Em4150 parity - *** Duplicate post
olivervd
PostPosted: Tue Oct 21, 2014 1:18 am     Reply with quote
I have a same problem with my read RFID.
I use PCW compiler(CCS).
My hardware is the recommended EM Marin for Em4150. If you need my schematic I can send for email.
I use em4095 + pic16f876A.
When I run my circuit emerge the next message "ERROR PARITY".
I can read em4100 and em4102, also I can write em4150, but I can't read em4150.
Can you help me?
This is my email: olivercharmander@hotmail.com
This is my code:
#include <16F876a.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT,NOPUT
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=RS)
#include <em4095.c>
#include <em4102.c>
#include <em4150.c>
#include <stdlib.h>
int32 msg;
int8 err;
int32 tagNum=0x00;
 int8  tag_adr=5;// tag_adr is between 0-33
void main(void) {
 rf_init();
   rf_powerUp();
  while(true) {
// restart_wdt();
      //LOGIN
      err = login_4150(0x00);
     // resultado=readProtect_4150(1, 2);
    //  printf("valor de Resultado = %d\n\r",resultado);
   //   printf("valor de ERR LOGIN = %d\n\r",err);
      switch(err) {
      case ERR_OK: printf("\n\rOK LOGIN"); break;
      case ERR_LIW:printf("\n\rLIW LOGIN"); break;
      case ERR_NAK:printf("\n\rNAK LOGIN"); break;
      case ERR_PARITY: printf("\n\rPARITY LOGIN"); break;
      puts(msg,RS);
 //ESCRITURA
   tagNum = make32(0x01,0x02,0x03,0x04);
     tag_adr=5;
     err = write_4150(tagNum,tag_adr);
      switch(err) {
      case ERR_OK: printf("\n\rOK ESCRITURA");
      case ERR_LIW:printf("\n\rLIW ESCRITURA"); break;
      case ERR_NAK: printf("\n\rNAK ESCRITURA"); break;
      case ERR_PARITY: printf("\n\rPARITY ESCRITURA"); break;
      puts(msg,RS);
      PWprotect_4150(FALSE);
err=setPassword_4150(oldPassword, newPassword);
printf("valor de ERR Password = %d\n\r",err);
   //LECTURA
  err = read_4150(&msg,5);
tagNum=msg;
      switch(err) {
      case ERR_OK: printf("Data: %lu \n\r", tagNum);
      printf("Data: %x \n\r", tagNum);
      case ERR_LIW: printf("\n\rLIW LECTURA");
      case ERR_NAK: printf("\n\rNAK LECTURA");
      case ERR_PARITY:
      printf("\n\rPARITY LECTURA");
     //printf("PARITY\n\r");
      puts(msg,RS);
  //RESET
   err= reset_4150() ;
   switch(err) {
      case ERR_OK: printf("\n\rOK RESET");
      case ERR_LIW: printf("\n\rLIW RESET");
      case ERR_NAK: printf("\n\rNAK RESET");
