mourad
I need your opinion in my program that i just wrote. thx u. |
Posted: Mon Apr 07, 2014 2:09 pm |
//RJ45 cable tester
#include "demo.h"
#byte PORTA = 0x05
#byte PORTB = 0x06
#byte PORTC = 0x07
#byte PORTD = 0x08
int1 TestSTPair(int8 p) // Test traight-through pair p
int address;
address = p<<1;
// First half
bit_set(PORTD,address); // test High
if (!bit_test(PORTC,address))
return 0;
bit_clear(PORTD,address); // test Low
if (bit_test(PORTC,address))
return 0;
// Second half
bit_set(PORTD,address+1); // test High
if (!bit_test(PORTC,address+1))
return 0;
bit_clear(PORTD,address+1); // test Low
if (bit_test(PORTC,address+1))
return 0;
return 1;
void TestSTCable() // Test traight-through cable
int8 pair;
PORTD = 0;
PORTB = 0;
for (pair = 0; pair < 4; pair++) // scan pairs
if (TestSTPair(pair) && bit_test(PORTA,pair)) // selected & connected?
bit_set(PORTB,pair+4); // turn on LED
delay_ms(500); // wait a bit
PORTB = 0;
int1 TestCOPair(int8 p) // Test crossover pair p
switch (p)
case 0: bit_set(PORTD,0); // test High
if (!bit_test(PORTC,4))
return 0;
bit_clear(PORTD,0); // test Low
if (bit_test(PORTC,4))
return 0;
bit_set(PORTD,2); // test High
if (!bit_test(PORTC,5))
return 0;
bit_clear(PORTD,2); // test Low
if (bit_test(PORTC,5))
return 0;
case 1: bit_set(PORTD,4); // test High
if (!bit_test(PORTC,0))
return 0;
bit_clear(PORTD,4); // test Low
if (bit_test(PORTC,0))
return 0;
bit_set(PORTD,5); // test High
if (!bit_test(PORTC,2))
return 0;
bit_clear(PORTD,5); // test Low
if (bit_test(PORTC,2))
return 0;
case 2: bit_set(PORTD,6); // test High
if (!bit_test(PORTC,3))
return 0;
bit_clear(PORTD,6); // test Low
if (bit_test(PORTC,3))
return 0;
bit_set(PORTD,7); // test High
if (!bit_test(PORTC,1))
return 0;
bit_clear(PORTD,7); // test Low
if (bit_test(PORTC,1))
return 0;
case 3: bit_set(PORTD,3); // test High
if (!bit_test(PORTC,6))
return 0;
bit_clear(PORTD,3); // test Low
if (bit_test(PORTC,6))
return 0;
bit_set(PORTD,1); // test High
if (!bit_test(PORTC,7))
return 0;
bit_clear(PORTD,1); // test Low
if (bit_test(PORTC,7))
return 0;
return 1;
void TestCOCable() //Test crossover cable
int8 pair;
PORTD = 0;
PORTB = 0;
if (TestCOPair(pair) && bit_test(PORTA,pair)) // selected & connected?
PORTB = 0;
#int_EXT
void EXT_isr() // External interrupt service routine
if (bit_test(PORTB,1))
TestSTCable(); // go and test straight-through cable
TestCOCable(); // go and test crossover cable
int8 counter;
///////////////////////// S E T U P ///////////////////////////
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
PORTA = 0;
PORTB = 0;
PORTC = 0;
PORTD = 0;
set_tris_a(0xFF);
set_tris_b(0x0F);
set_tris_d(0x00);
set_tris_c(0xFF);
ext_int_edge( H_TO_L );
enable_interrupts(INT_EXT);
enable_interrupts(global);
// blink all LEDs ///////////////////////////
for (counter=0;counter<4;counter++)
bit_set(PORTB,counter+4);
PORTB=0;
Sleep(); // Go to sleep
delay_cycles(1); // NOP
Aurbo
Re: I need your opinion in my program that i just wrote. thx |
Posted: Sun Aug 17, 2014 10:23 am |
Could you demonstrate how you'd take the results and display them on an LCD instead of just LED's?
The LED output looks so mid 2006ish...
Or perhaps how to code the S1 switch bank to use keypad input variables instead to free up those pins.
mourad wrote: | Code: |
//RJ45 cable tester
#include "demo.h"
#byte PORTA = 0x05
#byte PORTB = 0x06
#byte PORTC = 0x07
#byte PORTD = 0x08
int address;
address = p<<1;
// First half
return 0;
return 0;
// Second half
return 0;
return 0;
return 1;
int8 pair;
PORTD = 0;
PORTB = 0;
PORTB = 0;
switch (p)
return 0;
return 0;
return 0;
return 0;
return 0;
return 0;
return 0;
return 0;
return 0;
return 0;
return 0;
return 0;
return 0;
return 0;
return 0;
return 0;
return 1;
int8 pair;
PORTD = 0;
PORTB = 0;
PORTB = 0;
#int_EXT
int8 counter;
setup_adc(ADC_OFF);
setup_spi(FALSE);
PORTA = 0;
PORTB = 0;
PORTC = 0;
PORTD = 0;
set_tris_a(0xFF);
set_tris_b(0x0F);
set_tris_d(0x00);
set_tris_c(0xFF);
PORTB=0;
