[Help] Setup WDT in PIC18F4680
tienchuan
PostPosted: Wed Mar 18, 2015 12:46 am     Reply with quote
Hi
I have a problem when tried to setting WDT on PIC18F4680
In main program, i also used timer 0, and I can't config WDT with " setup_wdt() with another parameter, I can only setup with "WDT_512ms"
My config "
#include "18F4680_me.h"   #fusesH4,PUT,PROTECT,NODEBUG,NOLVP,WDT256,NOPBADEN,MCLR,BROWNOUT,BORV28
#use delay(clock=40000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, errors)
-timer0 setup
set_timer0(62);
setup_timer_0 (RTCC_INTERNAL | RTCC_8_BIT | RTCC_DIV_256);
- main code
   setup_wdt(WDT_ON|WDT_512mS);   // can't config with another parameters without WDT_512ms
   restart_wdt();
   for(;;)                      // main loop
   restart_wdt();
I'm using CCS C ver 5.021
Pls show me a problems when setup with WDT, is it conflict with timer0 ?
Thanks.
Begin Begin Begin !!!
PostPosted: Wed Mar 18, 2015 1:30 am     Reply with quote
The 18F4680 data sheet says:
24.2 Watchdog Timer (WDT)
24.2.1 CONTROL REGISTER
Register 24-14 shows the WDTCON register. This is a
readable and writable register which contains a control
bit that allows software to override the WDT enable
Configuration bit, but only if the Configuration bit has
disabled the WDT
This means if you want to use setup_wdt(), you must put NOWDT (only)
in the #fuses. Remove the WDT256 and replace it with NOWDT.
tienchuan
PostPosted: Wed Mar 18, 2015 2:59 am     Reply with quote
Thank so much
I fixed!Smile
