aaronik19
Multiple flags |
Posted: Mon Jul 14, 2014 3:53 pm |
Dear all,
In my project i have series of flags (about 14) which i need to check (not simultaneously). I am creating a boolean for each one but i am suspecting that there might be an easier and more practical way. Can someone give me a hint how i can improve this concept? |
Joined: 01 Jul 2010 Posts: 9169 Location: Greensville,Ontario
Posted: Mon Jul 14, 2014 4:58 pm |
Most PICs these days have LOTS of RAM , so why not just use 1 Byte / flag? yes, overkill and 'wasteful' but easier to implement,potentially faster to process.
In your case it's just 14 bytes... shouldn't be a big deal.
It could be done in 2 bytes but there could be more 'processing' required.
jay |
Posted: Mon Jul 14, 2014 11:38 pm |
There is nothing wrong with using the separate int1's though (technically they are not 'boolean' - pedantic here!...). The PIC has an efficient bit test operation which accesses these. You could just create a structure of 14 one bit fields in a single variable, which is in some ways 'tidier'. |
asmboy
Posted: Tue Jul 15, 2014 10:53 am |
to make and manage 16 flags there is this method:
unsigned int16 myword=0;
#bit fmw0 myword.0
#bit fmw1 myword.1
#bit fmw15 myword.15
// if your flags default to zero then this test below is efficient
if (myword) // at least one flag is set , so go sort it out
Mike Walne
Posted: Tue Jul 15, 2014 11:03 am |
OR
Look for any change in 'myword' to detect flag activity in either direction.
Mike
You're not giving us much to work on. |
