rusty_shackleford
#fuses |
Posted: Tue Sep 16, 2014 3:08 pm |
I wonder if there is a list of the #fuse abbreviations for each device and what they mean. a cheat sheet of some kind. |
stinky
Joined: 05 Mar 2012 Posts: 99 Location: Central Illinois
Posted: Tue Sep 16, 2014 3:22 pm |
They correlate pretty closely to the Configuration Word(s) in your device's datasheet. That combined with the device header file have been the magic cheat sheet for me. |
Posted: Tue Sep 16, 2014 3:57 pm |
Do you have the CCS IDE compiler (PCW, PCWH, PCWHD, etc.) ?
If so, look for fuses.txt in the CCS directory.
If you don't have it, do a web search for this:
Quote: | datadynamics fuses.txt |
A company that sells the compiler in Japan has posted it. |
jeremiah
Posted: Tue Sep 16, 2014 6:03 pm |
It's also worth noting that if you have the IDE, there is an option to display all the fuses for your particular chip with a description of what they are for.
It's View Configuration Bits in the most recent IDE version. |
