RNR107
High performance PWM on PIC16F1786 |
Posted: Fri Dec 19, 2014 10:12 am |
Hi all,
I am looking for a way to control a servo motor via PWM.
I am currently able to do it using the simple PWM mode, but this only give me a 10bits precision which is not sufficient in this particular application.
I understand from the 16F1786 datasheet that it is possible to get 16 bits using the PSMC module.
1- Am I reading the datasheet right? Can I get 16 bits PWM ?
2- Any example code anywhere I could look at ?
(I know it would be easier to use a 16bit PIC but only have a CCS license for the 8 bits PICs)
Thank you!
RNR |
Posted: Fri Dec 19, 2014 2:51 pm |
It has a 16-bit time base, but I don't see any CCS functions to support
the PSMC controller in the 16F1786.h file. I think you will have to write
your own functions, and write to the PSMC registers.
Are you sure you need that PIC ? Here is a method to get more
resolution for servo pulses, by using the CCP Compare module:
http://www.ccsinfo.com/forum/viewtopic.php?t=44328 |
asmboy
Posted: Fri Dec 19, 2014 3:18 pm |
"servo" covers Lot of territory and you are not very specific.
are we talking about a model airplane style
pulse width- proportional type
positioning servo here ?
though you are calling this "PWM" is it in reality to produce
position control pulses of high resolution and precision?
can you state the make and model of your servo? |
RNR107
Posted: Mon Dec 22, 2014 2:53 am |
asmboy wrote: |
Hi ASMBoy,
The sevo I am using is positioning servo used on model planes I think.
It's an S3001 from Futaba.
It requieres a 20ms periode PWM signal and I am only interested in pulses between 1.2ms and 1.9ms (6 to 9.5% duty).
RNR |
RNR107
Posted: Mon Dec 22, 2014 2:56 am |
PCM programmer wrote: | It has a 16-bit time base, but I don't see any CCS functions to support
Hi PCM Programmer,
This could be an option as long as it let me change the duty on the fly witout losing any pulses during the change...
I'll have a look at that. Could be just what I need... :-) Thank you!
RNR |
