I need your opinion in my program that i just wrote. thx u.
mourad
PostPosted: Mon Apr 07, 2014 2:09 pm     Reply with quote
//RJ45 cable tester
#include "demo.h"
#byte PORTA =  0x05
#byte PORTB =  0x06
#byte PORTC =  0x07
#byte PORTD =  0x08
int1 TestSTPair(int8 p)             // Test traight-through pair p
   int address;
   address = p<<1;
// First half
   bit_set(PORTD,address);          // test High
   if (!bit_test(PORTC,address))
      return 0;
   bit_clear(PORTD,address);        // test Low
   if (bit_test(PORTC,address))
      return 0;
// Second half
   bit_set(PORTD,address+1);        // test High
   if (!bit_test(PORTC,address+1))
      return 0;
   bit_clear(PORTD,address+1);      // test Low
   if (bit_test(PORTC,address+1))
      return 0;
   return 1;
void TestSTCable()               // Test traight-through cable
   int8 pair;
   PORTD = 0;
   PORTB = 0;
   for (pair = 0; pair < 4; pair++)       // scan pairs
      if (TestSTPair(pair) && bit_test(PORTA,pair)) // selected & connected?
         bit_set(PORTB,pair+4);     // turn on LED
      delay_ms(500);       // wait a bit
      PORTB = 0;
int1 TestCOPair(int8 p)          // Test crossover pair p
   switch (p)
      case 0:  bit_set(PORTD,0);          // test High
               if (!bit_test(PORTC,4))
                  return 0;
               bit_clear(PORTD,0);        // test Low
               if (bit_test(PORTC,4))
                  return 0;
               bit_set(PORTD,2);        // test High
               if (!bit_test(PORTC,5))
                  return 0;
               bit_clear(PORTD,2);      // test Low
               if (bit_test(PORTC,5))
                  return 0;
      case 1:  bit_set(PORTD,4);          // test High
               if (!bit_test(PORTC,0))
                  return 0;
               bit_clear(PORTD,4);        // test Low
               if (bit_test(PORTC,0))
                  return 0;
               bit_set(PORTD,5);        // test High
               if (!bit_test(PORTC,2))
                  return 0;
               bit_clear(PORTD,5);      // test Low
               if (bit_test(PORTC,2))
                  return 0;
      case 2:  bit_set(PORTD,6);          // test High
               if (!bit_test(PORTC,3))
                  return 0;
               bit_clear(PORTD,6);        // test Low
               if (bit_test(PORTC,3))
                  return 0;
               bit_set(PORTD,7);        // test High
               if (!bit_test(PORTC,1))
                  return 0;
               bit_clear(PORTD,7);      // test Low
               if (bit_test(PORTC,1))
                  return 0;
      case 3:  bit_set(PORTD,3);          // test High
               if (!bit_test(PORTC,6))
                  return 0;
               bit_clear(PORTD,3);        // test Low
               if (bit_test(PORTC,6))
                  return 0;
               bit_set(PORTD,1);        // test High
               if (!bit_test(PORTC,7))
                  return 0;
               bit_clear(PORTD,1);      // test Low
               if (bit_test(PORTC,7))
                  return 0;
   return 1;
void TestCOCable()      //Test crossover cable
   int8 pair;
   PORTD = 0;
   PORTB = 0;
      if (TestCOPair(pair) && bit_test(PORTA,pair)) // selected & connected?
      PORTB = 0;
#int_EXT
void EXT_isr()    // External interrupt service routine
   if (bit_test(PORTB,1))
      TestSTCable(); // go and test straight-through cable
      TestCOCable(); // go and test crossover cable
   int8 counter;
   ///////////////////////// S E T U P ///////////////////////////
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
   setup_timer_1(T1_DISABLED);
   PORTA = 0;
   PORTB = 0;
   PORTC = 0;
   PORTD = 0;
   set_tris_a(0xFF);
   set_tris_b(0x0F);
   set_tris_d(0x00);
   set_tris_c(0xFF);
   ext_int_edge( H_TO_L );
   enable_interrupts(INT_EXT);
   enable_interrupts(global);
   // blink all LEDs ///////////////////////////
   for (counter=0;counter<4;counter++)
      bit_set(PORTB,counter+4);
      PORTB=0;
      Sleep();             // Go to sleep
      delay_cycles(1);     // NOP
PostPosted: Mon Apr 07, 2014 2:21 pm     Reply with quote
Those routines came from here:
http://borsfeco.no-ip.biz/Datasheets/Books/UTP%20cables.pdf
Aurbo
Re: I need your opinion in my program that i just wrote. thx
PostPosted: Sun Aug 17, 2014 10:23 am     Reply with quote
Could you demonstrate how you'd take the results and display them on an LCD instead of just LED's?
The LED output looks so mid 2006ish...
Or perhaps how to code the S1 switch bank to use keypad input variables instead to free up those pins.
mourad wrote:
//RJ45 cable tester
#include "demo.h"
#byte PORTA =  0x05
#byte PORTB =  0x06
#byte PORTC =  0x07
#byte PORTD =  0x08
   int address;
   address = p<<1;
// First half
      return 0;
      return 0;
// Second half
      return 0;
      return 0;
   return 1;
   int8 pair;
   PORTD = 0;
   PORTB = 0;
      PORTB = 0;
   switch (p)
                  return 0;
                  return 0;
                  return 0;
                  return 0;
                  return 0;
                  return 0;
                  return 0;
                  return 0;
                  return 0;
                  return 0;
                  return 0;
                  return 0;
                  return 0;
                  return 0;
                  return 0;
                  return 0;
   return 1;
   int8 pair;
   PORTD = 0;
   PORTB = 0;
      PORTB = 0;
#int_EXT
   int8 counter;
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   PORTA = 0;
   PORTB = 0;
   PORTC = 0;
   PORTD = 0;
   set_tris_a(0xFF);
   set_tris_b(0x0F);
   set_tris_d(0x00);
   set_tris_c(0xFF);
      PORTB=0;
