debug monitor not working [solved]
webgiorgio
PostPosted: Sat Dec 06, 2014 10:16 am     Reply with quote
I am using the monitor function for the first time. The "monitor" window stays black, empty, looks like the microcontroller is not transmitting or the ICD non receiving. (I have no oscilloscope, but with the multimeter I see the voltage very unstable around 4,4 to 4,8 volts on the pin).
I have wired the pin6 of the target ICD connector to the pin RC4 of a 16F1825. (there is not RB3, RC4 is the USART TX according to datasheet)
http://ww1.microchip.com/downloads/en/DeviceDoc/40001440D.pdf
I have PCWH 5.032. The Led is flashing correctly, and I can read the value of the variable "sens1" in the tab "Watches" if I "Halt" the execution. All is mounted on a bredboard.
#include <16F1825.h>
#DEVICE ICD=TRUE
#device ADC=10
#use delay(internal=8000000,restart_wdt)
#define LED PIN_C3
#define DELAY 100
#use rs232(DEBUGGER, stream=STREAM_MONITOR, xmit=PIN_C4, rcv=PIN_C4)
int16 sens1, sens2;
   setup_adc_ports(sAN5|sAN6);
   //Example blinking LED program
   while(true)
      output_low(LED);
      delay_ms(DELAY);
      output_high(LED);
      delay_ms(DELAY);
      set_adc_channel(5);
      delay_ms(20);
      sens1=read_adc();
      set_adc_channel(6);
      delay_ms(20);
      sens2=read_adc();
      printf("ABC");
      //printf("\n sens1=%Lu",sens1);
PostPosted: Sat Dec 06, 2014 10:53 am     Reply with quote
1. the debug monitor does not use the UART
2. Enable debug then click the question mark on the Debug menu bar to open Help
3. In Help Table of Contents go to Debugger then Debugger Windows.
4. Info tells how to designate the Stream Monitor pin and enable the monitor
webgiorgio
PostPosted: Sat Dec 06, 2014 11:03 am     Reply with quote
Nothing happens when I click the quesion mark.
Neither I get anything out of the Help menu (I guess this is a problemm of my computer...with windows xp sp2).
I've to try install on another pc
PostPosted: Sat Dec 06, 2014 11:10 am     Reply with quote
Locate and dbl-click the file pcw.chm in the PICC folder then
> Debugger >> Debugger Windows >> Monitor
webgiorgio
PostPosted: Sun Dec 07, 2014 9:14 am     Reply with quote
Solved! Very Happy
The code and the connections were fine.
The problem was that the monitor function was Disabled in the debug configuration.
So I just did "Debug"->"Debug Configure"->"Monitor Enabled" -> "True".
webgiorgio
PostPosted: Sun Dec 07, 2014 1:11 pm     Reply with quote
if some characters of the strings received in the debug monitor are corrupted, solve with this: http://www.ccsinfo.com/forum/viewtopic.php?t=22089
