Using Array Pointers
SeeCwriter
PostPosted: Tue Apr 29, 2014 12:23 pm     Reply with quote
I'm using a 12LF1552 with v5.025 compiler. My program has two arrays consisting of 10 32-bit integers declared as such:
const u32 lowband_data[] = {
   0x02000004,
   0x0300008C,
   0x05006095,
   0x062003CA,
   0x0700044D,
   0x0809BEFF,
   0x098DBFFF,
   0x0A002205,
   0x0B0F8071,
   0x0F000081
const u32 highband_data[] = {
   0x02000004,
   0x03000091,
   0x05006095,
   0x062003CA,
   0x07000C4D,
   0x0809BEFF,
   0x098DBFFF,
   0x0A002205,
   0x0B078071,
   0x0F000081
What I found that doesn't work is to use a pointer to access the arrays. For example, this does not work:
u32 *pReg;
   Init();
   while( TRUE ) {
           pReg = ( input( BAND_SELECT ) ) ? highband_data:lowband_data;
          ProgramDevice( pReg );
          sleep();
void ProgramDevice( u32 *p )
   int nRegs, Reg;
   nRegs = sizeof(lowband_data) >> 2;  // Number of regs to program
   for ( Reg = 0; Reg < nRegs; Reg++) {
      SetReg( p[Reg] );
      delay_us(10);
void SetReg( u32 data )
What does work is this:
     byte high_band;
   Init();
   while( TRUE ) {
           high_band = ( input( BAND_SELECT ) ) ? 1:0;
          ProgramDevice( high_band );
          sleep();
void ProgramDevice( byte high_band )
   int nRegs, Reg;
      if ( high_band )    SetReg( highband_data[Reg] );
      else               SetReg( lowband_data[Reg] );
      delay_us(10);
I think both methods should work, or did I do something wrong with the first method?
PostPosted: Tue Apr 29, 2014 12:54 pm     Reply with quote
A search here would have found the answer.
The PIC (unlike most processors), has a separate memory space for ROM, and RAM. Const values are stored in ROM. Normal variables in RAM.
Pointers point to the RAM address space.
On the 'bigger' PIC's, there is an option to use the rom keyword, instead of const, and then the compiler will generate the extra code to allow pointers to be constructed to these values. You have to declare the pointer as a rom pointer as well.
However this is quite bulky, and on your small PIC, might not be useable.
rom u32 highband_data[] = {
   0x02000004,
   0x03000091,
   0x05006095,
   0x062003CA,
   0x07000C4D,
   0x0809BEFF,
   0x098DBFFF,
   0x0A002205,
   0x0B078071,
   0x0F000081
//and the pointer as
rom u32 *pReg;
SeeCwriter
PostPosted: Tue Apr 29, 2014 1:18 pm     Reply with quote
Good point. But I think the compiler should have at least thrown a warning about an incompatible type assignment.
PostPosted: Tue Apr 29, 2014 2:41 pm     Reply with quote
Not really. There is nothing incompatible, it just doesn't work!....
C has no type checking inbuilt. You can assign a number between types completely flexibly. The language will convert types if it can, but it is up to you as a user to check that numbers are compatible. So (for instance), there is nothing to stop you having a signed number, and then printing this with the %u printf format.
The same applies with the memory spaces. Both have addresses in the same range. You could use the address of a value in ROM, and then use the read_program_memory function to access the value. Though there is a caveat here that a const _may_ have extra data in front of it that is not actually the value.
