erhane
Where the integer gets its first value?[SOLVED] |
Posted: Sat Jul 19, 2014 11:55 am |
Hello friends, i have that source code but couldnt figure out where "decelLocation" integer gets its first value? It says it is predefined but defined where?
Value of "decelLocation" is 6400.
Thank You!
here is code:
#include <18F452.h>
#device adc=8
#FUSES H4 //High speed osc with HW enabled 4X PLL
#FUSES NOOSCSEN //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PUT //Power Up Timer
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#use delay(clock=32000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors)
#define ENGINE_RATE 25000 // be sure timer interrupt matches this
#define SPEED_OFFSET 16777216 // 2^24 The is the offset of the accumulator 2^24 units = 1 step
#define PIN_X_STEP PIN_A1 // pin corrector to step of stepper board
#define PIN_X_DIR PIN_A2 // pin connected to direction pin of stepper board
#define DIRECTION_FORWARD 1
#define DIRECTION_REVERSE -1
signed int32 currentLocation; // store current location in steps so we can use absolute moves
int32 decelLocation; // pre-calculated point we start to decelerated
signed int8 motionDirection; // what direction do we move 1 = fwd -1 = rev
short bEnableMotion; // this turns on/off the 25kHz Pulse Engine
short bDecel; // in decel mode
int32 currentSpeed; // current speed in accum units per engine tick
int32 accel; // accel rate in accum units per engine tick
int32 maxSpeed; // max speed in accum units per tick
int32 accumulator;
signed int32 targetLocation; // target position in steps
long moveAccelSteps; // accel rate in steps / sec /sec
long moveMaxSpeedSteps; // max speed in steps /sec
// this is the pulsing engine...the the file header for more info
#int_TIMER2
void TIMER2_isr(void)
// we only do anything if this motion is enabled and we are not at the target position
if (bEnableMotion && (currentLocation != targetLocation) )
// set the current speed
// If we are before the decel point we accelerate or coast
// else we decel
if (currentLocation == decelLocation)
bDecel = true;
if (!bDecel)
// if we are not at max speed and accel to the speed
if (currentSpeed < maxSpeed)
currentSpeed += accel;
else // decel
currentSpeed -= accel;
if (currentSpeed <= 0) // never let it get to zero otherwise we could get stuck
currentSpeed = accel;
accumulator += currentSpeed;
//see if we have accumulated enough for a step step
If (accumulator > SPEED_OFFSET)
currentLocation += motionDirection;
output_high(PIN_X_STEP); // turn on step pin
delay_us(4); // wait a while
output_low(PIN_X_STEP); // turn it off
accumulator -= SPEED_OFFSET;
bEnableMotion = false;
/* this is the simple "motion planner". It does all the intesive calulations
It calculated the acceleration per engine tick
It calculated the max speed per engine tick
It determines the motion direction
It resets the current speed to 0
It turns on the Pulse Engine
void doMotion()
float tempAccel;
float tempMaxSpeed;
float t;
int32 distToTarget;
int32 accelDist;
distToTarget = abs(targetLocation - currentLocation); // figure out the distance we will travel on this move
tempAccel = moveAccelSteps;// * stepsInch; // in steps per sec
tempAccel = tempAccel / (ENGINE_RATE * ENGINE_RATE);
tempAccel = tempAccel * SPEED_OFFSET;
accel = (int32)tempAccel;
tempMaxSpeed = moveMaxSpeedSteps;
tempMaxSpeed = (tempMaxSpeed / ENGINE_RATE) * SPEED_OFFSET;
maxSpeed = (int32)tempMaxSpeed;
//determine Accel distance
// d = 1/2 a t^2
t = (float)moveMaxSpeedSteps / (float)moveAccelSteps;
accelDist = (moveAccelSteps / 2) * t * t;
// determine the direction
if (targetLocation > currentLocation)
motionDirection = DIRECTION_FORWARD;
decelLocation = currentLocation + decelLocation;
output_low(PIN_X_DIR);
if (accelDist >= distToTarget / 2)
decelLocation = targetLocation - distToTarget / 2;
decelLocation = targetLocation - accelDist;
motionDirection = DIRECTION_REVERSE;
decelLocation = currentLocation - decelLocation;
output_high(PIN_X_DIR);
decelLocation = targetLocation + distToTarget / 2;
decelLocation = targetLocation + accelDist;
delay_us(4); // time for direction to "take" before steps start
bDecel = false;
currentSpeed = 0; // initialize this
bEnableMotion = true; // all set time to move
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_1,159,2);
setup_timer_3(T3_INTERNAL|T3_DIV_BY_1);
currentLocation = 0;
//enable_interrupts(INT_RDA);
while(true)
moveAccelSteps = 1000;
moveMaxSpeedSteps = 2000;
targetLocation = 200 * 8;
doMotion();
delay_ms(2000);
moveAccelSteps = 50000;
moveMaxSpeedSteps = 20000;
targetLocation = 0;
doMotion();
delay_ms(1500);
Posted: Sat Jul 19, 2014 2:16 pm |
You miss-read.
It doesn't say it is predefined. It says it is pre-calculated.
It is calculated from the distance to target, as soon as the motion code is called. |
Posted: Sat Jul 19, 2014 2:45 pm |
It should be initialized to some value. Since it's not initialized, it probably
is set to 0 upon power-up (due to the behavior of the PIC's silicon).
But you shouldn't depend upon that.
In his code in main(), he initializes these two variables as shown:
In his doMotion() routine, the first 'if' statement is this:
Code: | // determine the direction
output_low(PIN_X_DIR); |
Because 1600 is greater than 0, the if() statement will be executed.
The 'currentLocation' is added to the existing value of 'decelLocation',
but 'decelLocation' was never initialized. That's not good.
Probably you should just initialize it to 0 at the beginning of main().
You got that code from this page:
http://www.buildlog.net/pic/pic_basic_motion.html
He has a "contact" email address on that page. Why not ask him about it ?
Also, he has this fuse, which is probably a mistake:
Hardly anyone has a LVP programmer. Change it to NOLVP for safety. |
Posted: Sun Jul 20, 2014 3:05 am |
Look at it again.
The first calc you point to, is thrown away!. Just a couple of lines later you have:
(and the inverse example for when moving in the other direction).
This sets decelLocation, based based on where you want to go 'to', relative to where you 'are'.
The value for decelLocation, calculated in the first line, is never used (just wasted code....).
So it is 'precalculated'. |
