Please. Little Problem.
rugan035
PostPosted: Fri Nov 14, 2014 7:18 pm     Reply with quote
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Users\MR\Desktop\a\a.mcs".
Clean: Done.
Executing: "C:\Program Files (x86)\PICC\CCSC.exe" +FM "delay.c" +DF +LN +T +A +M +Z +Y=9 +EA
Could not spawn language tool. Check command-line options. (740)
BUILD FAILED: Sat Nov 15 03:03:24 2014
I'm doing the build process.But giving the above error. What can I do?
Thanks.
asmboy
PostPosted: Sat Nov 15, 2014 6:56 am     Reply with quote
start here:
http://www.ccsinfo.com/forum/viewtopic.php?t=26245
then follow the directions shown under topic 4 and 5
rugan035
PostPosted: Sat Nov 15, 2014 1:31 pm     Reply with quote
Oh sorry. I didn't know.
Complier version MPLAB IDE V8.91 using. Standard run. Target PIC16F877A.
This error giving every program. Does not matter.
I choose Set Language Tool Locations: CCS C Complier for PIC10/12/14/16/...dsPIC
PostPosted: Sat Nov 15, 2014 3:53 pm     Reply with quote
Post your operating system.
asmboy
this is the CCS forum not the MPLAB forum.
AND
I do believe the errors you show are MPLAB based
and you still have given nothing that
anyone could reasonably help you with, including things like your CCS version number and the CODE that you says causes you trouble.
Too bad, but at the moment "Great Swami" the mind reader
has not logged in lately, so
i think you are as they say S.O.O.L.
based on the amazingly near total lack of information you post.
That means i share your sentiment when you say
"i don't know" , and am convinced that you are 100% correct
as well as perhaps lacking a clue too, when you say that.
Best of luck in your project.
PostPosted: Sun Nov 16, 2014 1:35 am     Reply with quote
A search on the MPLAB forum, will find this error occurring a lot.
Try one thing. Create a shortcut to your MPLAB, and then right click this, select 'properties'. Then in the 'Compatibility' tab, tick 'Run this program as administrator', and select 'Run this program in compatibility mode for:' - select Windows XP (Service Pack 3). Say 'OK', and then see if the problem disappears.
I think it occurs because the program doesn't have the permissions to access the required files.
