12f508 not working PIN_B2 ? // problem T0CKI ?
1980best
PostPosted: Sat Oct 11, 2014 7:03 pm     Reply with quote
#include "12f508.h"
#Fuses NOWDT
#use delay(internal=4MHz)
#use STANDARD_IO( B )
#use FIXED_IO( B_outputs=PIN_B2 )
#define LED0 PIN_B0
#define LED1 PIN_B1
#define LED2 PIN_B2
#define DELAY 500
   while(true)
      output_low(LED0);
      output_low(LED1);
      output_low(LED2);
      delay_ms(DELAY);
      output_high(LED0);
      output_high(LED1);
      output_high(LED2);
      delay_ms(DELAY);
PostPosted: Sat Oct 11, 2014 8:19 pm     Reply with quote
See the set_options() macro in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=33336
That thread is about the 12F509 but the same solution will work
for the 12F508.
PostPosted: Sun Oct 12, 2014 2:22 am     Reply with quote
You don't actually need this macro.
Simply add:
setup_timer_0(T0_INTERNAL);
to your code. This turns the T0CS and T0SE bits off.
They default to waking set as '1', which connects GP2 to the timer. T0CS, "overrides TRIS on the T0CKI pin" (quote from data sheet).
Gabriel
PostPosted: Sun Oct 12, 2014 7:01 pm     Reply with quote
Isn't this part OTP?
Not very useful when prototyping.... i have 5 bricked by my ignorance.
CCS PCM 5.078 & CCS PCH 5.093
PostPosted: Mon Oct 13, 2014 12:42 am     Reply with quote
It's a very old part.
OTP. There was an EEPROM version available for development, but this was expensive, and used UV EEPROM, so very slow to erase.
For any modern use, far better to get one of the more modern replacements. Faster clocks, FLASH etc..
Ten years ago, it was a useful small part, because it was very cheap. It was one of the first PIC's to go under $0.50. Now it is replaced by versions, that are just as cheap, and have better abilities. There are devices available for less money, that have 8* the clock rate, FLASH memory, and one or more extra peripherals. If you look at the 12F1571, it is cheaper, has 5* as much RAM, and over twice as much ROM, has comparators, ADC's, extra timers, DAC, bandgap Vref, PWM. Given that it costs less 'no contest'. The only reason to use the 508, would be if you have a drawer full.....
ezflyr
PostPosted: Mon Oct 13, 2014 5:07 am     Reply with quote
What are you guys smoking Very Happy ? The 12f508 is a flash based part (note the 'f'), and can be reprogrammed multiple times with ICSP. You guys must be thinking of the 12c508, which *is* OTP!
John
Gabriel
PostPosted: Mon Oct 13, 2014 6:18 am     Reply with quote
I just checked my parts bin, indeed the bricks i own are the "C" version...
Ezflyr is right.
PostPosted: Mon Oct 13, 2014 7:35 am     Reply with quote
I still would not use it, on the cost/performance basis though.....
PostPosted: Mon Oct 13, 2014 8:57 am     Reply with quote
Wow.. I just looked in my drawer and found 2 of the JW aka Windowed units !!!
asmboy
PostPosted: Mon Oct 13, 2014 11:14 am     Reply with quote
at mouser the
12F1572 is 1 penny more than
the 12F508 @ Q=100
its like comparing a rocket launcher to a pea shooter.
http://ww1.microchip.com/downloads/en/DeviceDoc/40001723C.pdf
PostPosted: Mon Oct 13, 2014 11:33 am     Reply with quote
Right, but 12F1572 requires a programmer upgrade (if you don't have it)
to PICkit 3 or ICD3 or the equivalent.
Furthermore, it requires an upgrade to MPLAB X (it's not supported by
MPLAB 8.92), with a multi-day learning curve and frustrations.
The expense and the time may not be worth it, if you're a hobbyist or
doing a one-off project.
