evelikov92
Problem with DS18B20 |
Posted: Wed May 06, 2015 1:44 pm |
Hi everybody
I using pic18f6722, 20x4 lcd with this driver http://www.ccsinfo.com/forum/viewtopic.php?t=24661&highlight=flex and ds18b20 with this driver http://www.ccsinfo.com/forum/viewtopic.php?t=28425&highlight=ds18b20
I reading for problem with ds18b20 which is printing wrong temperature.
My problem is other. When I started program on device is working to ds1820_read() function and after that is stopped work.
I started the program in Proteus and is working ok.
I testing to write in LCD something before and after ds1820_read() function, and is display only text before function.
My question is what the problem probably is, the hardware or the software.
Probably is the temperature sensor is not working, and that is problem, or is the software, the fuses is wrong.
Here is my code simple code
This is the c file
#include "main.h"
#use delay(clock=32000000)
#include <flex_lcd.c>
#include <one_wire.c>
#include <ds1820.c>
float temperature;
setup_oscillator(OSC_32MHZ);
lcd_gotoxy(2, 2);
printf(lcd_putc, "123");
temperature = ds1820_read();
printf(lcd_putc,"\fTemperature: %3.1f", temperature);
printf(lcd_putc, "456");
This is the h file
#include <18F6722.h>
#device adc=12
#FUSES BORV25 //Brownout reset at 2.5V
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES NOXINST //Extended set extension and Indexed Addressing mode enabled
#FUSES BBSIZ1K //1K words Boot Block size
Posted: Wed May 06, 2015 3:58 pm |
This means the code is not returning from the ds1820_read() function.
The only thing that could cause this problem is the busy loop:
while (busy == 0)
busy = onewire_read();
So it could be a hardware problem. Check the connections to the
ds18b20. Do you have a 4.7K pull-up resistor on the DQ line ?
This is required. |
Gabriel
Posted: Wed May 06, 2015 6:20 pm |
Code: | result = (float) temp3 / 2.0; //Calculation for DS18S20 with 0.5 deg C resolution
// result = (float) temp3 / 16.0; //Calculation for DS18B20 with 0.1 deg C resolution |
Make sure you select the proper option, which is the later(commented) option for your sensor.
G. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
evelikov92
Posted: Thu May 07, 2015 3:39 am |
PCM programmer wrote: | Quote: |
while (busy == 0)
This is required. |
I have resistor, but is only 0.7K, and connection is OK. |
Posted: Thu May 07, 2015 5:30 am |
You are overloading the chip....
Though the low resistor means quick charging times for the capacitor, it also means more current than the chip is rated to pull down when signalling. Read the data sheet. For high pull up currents, they recommend using a FET, so it can be switched off when the chip is signalling. The suggested standard resistor is 4.7KR. The chip is not rated to pull down more than 4mA. |
