Array define...
hmmpic
Array define...
PostPosted: Tue Nov 25, 2014 4:25 am     Reply with quote
Hi
Now I'm confused, how to define this array correct, it's only a demo for my problem?
const char AString[?][?]={"12","1234","123","1","12345678"};
I can put a little more information:
const char AString[][9]={"12","1234","123","1","12345678"}; //Here I put the longest array in it's 8+1. Now the compiler calculate the rest. This waste a lot of space.
const char *AString[5]={"12","1234","123","1","12345678"};//This is pointer to 5 string, wont work in CCS?
How to define with minimum over heat.
Hints?
PostPosted: Tue Nov 25, 2014 9:12 am     Reply with quote
Read the manual.
Look at the section "Using Program Memory for Data".
Look at what the '*' specifier is used for.
hmmpic
PostPosted: Tue Nov 25, 2014 12:40 pm     Reply with quote
Thanks for hints:-)
The solution is on page 34 in the CCS PDF:
The compiler allows a non-standard C feature to implement a constant array of variable length
strings.
The syntax is:
const char id[n] [*] = { "string", "string" ...};
Where n is optional and id is the table identifier.
For example:
const char colors[] [*] = {"Red", "Green", "Blue"};
