| olivervd
				|  Posted: Tue Oct 21, 2014 1:18 am |   |
				| Hello, I have a same problem with my read RFID.
 I use PCW compiler(CCS).
 My hardware is the recommended EM Marin for Em4150. If you need my schematic I can send for email.
 I use em4095 + pic16f876A.
 When I run my circuit emerge the next message "ERROR PARITY".
 I can read em4100 and em4102, also I can write em4150, but I can't read em4150.
 Can you help me?
 This is my email: olivercharmander@hotmail.com
 This is my code:
  	  | Code: |  	  | #include <16F876a.h> #fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT,NOPUT
 #use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=RS)
 #include <em4095.c>
 #include <em4102.c>
 #include <em4150.c>
 #include <stdlib.h>
 int32 msg;
 int8 err;
 int32 tagNum=0x00;
 int8  tag_adr=5;// tag_adr is between 0-33
 void main(void) {
 rf_init();
 rf_powerUp();
 while(true) {
 // restart_wdt();
 //LOGIN
 err = login_4150(0x00);
 // resultado=readProtect_4150(1, 2);
 //  printf("valor de Resultado = %d\n\r",resultado);
 //   printf("valor de ERR LOGIN = %d\n\r",err);
 switch(err) {
 case ERR_OK: printf("\n\rOK LOGIN"); break;
 case ERR_LIW:printf("\n\rLIW LOGIN"); break;
 case ERR_NAK:printf("\n\rNAK LOGIN"); break;
 case ERR_PARITY: printf("\n\rPARITY LOGIN"); break;
 puts(msg,RS);
 //ESCRITURA
 tagNum = make32(0x01,0x02,0x03,0x04);
 tag_adr=5;
 err = write_4150(tagNum,tag_adr);
 switch(err) {
 case ERR_OK: printf("\n\rOK ESCRITURA");
 case ERR_LIW:printf("\n\rLIW ESCRITURA"); break;
 case ERR_NAK: printf("\n\rNAK ESCRITURA"); break;
 case ERR_PARITY: printf("\n\rPARITY ESCRITURA"); break;
 puts(msg,RS);
 PWprotect_4150(FALSE);
 err=setPassword_4150(oldPassword, newPassword);
 printf("valor de ERR Password = %d\n\r",err);
 //LECTURA
 err = read_4150(&msg,5);
 tagNum=msg;
 switch(err) {
 case ERR_OK: printf("Data: %lu \n\r", tagNum);
 printf("Data: %x \n\r", tagNum);
 case ERR_LIW: printf("\n\rLIW LECTURA");
 case ERR_NAK: printf("\n\rNAK LECTURA");
 case ERR_PARITY:
 printf("\n\rPARITY LECTURA");
 //printf("PARITY\n\r");
 puts(msg,RS);
 //RESET
 err= reset_4150() ;
 switch(err) {
 case ERR_OK: printf("\n\rOK RESET");
 case ERR_LIW: printf("\n\rLIW RESET");
 case ERR_NAK: printf("\n\rNAK RESET");
