number of things:
How fast your chip is running.
How fast you need the PWM.
What accuracy you need (number of different pulse widths).
In the code library, there is an example for radio control servos. Low speed, low resolution. If you need a high PWM frequency (>1KHz perhaps), and any sort of reasonable resolution (>16 step sizes perhaps), then unless your PIC is running very fast indeed, you are not going to get good results.
There is also an example doing exactly what you describe:
<http://www.ccsinfo.com/forum/viewtopic.php?t=50069>
However the comments also reflect the problems this has. Four channels, 256 levels each, result potentially flicker on the LED's involved.
Basic approach is to use a fast 'tick' interrupt, and in this decide for each signal when it needs to go on/off.
balboa
PostPosted: Tue Mar 31, 2015 9:51 am     Reply with quote
my chip is running on 20 MHz
the PWM fast is 50 Hz
the duty cycle varies between 1400 to 2400 us
PostPosted: Tue Mar 31, 2015 10:23 am     Reply with quote
Your requirements look like it's for RC servos.
Depending on what else the PIC has to do even using delay_us(xxx) might work for you. As others have said there is code available either in this forum or the 'code library' forum as well as a TON of code 'on the Web'.
hth
jay
Mike Walne
PostPosted: Tue Mar 31, 2015 10:28 am     Reply with quote
How many discrete steps do you need between 1400 & 2400us?
Like jay says, it looks like it's been done here before.
Do a search.
Mike
