In mcp2515, I want to 100Kbps baud rate value. What should be the correct settings for it?
Thank You
ezflyr
Posted: Wed Aug 13, 2014 3:46 am
Wouldn't it be better to answer this question yourself by reading the data sheet, rather than coming here to be spoon fed an answer?
John
Posted: Wed Aug 13, 2014 12:14 pm
As a hint, many people use the MBTime utility program to help them
calculate the CAN Bus baud rate parameters:
http://www.intrepidcs.com/support/mbtime.htm
The description of the program and the download link are on the right side
of the webpage. It works with MCP2515.
