keith landreth Guest
Timer 3 on PIC18F452 |
Posted: Fri May 30, 2003 10:32 am |
I'm using Timer 3 as the timer. I'm using a 8 Mhz crystal. I set up timer 3 for internal div by 8 and preloaded timer 3 with 50,000 (since it is 16 bit). The timer should update every 4 us and with the preload should rollover every .2 sec. When it rolls over 5 times this should be 1 sec.
It is updating much faster. I have done a similar application using RTCC. Is there something about Timer 3 that is different.
I'm using Timer0 and Timer1 to count 2 different pulses over the 1 minute.
Any ideas?
Thanks,
___________________________
Original Post ID: 144514888 |
Tomi Guest
Re: Timer 3 on PIC18F452 |
Posted: Fri May 30, 2003 10:41 am |
Timer3 is an up-counter. It will rollover after 65535th cycle.
If you preload it with 50000 then the timer3 will rollover in every (65536-50000)= 15536 cycles. What is cca. 62 msec.
Preload (65536-50000) = 15536 to get the desired period.
:=I'm using Timer 3 as the timer. I'm using a 8 Mhz crystal. I set up timer 3 for internal div by 8 and preloaded timer 3 with 50,000 (since it is 16 bit). The timer should update every 4 us and with the preload should rollover every .2 sec. When it rolls over 5 times this should be 1 sec.
:=It is updating much faster. I have done a similar application using RTCC. Is there something about Timer 3 that is different.
:=I'm using Timer0 and Timer1 to count 2 different pulses over the 1 minute.
:=Any ideas?
:=Thanks,
Original Post ID: 144514889 |
Posted: Fri May 30, 2003 10:53 am |
:=Timer3 is an up-counter. It will rollover after 65535th cycle.
:=If you preload it with 50000 then the timer3 will rollover in every (65536-50000)= 15536 cycles. What is cca. 62 msec.
:=Preload (65536-50000) = 15536 to get the desired period.
:=:=I'm using Timer 3 as the timer. I'm using a 8 Mhz crystal. I set up timer 3 for internal div by 8 and preloaded timer 3 with 50,000 (since it is 16 bit). The timer should update every 4 us and with the preload should rollover every .2 sec. When it rolls over 5 times this should be 1 sec.
:=:=It is updating much faster. I have done a similar application using RTCC. Is there something about Timer 3 that is different.
:=:=I'm using Timer0 and Timer1 to count 2 different pulses over the 1 minute.
:=:=Any ideas?
:=:=Thanks,
I preloaded the 15536 and it still is way to fast. He is my code.
#int_TIMER3
TIMER3_isr()
set_timer3(preload);
TMR3IF_BIT = 0;
if(++timer = 5)
++second;
timer = 0;
setup_timer_0(RTCC_EXT_H_TO_L | RTCC_DIV_1);
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
setup_timer_3(T3_INTERNAL|T3_DIV_BY_8);
enable_interrupts(INT_TIMER3);
TMROIF_BIT = 0;
TMR3IF_BIT = 0;
INT1IF_BIT = 0;
LCD_init();
CLEAR_DISP;
RD16_BIT = 1;
LCD_position (FIRST_LINE);
printf(LCD_char, "Time = \%d sec", i );
cnt_time = 60;
set_timer0(0);
set_timer1(0);
enable_interrupts(global);
while(i < (cnt_time +1))
if(second = 1)
printf(LCD_char, "Time = \%u sec", ++i );
second = 0;
Original Post ID: 144514890 |
Tomi Guest
Posted: Fri May 30, 2003 10:59 am |
How faster? 5 times ?
Maybe you want to write
if(++timer == 5)
instead of
if(++timer = 5)
:=:=Timer3 is an up-counter. It will rollover after 65535th cycle.
:=:=If you preload it with 50000 then the timer3 will rollover in every (65536-50000)= 15536 cycles. What is cca. 62 msec.
:=:=Preload (65536-50000) = 15536 to get the desired period.
:=:=:=I'm using Timer 3 as the timer. I'm using a 8 Mhz crystal. I set up timer 3 for internal div by 8 and preloaded timer 3 with 50,000 (since it is 16 bit). The timer should update every 4 us and with the preload should rollover every .2 sec. When it rolls over 5 times this should be 1 sec.
:=:=:=It is updating much faster. I have done a similar application using RTCC. Is there something about Timer 3 that is different.
:=:=:=I'm using Timer0 and Timer1 to count 2 different pulses over the 1 minute.
:=:=:=Any ideas?
:=:=:=Thanks,
:=I preloaded the 15536 and it still is way to fast. He is my code.
:=#int_TIMER3
:=TIMER3_isr()
:= set_timer3(preload);
:= TMR3IF_BIT = 0;
:= if(++timer = 5)
:= ++second;
:= timer = 0;
:= setup_timer_0(RTCC_EXT_H_TO_L | RTCC_DIV_1);
:= setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
:= setup_timer_2(T2_DISABLED,0,1);
:= setup_timer_3(T3_INTERNAL|T3_DIV_BY_8);
:= enable_interrupts(INT_TIMER3);
:= TMROIF_BIT = 0;
:= TMR3IF_BIT = 0;
:= INT1IF_BIT = 0;
:= LCD_init();
:= CLEAR_DISP;
:= delay_ms(1000);
:= RD16_BIT = 1;
:= LCD_position (FIRST_LINE);
:= printf(LCD_char, "Time = \%d sec", i );
:= cnt_time = 60;
:= set_timer0(0);
:= set_timer1(0);
:= enable_interrupts(global);
:= while(i < (cnt_time +1))
:= if(second = 1)
:= printf(LCD_char, "Time = \%u sec", ++i );
:= second = 0;
Original Post ID: 144514891 |
Posted: Fri May 30, 2003 11:15 am |
:=How faster? 5 times <img src="http://www.ccsinfo.com/pix/forum/smile.gif" border="0"> ?
:=Maybe you want to write
:=if(++timer == 5)
:=instead of
:=if(++timer = 5)
:=:=:=Timer3 is an up-counter. It will rollover after 65535th cycle.
:=:=:=If you preload it with 50000 then the timer3 will rollover in every (65536-50000)= 15536 cycles. What is cca. 62 msec.
:=:=:=Preload (65536-50000) = 15536 to get the desired period.
:=:=:=:=I'm using Timer 3 as the timer. I'm using a 8 Mhz crystal. I set up timer 3 for internal div by 8 and preloaded timer 3 with 50,000 (since it is 16 bit). The timer should update every 4 us and with the preload should rollover every .2 sec. When it rolls over 5 times this should be 1 sec.
:=:=:=:=It is updating much faster. I have done a similar application using RTCC. Is there something about Timer 3 that is different.
:=:=:=:=I'm using Timer0 and Timer1 to count 2 different pulses over the 1 minute.
:=:=:=:=Any ideas?
:=:=:=:=Thanks,
:=:=I preloaded the 15536 and it still is way to fast. He is my code.
:=:=#int_TIMER3
:=:=TIMER3_isr()
:=:= set_timer3(preload);
:=:= TMR3IF_BIT = 0;
:=:= if(++timer = 5)
:=:= ++second;
:=:= timer = 0;
:=:= setup_timer_0(RTCC_EXT_H_TO_L | RTCC_DIV_1);
:=:= setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
:=:= setup_timer_2(T2_DISABLED,0,1);
:=:= setup_timer_3(T3_INTERNAL|T3_DIV_BY_8);
:=:= enable_interrupts(INT_TIMER3);
:=:= TMROIF_BIT = 0;
:=:= INT1IF_BIT = 0;
:=:= LCD_init();
:=:= CLEAR_DISP;
:=:= delay_ms(1000);
:=:= RD16_BIT = 1;
:=:= LCD_position (FIRST_LINE);
:=:= printf(LCD_char, "Time = \%d sec", i );
:=:= cnt_time = 60;
:=:= set_timer0(0);
:=:= set_timer1(0);
:=:= enable_interrupts(global);
:=:= while(i < (cnt_time +1))
:=:= if(second = 1)
:=:= printf(LCD_char, "Time = \%u sec", ++i );
:=:= second = 0;
It is running about 4 times faster than it should. I have a signal gen set to 600 hz on Timer0 and Timer1. At the end of the 1 minute clock cycle, the counters are returning around 8,900 instead of the 36,000.
I made the correction [if(++timer = 5)] and it still does the same thing.
Original Post ID: 144514892 |
Tomi Guest
Posted: Fri May 30, 2003 11:34 am |
<font face="Courier New" size=-1>Check your code for proper C syntax/semantics. You have at least another typo:
if(second = 1) ...... // if(second == 1) ???????
:=:=:= if(second = 1)
:=:=:= LCD_position (FIRST_LINE);
:=:=:= printf(LCD_char, "Time = \%u sec", ++i );
:=:=:= second = 0;
:=:=:= }</font>
Original Post ID: 144514893 |
Posted: Fri May 30, 2003 11:36 am |
:=<font face="Courier New" size=-1>Check your code for proper C sytax/semantics. You have at least another typo:
:=if(second = 1) ...... // if(second == 1) ???????
:=:=:=:= if(second = 1)
:=:=:=:= LCD_position (FIRST_LINE);
:=:=:=:= printf(LCD_char, "Time = \%u sec", ++i );
:=:=:=:= second = 0;
:=:=:=:= }</font>
Tomi,
Thanks for the help. That was it.
Original Post ID: 144514894 |
R.J.Hamlett Guest
Posted: Fri May 30, 2003 2:55 pm |
:=:=<font face="Courier New" size=-1>Check your code for proper C sytax/semantics. You have at least another typo:
:=:=if(second = 1) ...... // if(second == 1) ???????
:=:=:=:=:= if(second = 1)
:=:=:=:=:= LCD_position (FIRST_LINE);
:=:=:=:=:= printf(LCD_char, "Time = \%u sec", ++i );
:=:=:=:=:= second = 0;
:=:=:=:=:= }</font>
:=Tomi,
:=Thanks for the help. That was it.
Worth also adding, that if you want the timer to be reasonably accurate, _add_ the starting number to the current value, rather than just setting it.
The problem otherwise is that the interrupt handler, will typically add perhaps 10 to 15uSec from the moment the interrupt occurs, till you reach the routine (and this is assuming that nothing else had the interrupts disabled - such as another interrupt handler, or some parts of the code). Since this time can vary, the reset 'point', may be at different points in the timer. If instead you add the required number to the current count (except for the latency between reading the value, and re-writing it), the timing will be much more accurate. :-)
Original Post ID: 144514904 |
