ldalcol
CRC16 CCITT |
Posted: Mon Mar 16, 2015 5:27 pm |
Hi, I'm a new in C program, but I have a problem with make correctly CRC16. Sorry if my problem is very soft, but like I said, I'm starting in C.
#include <ComSerial_crc.h>
#include <math.h>
#include <string.h>
#include <stdio.h>
#INCLUDE <stdlib.h>
#INCLUDE <input.c>
Code from crc.c deleted: generate_16bit_crc()
Reason: Forum rule #10
10. Don't post the CCS example code or drivers
http://www.ccsinfo.com/forum/viewtopic.php?t=26245
- Forum Moderator
//int x;
unsigned char x[7]; //assim o display funciona
int16 i, j,tam, chk, retchk;
set_tris_d(0b00000000);
output_d(0b11111111);
x[0] = getc(); //isdigit testa se é um numero
x[1] = getc();
chk = generate_16bit_crc(x,0x02,CRC_CCITT);
puts(chk);
Tks. |
Posted: Tue Mar 17, 2015 1:47 am |
You don't need to post the library part. Just include it. You are breaching CCS copyright by posting the section from the library....
That said, the key problem is with what you are doing with the value returned.
The CRC function returns a number, not a string.
Instead of puts(chk) which will never work, use:
printf("%04LX\n\r",chk);
Which will format the number as four hex digits, or:
printf("%04Lu\n\r",chk);
Which will print the number in decimal (and add a line feed/carriage return).
So the demo code becomes:
//You are not using anything in the other libraries - no point in including them
#include <crc.c> //Include the crc generator functions
unsigned int16 chk; //checksum value
//set_tris_d(0b00000000); //Pointless
x[1] = getc();
chk = generate_16bit_crc(x,0x02,CRC_CCITT); //generate CRC of two characters
printf("%04Lu\n\r",chk); //and display.
Notice how much smaller the code becomes.... |
ldalcol
Posted: Wed Mar 18, 2015 9:52 am |
Thank you, formatting work!
I apologize for posting information prohibited, it will not be repeated! |
