Torello
How to get PIC24 running 32Mhz *solution found* |
Posted: Wed Jul 02, 2014 2:55 pm |
What do I need to add/change to get the pic running on 32Mhz? Code below runs on 16 Mhz. I see pulses of 250ns on my scope.
The pic 24 uses 2 clock tics per instruction, so on 32Mhz the instruction time should be 62.5ns. The pulse uses 2 assembler instructions. So I should measure 125ns pulses instead of 250ns.
I also tried the #use delay(clock=32000000).. neither
and indeed changing the number to 16000000 gives also 250ns pulses...
#include <24FJ128GC006.h>
#FUSES NOJTAG //JTAG disabled
#device ICSP=1
#define dClockSpeed 32000000
setup_oscillator(OSC_Internal,dClockSpeed);
output_high(pin_E5);
output_low(pin_E5);
output_low(pin_E5);
output_low(pin_E5);
output_low(pin_E5);
_________________ Regards, Edwin. PCWHD v5.114
stinky
Joined: 05 Mar 2012 Posts: 99 Location: Central Illinois
Posted: Wed Jul 02, 2014 3:53 pm |
Just a guess. I don't know this device.
Does setup_oscillator(x) do everything needed or is there also a fuse that has to be set?
Since the two clock speeds give the same result it almost seems like it is defaulting to a clock source/speed. Perhaps not the one you intended? |
jeremiah
Posted: Wed Jul 02, 2014 5:02 pm |
Most PIC24's rely on the #fuses and #use delay() statements to be correct. You are missing both (you didn't specify any oscillator fuses at all) in the code you provided. You don't typically need setup_oscillator() unless you are changing stuff at run time.
I've never used a USB enabled PIC and I don't have that particular one to test against, but if I was gonna take a first stab at it with what I am used to on other PIC24 chips, I would try:
#case
#device ICSP=1
#fuses NOPR
#fuses FRC_PLL
#fuses NOCKSNOFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#fuses NOIESO //Internal External Switch Over mode disabled
#fuses PLL2 //Divide By 2(8MHz oscillator input)
#use delay(internal=8000000,clock=32000000)
output_high(PIN_E5);
output_low(PIN_E5);
output_low(PIN_E5);
output_low(PIN_E5);
output_low(PIN_E5);
It probably isn't enough to use USB, but you didn't specify you needed that. |
Torello
Posted: Thu Jul 03, 2014 1:32 am |
Thanks for your help. No, I don't need USB.
I'm just looking what it will take to migrate my 16K lines PIC18 code to this new processor using CCS.
If build-in functions in Pic24 are (very) different in comparison to the Pic18 , I need to find solid info about that. Otherwise I'll get lost in a swamp, and it will take me ages.
Build in help seems to be too short.
I'll give your example a try. _________________ Regards, Edwin. PCWHD v5.114 |
Posted: Thu Jul 03, 2014 2:12 am |
Most things are the same.
Big differences are with the maths types.
This is where being 'explicit', and using types like uint8_t, rather then generically 'int', makes it much easier to shift code. Use a text editor, and it's search and replace, and change the types used throughout the code, to be definitive. Be particularly careful about signed, versus unsigned.
So long as your code only used generic functions (rather than doing things like direct port IO for example), 99% should copy and run. The bits that cause problems are the changes to the physical hardware (so 16 bits as a port size, different timers, etc. etc..).
If you look at a lot of the CCS examples, they are written to merrily compile for PIC16/PIC18/PIC24 interchangeably. If you look at something like ex_extee.c, the same core code is being used for all the chip versions, with just the header changing. |
Torello
Posted: Sat Jul 05, 2014 10:17 am |
Well still can't get the Pic24 running on 32Mhz with use of the CCS supplied functions. tried many combinations of *use delay(..) or setup_oscillator(). It ends up to an max of 16Mhz.
The built in Pic24 wizard generates only:
#device ICSP=1
#use delay(internal=32MHz)
And compiled and loaded in my chip also runs 16Mhz
Seems no other options left then figuring out what the datasheet says about the oscillator circuitry and manually load all the configuration registers correctly. _________________ Regards, Edwin. PCWHD v5.114 |
Posted: Sat Jul 05, 2014 10:45 am |
Critical question. What compiler version?. |
Torello
Posted: Sun Jul 06, 2014 5:48 am |
The latest: PCWHD 5.026 _________________ Regards, Edwin. PCWHD v5.114 |
Joined: 01 Jul 2010 Posts: 9210 Location: Greensville,Ontario
Posted: Sun Jul 06, 2014 6:37 am |
OK, I don't use that PIC but...
any chance this line...
#device ICSP=1
forces a set of default fuses ? |
Torello
Posted: Wed Jul 23, 2014 2:23 pm |
Finally found a work-arround. Still think there is something messed up with #use delay() for the Pic24FJ128GC006.
Any way, got it working by using the 2 #Fuses; FRC_PLL and PLL1. And then the #use delay(clock=32Mhz). The option clock does not alter previous #fuses settings.
#device ICSP=1
#fuses FRC_PLL
#fuses PLL1
#use delay(clock=32Mhz) //Don't use Internal=32Mhz !!
output_low(pin_E5);
output_low(pin_E5);
output_low(pin_E5);
output_low(pin_E5);
