Ringo42
Why does this code stop |
Posted: Wed Feb 25, 2015 12:32 pm |
Can someone please look at this and tell me why it stops after line 71.
On the output I get the initial stuff then I get to "RSSI 3" and then nothing.
If I comment out lines 75 to 85 then it runs. What is killing it there?
Ringo
#include "18f452.h"
#fuses hs,WDT8,noprotect,put,nolvp
#device adc=10
#device HIGH_INTS=TRUE
#use delay(clock=20000000,restart_wdt)
#include <stdlib.h>
#define LED1_PIN PIN_B6
#define LED2_PIN PIN_B7
#define TX_PIN PIN_C6
#define RX_PIN PIN_C7
#define BAUD_RATE 19200
#define Mux_sel PIN_E2
#use rs232(baud=BAUD_RATE,xmit=TX_PIN,rcv=RX_PIN,errors,bits=8,parity=N,restart_wdt)
///Macros
#define LED1_ON output_high(LED1_PIN)
#define LED2_ON output_high(LED2_PIN)
#define LED1_OFF output_low(LED1_PIN)
#define LED2_OFF output_low(LED2_PIN)
void CheckRssi();
void InitPic();
setup_wdt(WDT_ON);
setup_timer_0(RTCC_INTERNAL);
printf("ABC\r\n >");
InitPic();
printf("\r\n\nMotherboard RX, firmware 3n >\r\n");
printf("\r\n>");
set_adc_channel( 5 );
delay_ms(1);
while (1)
CheckRssi();
restart_wdt();
void CheckRssi()
int channel;
int RSSI=0;
int RSSIcounter=0;
delay_ms(1);
RSSI = Read_ADC();
printf("RSSI!!!!!!!!!!!! \r\n");
if(RSSI >100) // If radio is detected, but up counter a bunch
RSSIcounter+=10;
output_high(PIN_E1);
RSSIcounter-=1;//else slowly count down to make sure radio is really off
output_low(PIN_E1);
printf("RSSI 2\r\n");
if(RSSIcounter >244)
RSSIcounter=244;
if(RSSIcounter <2)
RSSIcounter=2;
printf("RSSI 3 \r\n");
if(RSSIcounter > 30)//if the radio is seen a few times
output_high(MUX_Sel);//radio
output_high(PIN_B2);
output_low(MUX_sel);//usb
output_low(PIN_B2);
printf("RSSI 4 \r\n");
printf("RSSI= %u RSSIcounter= %u \r\n",RSSI,RSSIcounter);
void InitPic()
short int dummy_variable;
setup_adc_ports(All_ANALOG);
setup_adc( ADC_CLOCK_INTERNAL );
setup_spi(FALSE);
setup_psp(PSP_DISABLED);
setup_timer_2(T2_DIV_BY_4,128,16);// 18.6 khz 0-512 int every 8ms //
setup_timer_0(RTCC_Internal|RTCC_div_2);
// enable_interrupts(INT_RDA); // Serial Data Available IRQ
enable_interrupts(INT_TIMER2); // Timer 2 Overflow
// enable_interrupts(global); // Enable IRQs
dummy_variable = input(PIN_E0);
output_low(PIN_E1);
output_low(PIN_B2);
output_low(PIN_E2);//mux_sel
input(pin_a4);//RTS
port_b_pullups(false);
_________________ Ringo Davis |
Joined: 01 Jul 2010 Posts: 9401 Location: Greensville,Ontario
Posted: Wed Feb 25, 2015 1:04 pm |
first.....
Quote: | If I comment out lines 75 to 85 then it runs. What is killing it there? |
We have NO idea what these lines are, without seeing the actual listing ( filename.lst)
2nd. You have the WDT enabled which during the 'debugging' phase of code creation could( will) cause no end of problems.
3rd. You should post compiler version..might be a bug...
4th. RSSI looks like a 'radio peripheral' is connected to the PIC. Now if the PIC is running off 5 volts and the 'radio' is running off 3 volts, that can be a HUGE issue.
5th...
best check the datasheet, adc section, at 20MHz this won't be a valid value..
It'd be nice to see a schematic or more info as to what the hardware is(mfr/model/etc.)
The more info you give us, the faster/better the responses.
Ringo42
Posted: Wed Feb 25, 2015 1:32 pm |
Thanks for the help,
I narrowed it down to the line
//output_high(MUX_Sel);//radio
with it commented out it runs.
The .lst file is below.
I'll disable watchdog for now
Compiler Version 4.007
I'll change the ADc to ADC_CLOCK_DIV_32. It is listed as have a max freq of 20mhz. In the pic datasheet there is a div/64 but I dont see that option in the CCS manual, should I use something else?
You are correct the radio is 3.3V and the pic is 5V, but the only problem I see with this is not getting full range correct? The Rssi is a PWM value that I filter into an analog signal.
I can send a schematic, but don't see how to attach it here. Am I missing an attachment button somewhere?
[code:1:392b684fcf]
CCS PCH C Compiler, Version 4.007, 34836 25-Feb-15 13:42
Filename: C:\Users\Hardware\Dropbox\21st century\Firmware\21_Rx_V3N_rssi_test.lst
ROM used: 884 bytes (3%)
Largest free fragment is 31884
RAM used: 14 (1%) at main() level
23 (1%) worst case
Stack: 3 locations
0000: GOTO 029C
.................... #include "18f452.h"
.................... //////// Standard Header file for the PIC18F452 device ////////////////
.................... #device PIC18F452
.................... #list
.................... #fuses hs,WDT8,noprotect,put,nolvp
.................... #device adc=10
.................... #device HIGH_INTS=TRUE
.................... #use delay(clock=20000000,restart_wdt)
00F4: CLRF FEA
00F6: MOVLW 0F
00F8: MOVWF FE9
00FA: MOVF FEF,W
00FC: BZ 0120
00FE: MOVLW 06
0100: MOVWF 01
0102: MOVLW BF
0104: MOVWF 00
0106: CLRWDT
0108: DECFSZ 00,F
010A: BRA 0106
010C: DECFSZ 01,F
010E: BRA 0102
0110: MOVLW 7A
0112: MOVWF 00
0114: DECFSZ 00,F
0116: BRA 0114
0118: BRA 011A
011A: CLRWDT
011C: DECFSZ FEF,F
011E: BRA 00FE
0120: RETLW 00
.................... #include <stdlib.h>
.................... //// (C) Copyright 1996,2003 Custom Computer Services ////
.................... //// This source code may only be used by licensed users of the CCS C ////
.................... //// compiler. This source code may only be distributed to other ////
.................... //// licensed users of the CCS C compiler. No other use, reproduction ////
.................... //// or distribution is permitted without written permission. ////
.................... //// Derivative programs created using this software in object code ////
.................... //// form are not restricted in any way. ////
.................... #ifndef _STDLIB
.................... #define _STDLIB
.................... // Definitions and types
.................... #ifndef RAND_MAX
.................... #define RAND_MAX 32767 // The value of which is the maximum value
.................... // ... returned by the rand function
.................... #endif
.................... typedef struct {
.................... signed int quot;
.................... signed int rem;
.................... } div_t;
.................... signed long quot;
.................... signed long rem;
.................... } ldiv_t;
.................... #include <stddef.h>
.................... #ifndef _STDDEF
.................... #define _STDDEF
.................... #if sizeof(int *)==1
.................... #define ptrdiff_t int
.................... #else
.................... #define ptrdiff_t long
.................... #define size_t int
.................... #define wchar_t char
.................... #define NULL 0
.................... #define offsetof(s,f) (offsetofbit(s,f)/8)
.................... // String conversion functions
.................... /* Standard template: float atof(char * s)
.................... * converts the initial portion of the string s to a float.
.................... * returns the converted value if any, 0 otherwise
.................... float atof(char * s);
.................... /* Standard template: float atoe(char * s)
.................... * also handles E format numbers
.................... float atoe(char * s);
.................... /* Standard template: signed int atoi(char * s)
.................... * converts the initial portion of the string s to a signed int
.................... signed int atoi(char *s);
.................... /* Syntax: signed int32 atoi32(char * s)
.................... converts the initial portion of the string s to a signed int32
.................... returns the converted value if any, 0 otherwise*/
.................... signed int32 atoi32(char *s);
.................... /* Syntax: char * itoa(signed int32 num, int8 base, char * s)
.................... converts the signed int32 to a string and
.................... char * itoa(signed int32 num, int8 base, char * s);
.................... /* Standard template: signed long atol(char * s)
.................... * converts the initial portion of the string s to a signed long
.................... signed long atol(char *s);
.................... /* Standard template: float strtol(char * s,char *endptr)
.................... * the final string is returned in the endptr, if endptr is not null
.................... float strtod(char *s,char *endptr);
.................... /* Standard template: long strtoul(char * s,char *endptr,signed int base)
.................... * converts the initial portion of the string s, represented as an
.................... * integral value of radix base to a signed long.
.................... * Returns the converted value if any, 0 otherwise
.................... signed long strtol(char *s,char *endptr,signed int base);
.................... * integral value of radix base to a unsigned long.
.................... long strtoul(char *s,char *endptr,signed int base);
.................... // Pseudo-random sequence generation functions
.................... /* The rand function computes a sequence of pseudo-random integers in
.................... * the range 0 to RAND_MAX
.................... * Parameters:
.................... * (none)
.................... * Returns:
.................... * The pseudo-random integer
.................... long rand(void);
.................... /* The srand function uses the argument as a seed for a new sequence of
.................... * pseudo-random numbers to be returned by subsequent calls to rand.
.................... * [in] seed: The seed value to start from. You might need to pass
.................... * Remarks
.................... * The srand function sets the starting point for generating
.................... * a series of pseudorandom integers. To reinitialize the
.................... * generator, use 1 as the seed argument. Any other value for
.................... * seed sets the generator to a random starting point. rand
.................... * retrieves the pseudorandom numbers that are generated.
.................... * Calling rand before any call to srand generates the same
.................... * sequence as calling srand with seed passed as 1.
.................... * Usually, you need to pass a time here from outer source
.................... * so that the numbers will be different every time you run.
.................... void srand(unsigned int32 seed);
.................... // Memory management functions
.................... // Comming soon
.................... // Communication with the environment
.................... /* The function returns 0 always
.................... signed int system(char *string);
.................... // Searching and sorting utilities
.................... /* Performs a binary search of a sorted array..
.................... * [in] key: Object to search for
.................... * [in] base: Pointer to base of search data
.................... * [in] num: Number of elements
.................... * [in] width: Width of elements
.................... * [in] compare: Function that compares two elements
.................... * bsearch returns a pointer to an occurrence of key in the array pointed
.................... * to by base. If key is not found, the function returns NULL. If the
.................... * array is not in order or contains duplicate records with identical keys,
.................... * the result is unpredictable.
.................... //void *bsearch(const void *key, const void *base, size_t num, size_t width,
.................... // int (*compare)(const void *, const void *));
.................... /* Performs the shell-metzner sort (not the quick sort algorithm). The contents
.................... * of the array are sorted into ascending order according to a comparison
.................... * function pointed to by compar.
.................... //void *qsort(const void *base, size_t num, size_t width,
.................... // Integer arithmetic functions
.................... #define labs abs
.................... div_t div(signed int numer,signed int denom);
.................... ldiv_t ldiv(signed long numer,signed long denom);
.................... // Multibyte character functions
.................... // Not supported
.................... // Multibyte string functions
.................... // Internal implementation
.................... #include <string.h>
.................... #ifndef _STRING
.................... #define _STRING
.................... #include <ctype.h>
.................... #ifndef _CTYPE
.................... #define _CTYPE
.................... #define islower(x) isamong(x,"abcdefghijklmnopqrstuvwxyz")
.................... #define isupper(x) isamong(x,"ABCDEFGHIJKLMNOPQRSTUVWXYZ")
.................... #define isalnum(x) isamong(x,"0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz")
.................... #define isalpha(x) isamong(x,"ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz")
.................... #define isdigit(x) isamong(x,"0123456789")
.................... #define isspace(x) (x==' ')
.................... #define isxdigit(x) isamong(x,"0123456789ABCDEFabcdef")
.................... #define iscntrl(x) (x<' ')
.................... #define isprint(x) (x>=' ')
.................... #define isgraph(x) (x>' ')
.................... #define ispunct(x) ((x>' ')&&!isalnum(x))
.................... //// Uncomment the following define to ////
.................... //// allow some functions to use a ////
.................... //// quicker algorithm, but use more ROM ////
.................... //// #define FASTER_BUT_MORE_ROM ////
.................... /*Copying functions*/
.................... /* standard template:
.................... void *memmove(void *s1, void *s2, size_t n).
.................... Copies max of n characters safely (not following ending '\0')
.................... from s2 in s1; if s2 has less than n characters, appends 0 */
.................... char *memmove(void *s1,char *s2,size_t n)
.................... char *sc1;
.................... char *sc2;
.................... sc1=s1;
.................... sc2=s2;
.................... if(sc2<sc1 && sc1 <sc2 +n)
.................... for(sc1+=n,sc2+=n;0<n;--n)
.................... *--sc1=*--sc2;
.................... else
.................... for(;0<n;--n)
.................... *sc1++=*sc2++;
.................... return s1;
.................... /* compiler ignored the name 'strcpy()'; perhaps, it's reserved?
.................... Standard template: char *strcpy(char *s1, const char *s2)
.................... copies the string s2 including the null character to s1*/
.................... char *strcopy(char *s1, char *s2)
.................... char *s;
.................... for (s = s1; *s2 != 0; s++, s2++) {
.................... *s = *s2;
.................... return(s1);
.................... char *strncpy(char *s1, const char *s2, size_t n).
.................... Copies max of n characters (not following ending '\0')
.................... char *strncpy(char *s1, char *s2, size_t n)
.................... for (s = s1; n > 0 && *s2 != '\0'; n--)
.................... *s++ = *s2++;
.................... for (; n > 0; n--)
.................... *s++ = '\0';
.................... /*concatenation functions*/
.................... /* standard template: char *strcat(char *s1, const char *s2)
.................... appends s2 to s1*/
.................... char *strcat(char *s1, char *s2)
.................... for (s = s1; *s != '\0'; ++s);
.................... while(*s2 != '\0')
.................... ++s;
.................... ++s2;
.................... *s = '\0';
.................... /* standard template: char *strncat(char *s1, char *s2,size_t n)
.................... appends not more than n characters from s2 to s1*/
.................... char *strncat(char *s1, char *s2, size_t n)
.................... while(*s2 != '\0' && 0<n)
.................... --n;
.................... /*comparison functions*/
.................... /* standard template: signed int memcmp(void *s1, void *s2).
.................... Compares s1 & s2; returns -1 if s1<s2, 0 if s1=s2, 1 if s1>s2 */
.................... signed int memcmp(void * s1,char *s2,size_t n)
.................... char *su1, *su2;
.................... for(su1=s1, su2=s2; 0<n; ++su1, ++su2, --n)
.................... if(*su1!=*su2)
.................... return ((*su1<*su2)?-1:+1);
.................... return 0;
.................... /* standard template: int strcmp(const char *s1, const char *s2).
.................... signed int strcmp(char *s1, char *s2)
.................... for (; *s1 == *s2; s1++, s2++)
.................... if (*s1 == '\0')
.................... return(0);
.................... return((*s1 < *s2) ? -1: 1);
.................... /* standard template: int strcoll(const char *s1, const char *s2).
.................... signed int strcoll(char *s1, char *s2)
.................... int strncmp(const char *s1, const char *s2, size_t n).
.................... Compares max of n characters (not following 0) from s1 to s2;
.................... returns same as strcmp */
.................... signed int strncmp(char *s1, char *s2, size_t n)
.................... for (; n > 0; s1++, s2++, n--)
.................... if (*s1 != *s2)
.................... return((*s1 <*s2) ? -1: 1);
.................... else if (*s1 == '\0')
.................... int strxfrm(const char *s1, const char *s2, size_t n).
.................... transforms maximum of n characters from s2 and places them into s1*/
.................... size_t strxfrm(char *s1, char *s2, size_t n)
.................... int n1;
.................... n1=n;
.................... return(n1);
.................... /*Search functions*/
.................... /* standard template: void *memchr(const char *s, int c).
.................... Finds first occurrence of c in n characters of s */
.................... char *memchr(void *s,int c,size_t n)
.................... char uc;
.................... char *su;
.................... uc=c;
.................... for(su=s;0<n;++su,--n)
.................... if(*su==uc)
.................... return su;
.................... return NULL;
.................... /* standard template: char *strchr(const char *s, int c).
.................... Finds first occurrence of c in s */
.................... char *strchr(char *s, int c)
.................... for (; *s != c; s++)
.................... if (*s == '\0')
.................... return(s);
.................... size_t strcspn(const char *s1, const char *s2).
.................... Computes length of max initial segment of s1 that
.................... consists entirely of characters NOT from s2*/
.................... int *strcspn(char *s1, char *s2)
.................... char *sc1, *sc2;
.................... for (sc1 = s1; *sc1 != 0; sc1++)
.................... for (sc2 = s2; *sc2 != 0; sc2++)
.................... if (*sc1 == *sc2)
.................... return(sc1 - s1);
.................... char *strpbrk(const char *s1, const char *s2).
.................... Locates first occurence of any character from s2 in s1;
.................... returns s1 if s2 is empty string */
.................... char *strpbrk(char *s1, char *s2)
.................... return(sc1);
.................... /* standard template: char *strrchr(const char *s, int c).
.................... Finds last occurrence of c in s */
.................... char *strrchr(char *s, int c)
.................... char *p;
.................... for (p = 0; ; s++)
.................... if (*s == c)
.................... p = s;
.................... return(p);
.................... /* computes length of max initial segment of s1 consisting
.................... entirely of characters from s2 */
.................... int *strspn(char *s1, char *s2)
.................... for (sc2 = s2; ; sc2++)
.................... if (*sc2 == '\0')
.................... else if (*sc1 == *sc2)
.................... break;
.................... char *strstr(const char *s1, const char *s2);
.................... Locates first occurence of character sequence s2 in s1;
.................... returns 0 if s2 is empty string
.................... Uncomment #define FASTER_BUT_MORE_ROM at the top of the
.................... file to use the faster algorithm */
.................... char *strstr(char *s1, char *s2)
.................... char *s, *t;
.................... #ifdef FASTER_BUT_MORE_ROM
.................... if (*s2 == '\0')
.................... while (*s1)
.................... for(s = s1, t = s2; *t && (*s == *t); ++s, ++t);
.................... if (*t == '\0')
.................... ++s1;
.................... while(*s1 != '\0' && *s1 != *s2)
.................... /* standard template: char *strtok(char *s1, const char *s2).
.................... Finds next token in s1 delimited by a character from separator
.................... string s2 (which can be different from call to call). First call
.................... starts at beginning of s1 searching for first character NOT
.................... contained in s2; returns 0 if none is found.
.................... If one is found, it is the start of first token (return value).
.................... Function then searches from there for a character contained in s2.
.................... If none is found, current token extends to end of s1, and subsequent
.................... searches for a token will return 0. If one is found, it is
.................... overwritten by '\0', which terminates current token. Function saves
.................... pointer to following character from which next search will start.
.................... Each subsequent call, with 0 as first argument, starts searching
.................... from saved pointer */
.................... char *strtok(char *s1, char *s2)
.................... char *beg, *end;
.................... static char *save;
.................... beg = (s1)? s1: save;
.................... beg += strspn(beg, s2);
.................... if (*beg == '\0')
.................... *save = ' ';
.................... end = strpbrk(beg, s2);
.................... if (*end != '\0')
.................... *end = '\0';
.................... end++;
.................... save = end;
.................... return(beg);
.................... /*Miscellaneous functions*/
.................... maps error number in errnum to an error message string
.................... Returns: Pointer to string
.................... #ifdef _ERRNO
.................... char * strerror(int errnum)
.................... char s[15];
.................... switch( errnum)
.................... case 0:
.................... strcpy(s,"no errors");
.................... return s;
.................... case EDOM :
.................... strcpy(s,"domain error");
.................... case ERANGE:
.................... strcpy(s,"range error");
.................... #ENDIF
.................... /* standard template: size_t strlen(const char *s).
.................... Computes length of s1 (preceding terminating 0) */
.................... int *strlen(char *s)
.................... char *sc;
.................... for (sc = s; *sc != 0; sc++);
.................... return(sc - s);
.................... /* standard template: size_t stricmp(const char *s1, const char *s2).
.................... Compares s1 to s2 ignoring case (upper vs. lower) */
.................... signed int stricmp(char *s1, char *s2)
.................... for(; *s1==*s2||(isalpha(*s1)&&isalpha(*s2)&&(*s1==*s2+32||*s2==*s1+32));
.................... s1++, s2++)
.................... /* standard template: char *strlwr(char *s).
.................... Replaces uppercase letters by lowercase;
.................... returns pointer to new string s */
.................... char *strlwr(char *s)
.................... for (p = s; *p != '\0'; p++)
.................... if (*p >= 'A' && *p <='Z')
.................... *p += 'a' - 'A';
.................... div_t val;
.................... val.quot = numer / denom;
.................... val.rem = numer - (denom * val.quot);
.................... return (val);
.................... ldiv_t val;
.................... float pow10 = 1.0;
.................... float result = 0.0;
.................... int sign = 0;
.................... char c;
.................... int ptr = 0;
.................... c = s[ptr++];
.................... if ((c>='0' && c<='9') || c=='+' || c=='-' || c=='.') {
.................... if(c == '-') {
.................... sign = 1;
.................... if(c == '+')
.................... while((c >= '0' && c <= '9')) {
.................... result = 10*result + c - '0';
.................... if (c == '.') {
.................... pow10 = pow10*10;
.................... result += (c - '0')/pow10;
.................... if (sign == 1)
.................... result = -1*result;
.................... return(result);
.................... int expsign = 0;
.................... int i;
.................... float exp = 1.0;
.................... int expcnt = 0;
.................... if ((c>='0' && c<='9') || c=='+' || c=='-' || c=='.' || c=='E' || c=='e') {
.................... // Handling the exponent
.................... if (c=='e' || c=='E') {
.................... expsign = 1;
.................... expcnt = 10*expcnt + c - '0';
.................... for(i=0;i<expcnt;i++)
.................... exp*=10;
.................... if(expsign==1)
.................... result/=exp;
.................... result*=exp;
.................... signed int result;
.................... int sign, base, index;
.................... index = 0;
.................... sign = 0;
.................... base = 10;
.................... result = 0;
.................... if (!s)
.................... // Omit all preceeding alpha characters
.................... c = s[index++];
.................... // increase index if either positive or negative sign is detected
.................... if (c == '-')
.................... sign = 1; // Set the sign to negative
.................... else if (c == '+')
.................... if (c >= '0' && c <= '9')
.................... // Check for hexa number
.................... if (c == '0' && (s[index] == 'x' || s[index] == 'X'))
.................... base = 16;
.................... index++;
.................... // The number is a decimal number
.................... if (base == 10)
.................... while (c >= '0' && c <= '9')
.................... result = 10*result + (c - '0');
.................... else if (base == 16) // The number is a hexa number
.................... c = toupper(c);
.................... while ( (c >= '0' && c <= '9') || (c >= 'A' && c<='F'))
.................... result = (result << 4) + (c - '0');
.................... result = (result << 4) + (c - 'A' + 10);
.................... if (sign == 1 && base == 10)
.................... result = -result;
.................... signed long result;
.................... while ( (c >= '0' && c <= '9') || (c >= 'A' && c <='F'))
.................... c = s[index++];c = toupper(c);
.................... if (base == 10 && sign == 1)
.................... /* A fast routine to multiply by 10
.................... signed int32 mult_with10(int32 num)
.................... return ( (num << 1) + (num << 3) );
.................... signed int32 result;
.................... while (c >= '0' && c <= '9') {
.................... result = (result << 1) + (result << 3); // result *= 10;
.................... result += (c - '0');
.................... while ((c >= '0' && c <= '9') || (c >= 'A' && c <='F'))
.................... char * itoa(signed int32 num, int8 base, char *s)
.................... int32 temp=1;
.................... int8 i,sign=0,cnt=0;
.................... if(num<0) {
.................... sign=1; // Check for negative number
.................... num*=-1;
.................... while(temp>0) {
.................... temp=(num/base);
.................... s[cnt]=(num%base)+'0'; // Conversion
.................... if(s[cnt]>0x39)
.................... s[cnt]+=0x7;
.................... cnt++;
.................... num=temp;
.................... if(sign==1) {
.................... s[cnt]=0x2D; // Negative sign
.................... for(i = 0;i<(int8)(cnt/2);i++) {
.................... c=s[i];
.................... s[i]=s[cnt-i-1]; // Reverse the number
.................... s[cnt-i-1]=c;
.................... s[cnt]='\0'; // End the string
.................... float strtod(char *s,char *endptr) {
.................... int sign = 0, point = 0;
.................... c=s[ptr++];
.................... while((c>='0' && c<='9') || c=='+' || c=='-' || c=='.') {
.................... while((c >= '0' && c <= '9') && point == 0) {
.................... point = 1;
.................... while((c >= '0' && c <= '9') && point == 1) {
.................... if (c == '+') {
.................... if(endptr)
.................... if (ptr) {
.................... ptr--;
.................... *((char *)endptr)=s+ptr;
.................... *((char *)endptr)=s;
.................... char *sc,*s1,*sd;
.................... unsigned long x=0;
.................... char sign;
.................... char digits[]="0123456789abcdefghijklmnopqstuvwxyz";
.................... for(sc=s;isspace(*sc);++sc);
.................... sign=*sc=='-'||*sc=='+'?*sc++:'+';
.................... if(sign=='-')
.................... if (endptr)
.................... if (base <0 || base ==1|| base >36) // invalid base
.................... else if (base)
.................... if(base==16 && *sc =='0'&&(sc[1]=='x' || sc[1]=='X'))
.................... sc+=2;
.................... if(base==8 && *sc =='0')
.................... sc+=1;
.................... if(base==2 && *sc =='0'&&sc _________________ Ringo Davis |
Posted: Wed Feb 25, 2015 1:47 pm |
Your include file stddef.h is not needed. It's not used by your program.
But it fills up the .LST file and exceeds the amount of code that the forum
program can handle (it gets cut off). Delete #include stddef.h.
How to post an image on the CCS forum:
Use http://www.postimage.com or http://www.imageshack.com
or some other free image hosting service.
Upload your schematic to that website. Preferably a .JPG file or some
other commonly used image format.
Then post a link to your image here in the forum.
Quote: | Compiler Version 4.007 |
This is not a great version. I would only write very simple code with
this version. Then it may work for you. You are basically doing that now.
If you bought the compiler, you might consider asking CCS to upgrade
you to the last and best version of 4.xxx, which is 4.141. Maybe they
would do it for free if you ask them nicely, or maybe they could cut you
a deal. It's worth a try. 4.007 is early beta. |
Ringo42
Posted: Wed Feb 25, 2015 2:01 pm |
Here is the lst file without stdlib, hopefully that helps
Here is a PDF of the schematic
http://postimg.org/image/pwk8htn57/
I asked support about an upgrade, guess I'll see what they say.
Code: | CCS PCH C Compiler, Version 4.007, 34836 25-Feb-15 14:58
ROM used: 880 bytes (3%)
Largest free fragment is 31888
RAM used: 9 (1%) at main() level
17 (1%) worst case
Stack: 3 locations
0000: GOTO 029A
.................... #device HIGH_INTS=true
.................... //#device ADC=UNSIGNED
00F4: CLRF FEA
00F6: MOVLW 09
00F8: MOVWF FE9
00FA: MOVF FEF,W
00FC: BZ 0120
00FE: MOVLW 06
0100: MOVWF 01
0102: MOVLW BF
0104: MOVWF 00
0106: CLRWDT
0108: DECFSZ 00,F
010A: BRA 0106
010C: DECFSZ 01,F
010E: BRA 0102
0110: MOVLW 7A
0112: MOVWF 00
0114: DECFSZ 00,F
0116: BRA 0114
0118: BRA 011A
011A: CLRWDT
011C: DECFSZ FEF,F
011E: BRA 00FE
0120: RETLW 00
.................... //#include <stdlib.h>
.................... #define LED1_PIN PIN_B6
.................... #define LED2_PIN PIN_B7
.................... #define TX_PIN PIN_C6
.................... #define RX_PIN PIN_C7
.................... #define Mux_sel PIN_E2
.................... #define BAUD_RATE 19200
.................... #use rs232(baud=BAUD_RATE,xmit=TX_PIN,rcv=RX_PIN,errors,bits=8,parity=N,restart_wdt)
.................... ///Macros
.................... #define LED1_ON output_high(LED1_PIN)
.................... #define LED2_ON output_high(LED2_PIN)
.................... #define LED1_OFF output_low(LED1_PIN)
.................... #define LED2_OFF output_low(LED2_PIN)
.................... void CheckRssi();
.................... void InitPic();
.................... unsigned int RSSIcounter=0;
.................... void main()
029A: CLRF FF8
029C: BSF FD0.7
029E: CLRF FEA
02A0: CLRF FE9
02A2: MOVLW 40
02A4: MOVWF FAF
02A6: MOVLW A6
02A8: MOVWF FAC
02AA: MOVLW 90
02AC: MOVWF FAB
02AE: BSF FC1.0
02B0: BSF FC1.1
02B2: BSF FC1.2
02B4: BCF FC1.3
02B6: CLRF 05
02B8: CLRF 06
.................... setup_wdt(WDT_ON);
02BA: BSF FD1.0
.................... setup_timer_0(RTCC_INTERNAL);
02BC: MOVLW 80
02BE: MOVWF FD5
.................... printf("ABC\r\n >");
02C0: CLRF 07
02C2: MOVF 07,W
02C4: RCALL 0004
02C6: INCF 07,F
02C8: MOVWF 00
02CA: CLRWDT
02CC: BTFSS F9E.4
02CE: BRA 02CA
02D0: MOVWF FAD
02D2: MOVLW 05
02D4: SUBWF 07,W
02D6: BNZ 02C2
02D8: MOVLW 03
02DA: MOVWF 08
02DC: MOVLW 20
02DE: CLRWDT
02E0: BTFSS F9E.4
02E2: BRA 02DE
02E4: MOVWF FAD
02E6: DECFSZ 08,F
02E8: BRA 02DC
02EA: MOVLW 3E
02EC: CLRWDT
02EE: BTFSS F9E.4
02F0: BRA 02EC
02F2: MOVWF FAD
.................... InitPic();
02F4: BRA 00A8
.................... printf("\r\n\nMotherboard RX, firmware 3n >\r\n");
02F6: CLRF 07
02F8: MOVF 07,W
02FA: RCALL 001C
02FC: INCF 07,F
02FE: MOVWF 00
0300: CLRWDT
0302: BTFSS F9E.4
0304: BRA 0300
0306: MOVWF FAD
0308: MOVLW 1E
030A: SUBWF 07,W
030C: BNZ 02F8
030E: MOVLW 03
0310: MOVWF 08
0312: MOVLW 20
0314: CLRWDT
0316: BTFSS F9E.4
0318: BRA 0314
031A: MOVWF FAD
031C: DECFSZ 08,F
031E: BRA 0312
0320: MOVLW 3E
0322: CLRWDT
0324: BTFSS F9E.4
0326: BRA 0322
0328: MOVWF FAD
032A: MOVLW 0D
032C: CLRWDT
032E: BTFSS F9E.4
0330: BRA 032C
0332: MOVWF FAD
0334: MOVLW 0A
0336: CLRWDT
0338: BTFSS F9E.4
033A: BRA 0336
033C: MOVWF FAD
.................... printf("Copyright 2015 Ringo Davis\r\n>");
033E: CLRF 07
0340: MOVF 07,W
0342: RCALL 004E
0344: INCF 07,F
0346: MOVWF 00
0348: CLRWDT
034A: BTFSS F9E.4
034C: BRA 0348
034E: MOVWF FAD
0350: MOVLW 1D
0352: SUBWF 07,W
0354: BNZ 0340
.................... set_adc_channel( 5 );
0356: MOVLW 28
0358: MOVWF 01
035A: MOVF FC2,W
035C: ANDLW C7
035E: IORWF 01,W
0360: MOVWF FC2
.................... delay_ms(1);
0362: MOVLW 01
0364: MOVWF 09
0366: RCALL 00F4
.................... while (1)
.................... CheckRssi();
0368: BRA 01BC
.................... restart_wdt();
036A: CLRWDT
036C: BRA 0368
036E: SLEEP
.................... int channel;
.................... unsigned int RSSI=0;
01BC: CLRF 08
01BE: MOVLW 28
01C0: MOVWF 01
01C2: MOVF FC2,W
01C4: ANDLW C7
01C6: IORWF 01,W
01C8: MOVWF FC2
01CA: MOVLW 01
01CC: MOVWF 09
01CE: RCALL 00F4
.................... RSSI = Read_ADC();
01D0: BSF FC2.2
01D2: BTFSC FC2.2
01D4: BRA 01D2
01D6: MOVFF FC3,08
.................... delay_ms(100);
01DA: MOVLW 64
01DC: MOVWF 09
01DE: RCALL 00F4
.................... // printf("RSSI!!!!!!!!!!!! \r\n");
.................... if(RSSI >100) // If radio is detected, but up counter a bunch
01E0: MOVF 08,W
01E2: SUBLW 64
01E4: BC 01F0
.................... RSSIcounter+=10;
01E6: MOVLW 0A
01E8: ADDWF 06,F
.................... output_high(PIN_E1);
01EA: BCF F96.1
01EC: BSF F8D.1
01EE: BRA 01F8
.................... RSSIcounter-=1;//else slowly count down to make sure radio is really off
01F0: MOVLW 01
01F2: SUBWF 06,F
.................... output_low(PIN_E1);
01F4: BCF F96.1
01F6: BCF F8D.1
.................... // printf("RSSI 2\r\n");
.................... if(RSSIcounter >244)
01F8: MOVF 06,W
01FA: SUBLW F4
01FC: BC 0202
.................... RSSIcounter=244;
01FE: MOVLW F4
0200: MOVWF 06
.................... if(RSSIcounter <2)
0202: MOVF 06,W
0204: SUBLW 01
0206: BNC 020C
.................... RSSIcounter=2;
0208: MOVLW 02
020A: MOVWF 06
.................... // printf("RSSI 3 \r\n");
.................... if(RSSIcounter > 30)//if the radio is seen a few times
020C: MOVF 06,W
020E: SUBLW 1E
0210: BC 0218
.................... //output_high(MUX_Sel);//radio
.................... output_high(PIN_B2);
0212: BCF F93.2
0214: BSF F8A.2
0216: BRA 0220
.................... output_low(MUX_sel);//usb
0218: BCF F96.2
021A: BCF F8D.2
.................... output_low(PIN_B2);
021C: BCF F93.2
021E: BCF F8A.2
.................... // printf("RSSI 4 \r\n");
.................... printf("RSSI= %u RSSIcounter= %u \r\n",RSSI,RSSIcounter);
0220: CLRF 09
0222: MOVF 09,W
0224: RCALL 007C
0226: INCF 09,F
0228: MOVWF 00
022A: CLRWDT
022C: BTFSS F9E.4
022E: BRA 022A
0230: MOVWF FAD
0232: MOVLW 06
0234: SUBWF 09,W
0236: BNZ 0222
0238: MOVFF 08,0C
023C: MOVLW 1B
023E: MOVWF 0D
0240: RCALL 014A
0242: MOVLW 04
0244: MOVWF 0A
0246: MOVLW 20
0248: CLRWDT
024A: BTFSS F9E.4
024C: BRA 0248
024E: MOVWF FAD
0250: DECFSZ 0A,F
0252: BRA 0246
0254: MOVLW 08
0256: MOVWF 0B
0258: MOVF 0B,W
025A: RCALL 007C
025C: INCF 0B,F
025E: MOVWF 00
0260: CLRWDT
0262: BTFSS F9E.4
0264: BRA 0260
0266: MOVWF FAD
0268: MOVLW 15
026A: SUBWF 0B,W
026C: BNZ 0258
026E: MOVFF 06,0C
0272: MOVLW 1B
0274: MOVWF 0D
0276: RCALL 014A
0278: MOVLW 20
027A: CLRWDT
027C: BTFSS F9E.4
027E: BRA 027A
0280: MOVWF FAD
0282: MOVLW 0D
0284: CLRWDT
0286: BTFSS F9E.4
0288: BRA 0284
028A: MOVWF FAD
028C: MOVLW 0A
028E: CLRWDT
0290: BTFSS F9E.4
0292: BRA 028E
0294: MOVWF FAD
0296: GOTO 036A (RETURN)
.................... short int dummy_variable;
.................... setup_adc_ports(All_ANALOG);
00A8: BCF FC1.0
00AA: BCF FC1.1
00AC: BCF FC1.2
00AE: BCF FC1.3
.................... setup_adc( ADC_CLOCK_DIV_32 );
00B0: BCF FC1.6
00B2: BCF FC2.6
00B4: BSF FC2.7
00B6: BSF FC1.7
00B8: BSF FC2.0
.................... setup_spi(FALSE);
00BA: BCF FC6.5
00BC: BCF F94.5
00BE: BSF F94.4
00C0: BCF F94.3
00C2: MOVLW 00
00C4: MOVWF FC6
00C6: MOVWF FC7
.................... setup_psp(PSP_DISABLED);
00C8: BCF F96.4
.................... setup_timer_2(T2_DIV_BY_4,128,16);// 18.6 khz 0-512 int every 8ms //
00CA: MOVLW 78
00CC: IORLW 05
00CE: MOVWF FCA
00D0: MOVLW 80
00D2: MOVWF FCB
.................... setup_timer_0(RTCC_Internal|RTCC_div_2);
00D4: MOVWF FD5
.................... // enable_interrupts(INT_RDA); // Serial Data Available IRQ
.................... enable_interrupts(INT_TIMER2); // Timer 2 Overflow
00D6: BSF F9D.1
.................... // enable_interrupts(global); // Enable IRQs
.................... dummy_variable = input(PIN_E0);
00D8: BSF F96.0
00DA: BCF 07.0
00DC: BTFSC F84.0
00DE: BSF 07.0
00E0: BCF F96.1
00E2: BCF F8D.1
00E4: BCF F93.2
00E6: BCF F8A.2
.................... output_low(PIN_E2);//mux_sel
00E8: BCF F96.2
00EA: BCF F8D.2
.................... input(pin_a4);//RTS
00EC: BSF F92.4
.................... port_b_pullups(false);
00EE: BSF FF1.7
00F0: GOTO 02F6 (RETURN)
Configuration Fuses:
Word 1: 2200 HS NOOSCSEN
Word 2: 070E BROWNOUT WDT8 WDT BORV20 PUT
Word 3: 0100 CCP2C1
Word 4: 0081 STVREN NODEBUG NOLVP
Word 5: C00F NOPROTECT NOCPD NOCPB
Word 6: E00F NOWRT NOWRTD NOWRTB NOWRTC
Word 7: 400F NOEBTR NOEBTRB
Posted: Wed Feb 25, 2015 2:29 pm |
Mux_sel (pin E2) goes to a jumper block. I don't know what jumpers
are installed there. But the first thing to do, would be to investigate
if there is some hardware effect of setting that pin high, such that it
locks up the PIC.
Do that test with a very simple program as shown below. When it runs,
do you see both printf messages, or just the first one ?
#include "18f452.h"
#fuses hs,NOWDT,noprotect,put,nolvp
#device adc=10
printf("Start\r\n");
printf("Just set mux sel high \n\r");
while(TRUE);
Ringo42
Posted: Wed Feb 25, 2015 2:41 pm |
I get nothing when I run that code. I added a couple lines and now I get the first print statement. The pin does go high though. I put an LED on it.
The jumper block just sends the signal to the mux.
Code: | #include "18f452.h"
#device adc=10
output_low(MUX_Sel);
printf("Just set mux sel low \n\r");
while(TRUE);
Ringo42
Posted: Wed Feb 25, 2015 2:56 pm |
Something is gotta be wrong here. I changed the pin to one that goes nowhere and it doesn't run. Then I did not use a pin at all.
#device adc=10
#define Mux_sel2 PIN_D4
//output_low(MUX_Sel2);
//output_high(MUX_Sel2);
while(TRUE);
and this does not run. I reload my last hex file from my previous test and it runs. How can this simple code be broken?
Code: | CCS PCH C Compiler, Version 4.007, 34836 25-Feb-15 15:53
Filename: C:\Users\Hardware\Dropbox\21st century\Firmware\e2test.lst
ROM used: 282 bytes (1%)
Largest free fragment is 32486
RAM used: 7 (0%) at main() level
8 (1%) worst case
Stack: 1 locations
0000: GOTO 0094
.................... #fuses hs,NOWDT,noprotect,put,nolvp
.................... #use delay(clock=20000000)
006E: CLRF FEA
0070: MOVLW 07
0072: MOVWF FE9
0074: MOVF FEF,W
0076: BZ 0092
0078: MOVLW 06
007A: MOVWF 01
007C: CLRF 00
007E: DECFSZ 00,F
0080: BRA 007E
0082: DECFSZ 01,F
0084: BRA 007C
0086: MOVLW 7B
0088: MOVWF 00
008A: DECFSZ 00,F
008C: BRA 008A
008E: DECFSZ FEF,F
0090: BRA 0078
0092: RETLW 00
.................... #define Mux_sel2 PIN_D4
0094: CLRF FF8
0096: BCF FD0.7
0098: CLRF FEA
009A: CLRF FE9
009C: MOVLW 40
009E: MOVWF FAF
00A0: MOVLW A6
00A2: MOVWF FAC
00A4: MOVLW 90
00A6: MOVWF FAB
00A8: BSF FC1.0
00AA: BSF FC1.1
00AC: BSF FC1.2
00AE: BCF FC1.3
00B0: CLRF 05
.................... printf("Start\r\n");
00B2: CLRF 06
00B4: MOVF 06,W
00B6: RCALL 0004
00B8: INCF 06,F
00BA: MOVWF 00
00BC: CLRWDT
00BE: BTFSS F9E.4
00C0: BRA 00BC
00C2: MOVWF FAD
00C4: MOVLW 07
00C6: SUBWF 06,W
00C8: BNZ 00B4
.................... delay_ms(1000);
00CA: MOVLW 04
00CC: MOVWF 06
00CE: MOVLW FA
00D0: MOVWF 07
00D2: RCALL 006E
00D4: DECFSZ 06,F
00D6: BRA 00CE
.................... //output_low(MUX_Sel2);
.................... printf("Just set mux sel low \n\r");
00D8: CLRF 06
00DA: MOVF 06,W
00DC: RCALL 001C
00DE: INCF 06,F
00E0: MOVWF 00
00E2: CLRWDT
00E4: BTFSS F9E.4
00E6: BRA 00E2
00E8: MOVWF FAD
00EA: MOVLW 17
00EC: SUBWF 06,W
00EE: BNZ 00DA
00F0: MOVLW 04
00F2: MOVWF 06
00F4: MOVLW FA
00F6: MOVWF 07
00F8: RCALL 006E
00FA: DECFSZ 06,F
00FC: BRA 00F4
.................... //output_high(MUX_Sel2);
.................... printf("Just set mux sel high \n\r");
00FE: CLRF 06
0100: MOVF 06,W
0102: RCALL 0044
0104: INCF 06,F
0106: MOVWF 00
0108: CLRWDT
010A: BTFSS F9E.4
010C: BRA 0108
010E: MOVWF FAD
0110: MOVLW 18
0112: SUBWF 06,W
0114: BNZ 0100
.................... while(TRUE);
0116: BRA 0116
0118: SLEEP
Word 2: 0E0E BROWNOUT WDT128 NOWDT BORV20 PUT
Word 3: 0100 CCP2C1
Posted: Wed Feb 25, 2015 3:20 pm |
couple of 'issues'..
The schematic show a PIC16F877 but code shows 18F452......
which is the real PIC ?
The RSSI PWM output will only ever get to about 3 volts,about 2/3 of the 877 ADC range....
Ringo42
Posted: Wed Feb 25, 2015 3:26 pm |
Google found the old post. Damn my bad memory. I don't remember that issue at all, but it has been a long time since I worked on this.
Yes it really is a 452. I'm not concerned about the 2/3 range stuff.
I'll fix the delay_ms and see if that does it.
Thanks PCMP _________________ Ringo Davis |
Ringo42
Posted: Wed Feb 25, 2015 3:36 pm |
well it is not the delay.
This does not run either
#device adc=10
while(TRUE);
Ringo42
Posted: Wed Feb 25, 2015 3:45 pm |
oops here is the lst
Code: | CCS PCH C Compiler, Version 4.007, 34836 25-Feb-15 16:33
ROM used: 216 bytes (1%)
Largest free fragment is 32552
7 (0%) worst case
Stack: 1 locations
0000: GOTO 006E
006E: CLRF FF8
0070: BCF FD0.7
0072: CLRF FEA
0074: CLRF FE9
0076: MOVLW 40
0078: MOVWF FAF
007A: MOVLW A6
007C: MOVWF FAC
007E: MOVLW 90
0080: MOVWF FAB
0082: BSF FC1.0
0084: BSF FC1.1
0086: BSF FC1.2
0088: BCF FC1.3
008A: CLRF 05
008C: CLRF 06
008E: MOVF 06,W
0090: RCALL 0004
0092: INCF 06,F
0094: MOVWF 00
0096: CLRWDT
0098: BTFSS F9E.4
009A: BRA 0096
009C: MOVWF FAD
009E: MOVLW 07
00A0: SUBWF 06,W
00A2: BNZ 008E
00A4: CLRF 06
00A6: MOVF 06,W
00A8: RCALL 001C
00AA: INCF 06,F
00AC: MOVWF 00
00AE: CLRWDT
00B0: BTFSS F9E.4
00B2: BRA 00AE
00B4: MOVWF FAD
00B6: MOVLW 17
00B8: SUBWF 06,W
00BA: BNZ 00A6
00BC: CLRF 06
00BE: MOVF 06,W
00C0: RCALL 0044
00C2: INCF 06,F
00C4: MOVWF 00
00C6: CLRWDT
00C8: BTFSS F9E.4
00CA: BRA 00C6
00CC: MOVWF FAD
00CE: MOVLW 18
00D0: SUBWF 06,W
00D2: BNZ 00BE
00D4: BRA 00D4
00D6: SLEEP
Word 3: 0100 CCP2C1
Posted: Wed Feb 25, 2015 3:51 pm |
I installed PCH vs. 4.007 and compiled your program above, and I ran it
on a PicDem2-Plus (old version) and it basically worked:
Code: | ÓÓStart
I got a couple garbage characters before the start, but it displayed all
messages in TeraTerm.
I think you're using an LVP programmer. Can you do a Verify and check
if the code was written to the PIC properly ? |
Ringo42
Posted: Wed Feb 25, 2015 3:53 pm |
I'm using an ICD-U64. I just did a verify and it passed. _________________ Ringo Davis |
