Character String to Hex
rhinojo7
PostPosted: Thu Jul 27, 2006 3:06 pm     Reply with quote
Hello all, what I'm trying do is read in a character string from the PC through the serial port. The character coming in form the PC is supposed to be Hex Data. My problem is how do I convert the string of data into hex.
here is an example of what I'm trying to do:
Lets say this is the string coming in from the PC:
1A2B3C4D5E
What I want to do is make that string into the following (I'm using int8 as the type for the data: int8 data[5];)
data[0]=0x1A
data[1]=0x2B
data[2]=0x3C
data[3]=0x4D
data[4]=0x5E
Does anybody have any idea of how to do that. I would really appreciate the help.
rhinojo
PostPosted: Thu Jul 27, 2006 3:18 pm     Reply with quote
CCS has a function called atoi_b16() that will do it. It's in the Loader.c
file. Look in this folder: c:\program files\picc\drivers
kel
This may help
PostPosted: Thu Jul 27, 2006 6:50 pm     Reply with quote
The following function works fine but it has got its side effect.
void String2Hex(char *arr, byte StartPos, byte EndPos){
             byte counter;
             byte cnt;
             char buff[5]="";/*clear the buffer.you are interested in 0xXX*/
                for(counter=StartPos; counter < EndPos; counter++)
                       buff[counter]=arr[counter];
                   for(cnt=StartPos; cnt < EndPos; cnt++)
                       printf("0X%c",buff[cnt]);
 /*Test program*/
               char xc[]="1A2B3C4D5E";
               String2Hex(xc, 0, 2)   /*prints 0X1A */
                String2Hex(xc, 1, 3)  /*prints 0x2B */
Hope this helps. PCM programmer please improve this function should you find any flause.I have not tested this function under the CCS enviroment but have tested it under GCC c compiler and it works fine.
cheers
kel
The improved version.
PostPosted: Sun Jul 30, 2006 6:36 pm     Reply with quote
This function checks for the difference of start and end position. if it's more than two, it displays error message. This way the mn cannot be more than 2 especially if data is required as follows:
data[0]=0x1A
data[1]=0x2B
data[2]=0x3C
data[3]=0x4D
data[4]=0x5E
             byte counter;
             byte cnt;
            byte mn=Endpos-Startpos;
// to restrict the function to print only 2 hex numbers, the mn must be //equal to 2(mn=2)
          if(mn>1 && mn <3) {
                    Sartpos=0;
                    Endpos=2; /*print 2 hex only*/
               } else  printf("Error mn bust be 2 !!");
 /*Test program*/
thientaisodo
PostPosted: Tue Sep 02, 2014 3:16 am     Reply with quote
This may be help for anyone.
Function convert string (8bit) to hex (8bit)
char   demo_string[2]="A0";
int8    demo_hex;
demo_hex=atoh(demo_string);
// demo_hex = 0xA0
signed int atoh(char *s)
   unsigned int temp[2], count, result;
   char c;
   result = 0;
   count = 0;
   for(count=0;count<2;count++)
      c = s[count];
      if (c >= '0' && c <= '9')
         temp[count] = c - '0';
      else  if (c >= 'A' && c <= 'F')
         temp[count] = c - '7';
      else  if (c >= 'a' && c <= 'f')
         temp[count] = c - 'W';
         temp[count] = 0;
   result = (((temp[0] << 4) & 0xf0)|(temp[1] & 0x0f));
   return(result);
