gets() Problem
Jhon_ST
gets() Problem
PostPosted: Sun Jun 01, 2014 7:38 pm     Reply with quote
hi I am trying to prepare a program controlled by a virtual terminal. Then I have a problem with the function gets (string) it blocks in the while loop. I want to know how to execute the same program if I did not write the letter R is disigne as loop interruption
while(true)
 gets(string);
  if(!strcmp(string,retour)){  // blocked  here
     goto start;
if(a==1)
    output_low(pin_d0);
    output_high(pin_d1);
    s=1;
if(b==1)
    output_high(pin_d0);
    output_low(pin_d1);
   if((input(pin_a0)==1)&&((b==1)||(s==1))){
    c=5;
  output_high(pin_D2);
   delay_us(1000);
  output_low(pin_D2);
   delay_us(60);
  for(i=0;i<c;i++)
  delay_us(60);
  output_low(pin_D2);
   delay_us(60);}
  {output_low(pin_D2);
this is a part of program if i delete the gets(string); the program was running normally Rolling Eyes
Mike Walne
PostPosted: Mon Jun 02, 2014 1:36 am     Reply with quote
Of course is sticks at gets(string).
Read the manual, it sits there waiting for a CR.
You get round the problem by polling kbhit() or use an isr.
Mike
