Help with UDP rx/tx
fr3nsis
Help with UDP rx/tx
PostPosted: Tue Apr 01, 2014 12:57 pm     Reply with quote
I need to send rfid id via ethernet to one pc that will replay with id acquired, this through ethernet.
I have choosed udp protocol but i don't understand why sometimes socket becomes invalid and program stop to receives data.
This is my code:
    #include <a.h>
    #include "my_lcd.c"
    #include "DS3231.c"
    #define LCD_ON output_low(PIN_B4);
    #define LCD_OFF output_high(PIN_B4);
    #define STACK_USE_ICMP  1
    #define STACK_USE_ARP   1
    #define STACK_USE_UDP   1
    #define MAX_SOCKETS     6
    #define MAX_UDP_SOCKETS 4
    UDP_SOCKET last_rx_socket=INVALID_UDP_SOCKET;
    #CASE // make compiler case sensative
    #define UDP_SOURCE_PORT 1024  //set port to receive data from
    #define UDP_DESTINATION_PORT  1025  //set port to send data to
    #define UDP_NUM_LISTEN_SOCKETS   2  //set maximum number of computers to communicate with
    void PicInit(void);
    void UDPTxTask(void);
    void UDPRxTask(void);
    NODE_INFO RemoteNode;
    int counter=0,crediti=0,ok=0,w=0;
    unsigned char LeggiSeriale[3] = {0xA0, 0x01, 0x01};
    char *weekday[] = {"", "Lun", "Mar", "Mer", "Gio", "Ven", "Sab","Dom"};
    int8 VoceMenu=0;
    unsigned char  year = 14;
    unsigned char month = 3;
    unsigned char date = 12;
    unsigned char day = 3;
    unsigned char hours = 15;
    unsigned char minutes = 9;
    unsigned char seconds = 0;
    unsigned short pm_am;
    register float temp;
    void AzzeraBuffer();
    void Read_Data();
    void RSeriale();
    void Read_I2C();
    unsigned char ibuffer[4]={0,0,0,0},RX[16]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
    void IPAddressInit(void)
     //IP address of this unit
       MY_IP_BYTE1=192;
       MY_IP_BYTE2=168;
       MY_IP_BYTE3=1;
       MY_IP_BYTE4=84;
       //network gateway
       MY_GATE_BYTE1=192;
       MY_GATE_BYTE2=168;
       MY_GATE_BYTE3=1;
       MY_GATE_BYTE4=254;
       //subnet mask
       MY_MASK_BYTE1=255;
       MY_MASK_BYTE2=255;
       MY_MASK_BYTE3=255;
       MY_MASK_BYTE4=0;
       //MAC address of this unit
       MY_MAC_BYTE1=MY_DEFAULT_MAC_BYTE1;
       MY_MAC_BYTE2=MY_DEFAULT_MAC_BYTE2;
       MY_MAC_BYTE3=MY_DEFAULT_MAC_BYTE3;
       MY_MAC_BYTE4=MY_DEFAULT_MAC_BYTE4;
       MY_MAC_BYTE5=MY_DEFAULT_MAC_BYTE5;
       MY_MAC_BYTE6=MY_DEFAULT_MAC_BYTE6;
             PicInit();
             IPAddressInit();
             StackInit();
                StackTask();
                UDPRxTask();
                UDPTxTask();
            if (ibuffer[0]!=0){
             printf(lcd_putc,"\nRX:     %2X%2X%2X%2X", ibuffer[0],ibuffer[1],ibuffer[2],ibuffer[3]);
             ibuffer[0]=0;
             UDPDiscard();
               delay_ms(200);
                if (!input(PIN_D0)){
                   Read_Data();
         if (ok==1){
         lcd_putc("\fCARD ID:");
         printf(lcd_putc,"%2X%2X%2X%2X", RX[3],RX[4],RX[5],RX[6]);
            UDPDiscard();
    void PicInit(void){
    LCD_ON;
    LCD_OFF;
    //DS3231_init();
    LCD_ON;
    LCD_OFF;
    //setDate(day,date,month,year);
    //setTime(hours,minutes,seconds,0,0);
    lcd_init();
    LCD_ON;
    LCD_OFF;
    lcd_putc("\fReader ETH v1.00\n(c) 2014 Pompili F.");
    LCD_ON;
    void AzzeraBuffer(){
    for (counter=0;counter<16;counter++)
    RX[counter]=0x00;
    void Read_Data(){
    ok=0x0;
    crediti=0x0;
    RSeriale();
    if(RX[1]!=0x01 || RX[2]!=0x00)
    {ok=0;return;};
    ok=1;
    return ;
    void RSeriale(){
    AzzeraBuffer();
    i2c_start();
    for(counter=0;counter<3;counter++)  i2c_write(LeggiSeriale[counter]);
    i2c_stop();
    delay_ms(200);
    Read_I2C();
    void Read_I2C(){
    i2c_start();
    i2c_write(0xA1);
    RX[0]=i2c_read(1);
    for(counter=1;counter<RX[0];counter++)
    RX[counter]=i2c_read(1);
    RX[counter]=i2c_read(0);
    i2c_stop();
    void UDPRxTask(void) {
       static enum {UDP_RX_OPEN=0, UDP_RX_LISTEN=1}
                state=0;
       static UDP_SOCKET socket=INVALID_UDP_SOCKET;
       int8 z=0, c;
          if (socket==INVALID_UDP_SOCKET)
             state=UDP_RX_OPEN;
          switch (state) {
             case UDP_RX_OPEN:
                socket=UDPOpen(UDP_SOURCE_PORT,NULL,INVALID_UDP_SOCKET);
                if (socket!=INVALID_UDP_SOCKET) {
                   printf("\r\nUDP SOCKET %U OPEN FOR LISTENING", socket);
                   state=UDP_RX_LISTEN;
             case UDP_RX_LISTEN:
                if (UDPIsGetReady(socket)) {
                   last_rx_socket=socket;
                   printf(" SP:%LU DP:%LU S:%U] - ",
                      UDPSocketInfo[socket].remotePort,
                      UDPSocketInfo[socket].localPort,
                      socket
                   while(UDPGet(&c)) {
                      ibuffer[z]=c;
                      printf("%u",ibuffer[z]);
                      z++;
    void UDPTxTask(void) {
       static enum
       {UDP_TX_OPEN=2, UDP_TX_WAIT=0, UDP_TX_ISREADY=3} stato=0;
       static int8 tx_socket;
       switch (stato) {
          case UDP_TX_WAIT:
             if (tx_socket==INVALID_UDP_SOCKET) {
             stato=UDP_TX_OPEN;
          case UDP_TX_OPEN:
           tx_socket=UDPOpen(UDP_SOURCE_PORT, NULL, UDP_DESTINATION_PORT);
                printf("\r\nCan't open UDP socket for transmit");
                stato=UDP_TX_WAIT;
                stato=UDP_TX_ISREADY;
          case UDP_TX_ISREADY:
             if ((UDPIsPutReady(tx_socket)) && (RX[3]!=0)) {
             UDPPut(RX[3]);
             UDPPut(RX[4]);
             UDPPut(RX[5]);
             UDPPut(RX[6]);
             UDPFlush();
             AzzeraBuffer();
             stato=UDP_TX_WAIT;
             UDPClose(tx_socket);
