P9813 Two Wire RGB LED Strip Driver
sshahryiar
PostPosted: Fri Jan 16, 2015 9:36 pm     Reply with quote
P9813.h
#define data_pin  PIN_A4
#define clock_pin PIN_A5
void P9813_init();
void P9813_clock();
void turn_off_strip();
void send_data(unsigned long long value);
unsigned char make_anti_code(unsigned char value);
void set_colour(unsigned char R, unsigned char G, unsigned char B);
P9813.c
#include "P9813.h"
void P9813_init()
    output_low(data_pin);
    output_low(clock_pin);
    turn_off_strip();
void P9813_clock()
   delay_us(20);
   output_high(clock_pin);
   delay_us(20);
   unsigned char s = 32;
   while(s > 0)
       P9813_clock();
       s--;
   unsigned char s = 0;
   for(s = 0; s < 32; s++)
      if((value & 0x80000000) != 0)
         output_high(data_pin);
      value <<= 1;
      P9813_clock();
  if((value & 0x80) == 0)
   s |= 0x02;
  if((value & 0x40) == 0)
   s |= 0x01;
  return s;
  unsigned long long tmp = 0;
  tmp |= (((unsigned long long)0x03) << 30);
  tmp |= (((unsigned long long)make_anti_code(B)) << 28);
  tmp |= (((unsigned long long)make_anti_code(G)) << 26);
  tmp |= (((unsigned long long)make_anti_code(R)) << 24);
  tmp |= (((unsigned long long)B) << 16);
  tmp |= (((unsigned long long)G) << 8);
  tmp |= ((unsigned long long)R);
  send_data(tmp);
Example Code:
#include <12F615.h>
#device *= 16
#device ADC = 8
#fuses NOWDT, PROTECT, INTRC_IO, NOMCLR, PUT, NOBROWNOUT, IOSC4
#define button   !input(PIN_A3)
#use delay (internal = 4MHz)
#include "P9813.c"
void setup();
unsigned long adc_avg();
   const unsigned char R_table[18] = {4, 44, 87, 128, 164, 195, 221, 240, 251, 255, 251, 240, 221, 195, 164, 128, 87, 44};
   const unsigned char G_table[18] = {221, 240, 251, 255, 251, 240, 221, 195, 164, 128, 87, 44, 4, 44, 87, 128, 164, 195};
   const unsigned char B_table[18] = {221, 195, 164, 128, 87, 44, 4, 44, 87, 128, 164, 195, 221, 240, 251, 255, 251, 240};
   unsigned char n = 0;
   unsigned char i = 0;
   unsigned char R_value = 0;
   unsigned char G_value = 0;
   unsigned char B_value = 0;
   unsigned long d = 0;
   setup();
      d = adc_avg();
      if(button)
          while(button);
          i = 0x00;
          n++;
      if(n > 0x0F)
          n = 0x00;
      if(i > 0x11)
         i = 0x00;
      switch(n)
          case 0x01:
             R_value = R_table[i];
             G_value = 0;
             B_value = 0;
          case 0x02:
             G_value = G_table[i];
             R_value = 0;
             B_value = 0;
          case 0x03:
             B_value = B_table[i];
             G_value = 0;
             R_value = 0;
          case 0x04:
          case 0x05:
              R_value = 0xFE;
             G_value = 0;
             B_value = 0;
          case 0x06:
              G_value = 0xFE;
             R_value = 0;
             B_value = 0;
          case 0x07:
              B_value = 0xFE;
             R_value = 0;
             G_value = 0;
          case 0x08:
              B_value = get_timer0();
             R_value = (get_timer0() + 0x56);
             G_value = (get_timer0() + 0xAC);
          case 0x09:
              B_value = 0xFE;
             R_value = 0xFE;
             G_value = 0xFE;
          case 0x0A:
             R_value = d;
             G_value = 0x00;
             B_value = 0x00;
          case 0x0B:
             G_value = d;
             R_value = 0x00;
             B_value = 0x00;
          case 0x0C:
             B_value = d;
             G_value = 0x00;
             R_value = 0x00;
          case 0x0D:
             R_value = d;
             G_value = d;
             B_value = d;
          case 0x0E:
             R_value = (0xFF - d);
             G_value = (0xFF - d);
             B_value = (0xFF - d);
          case 0x0F:
             B_value = B_table[(get_timer0() >> 4)];
             R_value = R_table[(get_timer0() >> 4)];
             G_value = G_table[(get_timer0() >> 4)];
          default:
              R_value = 0x00;
              G_value = 0x00;
              B_value = 0x00;
      i++;
      turn_off_strip();
      set_colour(R_value, G_value, B_value);
      turn_off_strip();
      delay_ms((d << 2));
void setup()
   disable_interrupts(global);
   setup_ADC(ADC_clock_div_8);
   setup_ADC_ports(sAN0);
   set_ADC_channel(0x00);
   setup_CCP1(CCP_off);
   setup_timer_0(T0_internal);
   setup_timer_1(T1_disabled);
   setup_timer_2(T2_disabled, 0xFF, 0x01);
   set_timer0(0x00);
   set_timer1(0x00);
   set_timer2(0x00);
   P9813_init();
   unsigned char s = 8;
   unsigned long avg = 0;
   while(s > 0)
       read_adc(adc_start_only);
       while(adc_done() == false);
       avg += read_adc(adc_read_only);
       s--;
   avg >>= 3;
   return avg;
Demo Video:
https://www.youtube.com/watch?v=j6gkdTMKIWg
https://www.facebook.com/MicroArena
SShahryiar
