Jhonny
| Output_bit , nothing |
Posted: Fri Mar 27, 2015 8:42 am |
Hi!
I use this code:
#include <12F683.h>
#device ADC=16
#FUSES noPUT //Power Up Timer
#FUSES PROTECT //Code protected from reads
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#use delay(internal=4000000)
int16 i;
unsigned int16 data=0b0101010101010101;
for(i=1;i<=16;++i)
output_bit(PIN_A5, shift_left(data,2,1));
delay_ms(30);
i=0;
}//end while
}//end main
The output signal is continuous H level. What is wrong? (I'm going crazy ...)  |
Posted: Fri Mar 27, 2015 9:19 am |
After 480mSec, it will be.
You are shifting a 1 in every time, so after 16shifts, data will contain all 1's....
unsigned int16 temp;
temp=data;
for(i=0;i<16;++i)
output_bit(PIN_A5, shift_left(&temp,2,1));
delay_ms(30);
}//end while
}//end main
This way the value to shift is reloaded every loop.
Remember also 'shift_left' requires an _address_. Note the '&'.
Jhonny
Posted: Fri Mar 27, 2015 10:13 am |
Okay, I begin to understand. Thank you very much, it seems to me that we have to work well.  |
