salmankhalid16
FREQUENCY COUNTER PROBLEM |
Posted: Sat Jun 21, 2014 9:09 am |
Hello All
i want to make a frequency counter. The frequency range is from 0Hz to 1000Hz... I am using 11.0592MHz crystal... Also i want to generate a 100Hz pulse using timer 2...
my code is as under
#include <main.h>
int count = 0;
int16 isr_ccp_delta;
int16 current_ccp_delta;
int16 frequency;
#int_ccp2
void ccp2_isr(void)
int16 current_ccp;
static int16 old_ccp = 0;
// Read the 16-bit hardware CCP2 register
current_ccp = CCP_2;
// Calculate the time interval between the
// previous rising edge of the input waveform
// and the current rising edge. Put the result
// in a global variable, which can be read by
// code in main().
isr_ccp_delta = current_ccp - old_ccp;
// Save the current ccp value for the next pass.
old_ccp = current_ccp;
#INT_TIMER2
int_tmr2()
count = 1;
setup_adc_ports(ALL_ANALOG);
setup_timer_2(T2_DIV_BY_16,173,10);
set_timer1(0);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
setup_ccp2(CCP_CAPTURE_RE);
clear_interrupt(INT_CCP2);
enable_interrupts(INT_CCP2);
if(count == 1)
output_high(PIN_C3);
disable_interrupts(GLOBAL);
current_ccp_delta = isr_ccp_delta;
// To calculate the frequency of the input signal,
// we take the number of clocks that occurred
// between two consecutive edges of the input signal,
// and divide that value into the number of Timer1
// clocks per second. Since we're using a 11.0592 MHz
// clock, the Timer1 clock is 2764800 MHz (Timer1 runs
// at the instruction cycle rate, which is 1/4 of the
// internal clock frequency). For example, suppose the
// the input waveform has a frequency of 244 Hz.
// 244 Hz has a period of about 4098 usec.
// Timer1 is clocked at 2764800 MHz, so between two
// consecutive rising edges of the input signal,
// it will count up by 4098 clocks. To find the
// frequency, we divide 4098 into the number of
// clocks that occur in 1 second, which is 2764800.
frequency = (2764800L / current_ccp_delta);
printf("%4X\n\r",frequency);
count = 0;
if(count == 0)
output_low(PIN_C3);
1. I am unable to read the correct frequency... Please help
the frequency range i want to read is from 0Hz to 1000Hz |
Joined: 01 Jul 2010 Posts: 9202 Location: Greensville,Ontario
Posted: Sat Jun 21, 2014 10:42 am |
OK....
WHAT is the signal source you're trying to read ?
What is the frequency you are trying to read AND what is the displayed value the PIC sends to the PC terminal program?
Also WHICH PIC are you using...
What version of the compiler ...
We need to know this before we can help further...
Jay |
gpsmikey
Posted: Sat Jun 21, 2014 12:06 pm |
You also need to explain how you determine the "edges" of the waveform (and what that waveform is). If you do not have good edge detection and some form of filtering, you will probably get numbers all over the place since the edge detection is not accurate.
mikey _________________ mikey
Mike Walne
Posted: Sat Jun 21, 2014 3:39 pm |
I did code for a frequency meter section in this link.
http://www.ccsinfo.com/forum/viewtopic.php?t=47375
It SHOULD provide you with all you need for that section.
The 100Hz square wave is a separate issue. What is the accuracy required for the square wave?
Mike
EDIT Scrub your other post on this same topic, it wastes everyone's time.
And learn to use the code button. |
