Help - Pointers and Structures in PIC16F1825
CMatic
PostPosted: Fri Dec 12, 2014 9:22 pm     Reply with quote
I am trying to implement a menu system and would like to use structures and functions pointers to access it. I would like to know what is the best way to implement it in PIC16F1825. Thank you for all your comments and suggestions.
PostPosted: Fri Dec 12, 2014 11:21 pm     Reply with quote
I think your post here is a continuation of this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=53192
You should keep it all in one thread and not make multiple threads.
Anyway, I made a sample program shown below, that I think does what
you want. I tested it with compiler vs. 5.033. This program demonstrates
putting a function pointer in a structure. It shows an array of structures
stored in Flash memory and initialized. It shows that the structure
elements can be displayed and that the function pointer works.
Here is the output of the program in MPLAB simulator:
Option1
05
01
02
00
011f
01
Running testfun() function
Test program:
#include <16F1825.h>
#fuses INTRC_IO, NOWDT, BROWNOUT
#use delay(clock=4M)
void testfun(void)
printf("Running testfun() function\r");
typedef char* (*_fptr)(int8);
typedef struct  {
   char text[14];
   char num_menu;
   char UP;
   char DOWN;
   char ENTER;
   _fptr funct_ptr;
   int default_value;
}MenuEntry;
const MenuEntry menu[10]= {
   {"[Main]       ",5,0,0,0,0,0},
   {"Option1      ",5,1,2,0,testfun,1},
   {"Option2      ",5,0,0,0,0,2},
   {"Option3      ",5,0,0,0,0,3},
   {"Option4      ",5,0,0,0,0,4},
   {"[Sub]        ",5,0,0,0,0,5},
   {"Option1      ",5,0,0,0,0,6},
   {"Option2      ",5,0,0,0,0,7},
   {"Option3      ",5,0,0,0,0,8},
   {"Option4      ",5,0,0,0,0,9}
printf("%s \r", menu[1].text);
printf("%x \r", menu[1].num_menu);
printf("%x \r", menu[1].UP);
printf("%x \r", menu[1].DOWN);
printf("%x \r", menu[1].ENTER);
printf("%lx \r",menu[1].funct_ptr);
printf("%x \r", menu[1].default_value);
printf("\r");
(*menu[1].funct_ptr)();
while(TRUE);
CMatic
PostPosted: Sat Dec 13, 2014 9:32 pm     Reply with quote
PCM programmer thanks so very much. I just compiled it with CCS PCM C Compiler, Version 5.026. And its working now. Thank you again your comments were very helpful. Happy Holidays.
