Rotate LED
Kreg
Rotate LED
PostPosted: Wed Aug 27, 2014 2:55 am     Reply with quote
Hi all !
I would like to ask a question.
Actually, I have just bought a PICKIT3 with a 18F45K20
I would like to 'flash and rotate' LED.
Can you help me ? I am a beginner.
All my LEDs are connected to the port D (there is 7 LED)
I would like to introduce an array of the form
const int LED_LookupTable[8]={0,1,2,3,4,5,6,7};
Then, sending the led_data in sequence to portD will light each each LED in turn.
Here is my code but it doesn't work :
/**  I  N  C  L  U  D  E  S  **************************************************/
#include  <18F45K20.h>
#FUSES INTRC_IO,NOWDT,NOLVP
#USE delay (CLOCK=1MHz)
#WORD LATD=0xF8C
#WORD PORTD=0xF83
#BIT led=LATD.0
#BIT led1=LATD.1
#BIT led2=LATD.2
#BIT led3=LATD.3
#BIT led4=LATD.4
#BIT led5=LATD.5
#BIT led6=LATD.6
#BIT led7=LATD.7
void main(){
   int LED_Number=0;
   SET_TRIS_D(0b00000000);
   led7.LED_LookupTable[LED_Number];
   led7=1;
   LED_Number++;
   if(LED_Number==8){
      LED_Number=0;
   delay_ms(2000);
And the error about led7=1;
Expecting a structure/union
How can I fix that ?
Kreg
PostPosted: Wed Aug 27, 2014 3:06 am     Reply with quote
#WORD LATD=0xF8C
#WORD PORTD=0xF83
#BIT led=LATD.0
#BIT led1=LATD.1
#BIT led2=LATD.2
#BIT led3=LATD.3
#BIT led4=LATD.4
#BIT led5=LATD.5
#BIT led6=LATD.6
#BIT led7=LATD.7
void main(){
   LATD=0;
   int LED_Number=0;
   int i=0;
while(1){
   for(i=0;i<8;i++){
      bit_set(LATD,i);
   i=0;
   LATD=0;
This code works but I don't use the array unfortunately
PostPosted: Wed Aug 27, 2014 1:33 pm     Reply with quote
This code lights up LEDs on PortB, bits 0 to 3. They are turned on
sequentially. Once turned on, the Leds stay on. This program
shows how to read from an array. I used PortB because that's the
way my hardware board is setup.
#include <18F452.h>
#fuses XT, BROWNOUT, PUT, NOWDT, NOLVP
#use delay(clock=4M)
#byte PORTB = getenv("SFR:PORTB")
int i;
output_b(0x00);  // All Leds off initially, and PortB TRIS = all outputs
for(i = 0; i < 4; i++)
    bit_set(PORTB, LED_LookupTable[i]);
